I need to tow my 4WD tacoma and need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cmccain13, Sep 27, 2020.
  1. Oct 1, 2020 at 9:58 AM
    #41
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    The input shafts on Tcase and manual transmission are in oil bath but the output shafts bearings rely on lubrication from moving input shafts.
  2. Oct 1, 2020 at 10:11 AM
    #42
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    What I’m saying tho is the transmission is not affected while the t case is in neutral, the output shaft bearing of the trans is not even spinning. The tcase output would be lubed tho because the chain is spraying oil?
  3. Oct 1, 2020 at 10:36 AM
    #43
    Diemaster
    Diemaster Active Member
    Josh
    San Bernardino
    2004 SR5 Tacoma 4x4 V6 Double Cab
    Ive always wondered why, with a 4X4 1st gen, you cant remove the rear driveshaft for flat towing and when you want to drive, just put it in 4X4 mode so it's propelled by the front tires only.
    also not only class A motorhomes can tow large loads. i got a class C with the Ford V10 in it and it can tow 10K pounds. My Double cab Tacoma is 1/2 that.
  4. Oct 2, 2020 at 9:44 AM
    #44
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I don't know about the towing part, but I've known people that have removed their rear driveshafts and driven around with 4hi engaged so they're effectively in FWD. Nothing wrong with doing that, just can't go too crazy driving around since the front drivetrain isn't as robust as the rear of course. but it shouldn't hurt anything.
    But flat towing that way, I'm not sure to be honest
  5. Oct 2, 2020 at 11:11 AM
    #45
    tony2018
    tony2018 Well-Known Member
    If I were towing my 1st gen that has a rebuilt rearend I'm not gonna wear out its fresh bearings. That RV better have enough torque and breaking power before I even think about flat towing. I ain't here to be cocky about what I know or don't know. These 1st gens aren't around much longer so I'm not gonna risk further damage.
  6. Oct 5, 2020 at 2:28 PM
    #46
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    I briefly touched on the auto trans in post #19.
    Yes auto trans needs fluid pumping for long hauls.
