I need to leave truck running for pup but want to lock doors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Boco10, Aug 7, 2023.
  1. Aug 8, 2023 at 4:50 AM
    #41
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    If the PETA freaks don't get you, the enviro freaks might. Lots of places around here have anti idling laws.
    Rusty66 likes this.
  2. Aug 8, 2023 at 4:59 AM
    #42
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Not how it works. Key fob won't lock the truck while its running.
  3. Aug 8, 2023 at 5:07 AM
    #43
    D. Lengua
    D. Lengua Well-Known Member
    '21 Limited LB
    i've used the Toyota app to remote start, and it has a 10 minute timer counting down to when it'll shut off. if need be, start it again. only problem is the app doesn't have a 100% success rate, at times it just refuses to start. so i make sure it works before getting too far away from the vehicle.
  4. Aug 8, 2023 at 5:57 AM
    #44
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Just be careful leaving a pup in a vehicle during the warm months, even with the AC running. Shit happens!
    Chew likes this.
  5. Aug 8, 2023 at 6:06 AM
    #45
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I just did it this morning. You use the physical key inside the fob, not the buttons on the fob
    musicisevil likes this.
  6. Aug 8, 2023 at 7:44 AM
    #46
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
  7. Aug 8, 2023 at 8:23 AM
    #47
    Road Bull
    Road Bull Well-Known Member
    WA
    2022 Tacoma TRD OR; 2002 4Runner
    Remember if someone is considering leaving a dog in the car after using the remote start, this will run for a while, but will automatically shut off as well after a while. I forget if it’s 15 minutes or something, but something to be mindful of.
    Gen3TacomaOBX likes this.
  8. Aug 8, 2023 at 9:35 AM
    #48
    TheSpartan
    TheSpartan Well-Known Member
    Gorgo (22 Army Green TRD Sport DCSB)
    Your door also has a keyhole... how do you think you would get in if your battery died...
  9. Aug 8, 2023 at 9:35 AM
    #49
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 Pro
    it's 8 minutes, but pretty close.
  10. Aug 8, 2023 at 9:41 AM
    #50
    D. Lengua
    '21 Limited LB
    10 when you use the app.
    BabyBilly[QUOTED] likes this.
  11. Aug 8, 2023 at 10:42 AM
    #51
    Mpilot
    Mpilot Member
    Brad
    2023 White SR5 V6 4x4
    15 minutes for the N2Designs remote start.
    BabyBilly and BRFab like this.
  12. Aug 8, 2023 at 11:36 AM
    #52
    fyrmng
    fyrmng Member
    Generally maybe…I just posted what has worked for me. Have you tried it?
  13. Aug 8, 2023 at 11:39 AM
    #53
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My 07 will unlock the doors if I lock them and leave the engine running. I'm sure there is a way to program the vehicle to do let you do it, but you may have to take it to a dealer. I'm friends with several in LE who are dog handlers. They leave their vehicles running with doors locked for hours at a time.
  14. Aug 8, 2023 at 11:41 AM
    #54
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Yes, that was my experience. Prior to having remote start, I would try this. I had to change the settings in my truck so only the driver's door would unlock with the fob. This would allow me to, then, manually lock the door from the outside. The door buttons would not work for me for this purpose.
  15. Aug 8, 2023 at 11:49 AM
    #55
    fyrmng
    fyrmng Member
    Don’t know if it matters but I am using OEM replacement remotes. 1st set weren’t rated for submersion…and yes I did it a 2nd time. Also added a non OEM remote lock for the tailgate.
  16. Aug 8, 2023 at 1:13 PM
    #56
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I have been doing this for years leaving the dog in the truck or car. I turn off the engine leave the vehicle with the dog inside and then every 5 -10 minutes remotely start the truck and this will cool the truck down and it will automatically shut off after 8-9 minutes. I always sit by a window so the vehicle is visible and always make sure the vehicle is actually running as the lights are on but the newer Tacoma the lights do not come on so I have to be careful to make sure it is running so what I do is turn it off and restart right away or walk out to the vehicle to make sure. Never make an assumption that truck is running. just saying
  17. Aug 8, 2023 at 2:23 PM
    #57
    gfk
    gfk Well-Known Member
    It's ten mins. I work a lot from my truck and when that bad boy turns off it gets hot in there really quick, like dead dog hot. I would at the VERY least set a timer for 7 mins to get back over to it. Not worth risking it with the auto start. My truck also just turns off after a while of me sitting in it with it on in park. I don't know an exact time but it does turn off after a while. I'm in FL, and like i said I work from my truck via the wifi a lot and it does turn off on me after sitting for a while.
  18. Aug 9, 2023 at 10:36 AM
    #58
    Mpilot
    Mpilot Member
    Brad
    If you order the N2Designs remote start, you can talk to them when you place your order and have them do a custom time for the truck to shut off. The standard time is 15 minutes, but they can do up to 60 minutes. I had them do this for me and it was no extra charge.
  19. Aug 9, 2023 at 2:56 PM
    #59
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    I have an H-Key and "12 volt solutions" remote start and do what OP is asking frequently... it'll run for ~15 minutes then shut off.
