i need your help with my taco
Discussion in '4 Cylinder' started by natebaur, Jan 21, 2009.
  1. Jan 21, 2009 at 12:15 PM
    natebaur
    natebaur [OP] Active Member
    elkorn
    00 toyota tacoma single cab
    hey my 2000 toyota tacoma reg cab dude not come with an rpm guage is there anyway to add a digital one?????
  2. Jan 21, 2009 at 12:21 PM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
  3. Jan 21, 2009 at 7:38 PM
    natebaur
    elkorn
    yea just looked up scan guage is it meant to be used while drving??? and my obd 2 plug in is in the enginebAY is it okay to run the wire through the firewall???
  4. Jan 21, 2009 at 7:41 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    i suspect that if you found a wrecked SR5 of the same generation/year range you could swap out the gauge cluster...but your mileage would be wrong
  5. Jan 21, 2009 at 7:42 PM
    mneuls
    mneuls Well-Known Member
    Fort St John, British Columbia, Canada
    5100's and dakar leaf 3"lift, Satoshi grill,
    Bilstein 5100's front and back, dakar 3" leaf springs, Westin bull bar, piaa driving lights, piaa replacement bulbs, H/U, 2x10" mtx tt65 subs, 1000w clarion monoblock, Mtx surround speakers. green wire mod. Flowmaster 40, airaid intake. scanguage II.
    y do you need rpm? you have an automatic.
  6. Jan 21, 2009 at 7:48 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Does it matter? No
  7. Jan 21, 2009 at 7:51 PM
    mneuls
    i guess not, I just don't see the point of having a tach in an auto. neither did the engineers at toyota i guess.
  8. Jan 22, 2009 at 11:15 AM
    tacoma-king
    tacoma-king Well-Known Member
    sault ste. marie Michigan
    1997 Tacoma
    hitch
    some people like to have them just to have them Just like I dont need a lift and bigger tires but I want them
  9. Jan 22, 2009 at 5:36 PM
    Aldo ct
    Aldo ct Well-Known Member
    central California
    97 Tacoma 2rz
    LC header, prerunner/4x4 front end, hellwig rear sway bar/beefed brackets, instrument cluster w/tachometer, 60/40 bench seat, solid sideview mirrors, slider rear window, rearview mirror w/map lights, 27x8.50r14 tires
    If you want it to look factory, find one at a junk yard or through someone. I am not sure if you can adjust the digital mileage to match yours.
    I did the same thing. I had an instrument cluster with no tach, and found a cluster with tach and swaped them. I took both clusters to a speedo shop and they corrected the mileage on the new cluster. I have a cable driven cluster.
  10. Jan 22, 2009 at 7:45 PM
    natebaur
    elkorn
    its nice knowing what my rpm is because when i do test like microvat or anything i need to know where 2500 rpm is at
  11. Jan 23, 2009 at 6:07 PM
    darkturtleninja
    darkturtleninja 9th level dungeon master
    Illinois
    95 2.7 3rz turd
    cold air intake, body lift, suspension lift.
    Get a Haynes or chiltons book.... its the best 15 bucks you can spend on a vehicle! in the back of the book there are wiring diagrams.... look for instrument panel guages and warning light system under the chassis electrical system diagrams. on my 95 it is the black wire in the wiring harness that plugs into the guages.
    that would be for an aftermarket tach
    and what do you know my Haynes book says 1995 thru 2000 all models.....
  12. Jan 29, 2009 at 12:51 AM
    wawireguy
    wawireguy Well-Known Member
    Haynes and Chiltons always let me down. Find a Toyota factory manual if you really want to be able to work on it.
  13. Jan 29, 2009 at 7:27 AM
    darkturtleninja
    Illinois
    95 2.7 3rz turd
    that is not the point....
  14. Mar 25, 2009 at 8:16 PM
    zigzagg321
    zigzagg321 T100
    Ohio
    96 T100 SR5
    sliding rear window
    not to dig up an old crusty thread or anything, but... Anyone try any of this yet? Id like to add a tach to my 96 2.7L.
  15. Mar 25, 2009 at 8:18 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Tigerfan is the mileage stored at the gauge cluster or in the ECU?
  16. Mar 25, 2009 at 8:31 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    i think it'll depend on whether or not the odo is digital or analog but im not sure
    never explored this...i just for some reason know that in older trucks sr5 added a tach
  17. Mar 26, 2009 at 9:47 AM
    darkturtleninja
    Illinois
    95 2.7 3rz turd
    i have an aftermarket tach... like i said... black wire....
