I ordered LT265/70R17 E rated tires. Is E rated too much? Keep or cancel the order?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoma384058, Dec 23, 2022.
  1. Dec 23, 2022 at 2:47 PM
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    This is where it is hard to tell without actually doing it and comparing the two. Everyone drives different and has different perspectives. I asked around on this and most people just said something like "Maybe a little at first but now I barely notice it" in regards to acceleration and braking. Some people just aren't sensitive to it or the way they drive, don't notice or care.
    The reality is, regardless of if someone cares or not, is that heavier will:
    • Take more power to accelerate
    • Wear out brakes faster and have longer stopping distance
    • Will "roll" better and coast longer when you take your foot off the gas (I actually like this and do notice it - helps with MPG say when rolling up to a red light.
    • Decrease MPG
    • Is harder on the transmission
    To what extent? No idea, but it is just common sense.
    Tread life? Tough to say. Probably depends more on weight of vehicle and tire/terrain.
  2. Dec 23, 2022 at 2:49 PM
    BattleKat
    San Diego
    OP< no one has really asked this and I don't see that you have supplied it. What is your goal with the tire upgrade? How do you plan to use the truck?
    NuckTrutz likes this.
  3. Dec 23, 2022 at 2:54 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Ive always ran with the same E’s that OP ordered for off-roading over rocks also, and always thought the load rating is misleading for items that are touching the ground as the truck is not carrying them. But it also takes mass and momentum into account for acceleration and deceleration (braking). The safety margin built into that rating has always been OK for me, and I don’t live in a State that weighs or inspects my truck per their registration requirement, otherwise all my armor plating, spare tank, RTT, topper and other sht would have to go also :bananadance:
  4. Dec 23, 2022 at 3:09 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    A tire’s weight has only a small effect on its efficiency. A tire’s efficiency is mostly a function of its rolling resistance and at higher speeds it’s aerodynamic resistance. In any case, there are far too many variables at play to answer your question.
    My personal experience with my 2 sets of tires (P265/70r16 good year wrangler adventures and LT255/85r16 (E) dick Cepek extreme country) is 1-2 mpg (5-10%).
  5. Dec 23, 2022 at 3:50 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    I lost 3+ mpg going from the original equipment LTX 2's to GY Ultra Terrain (load C, same size ). Can't imagine a range E being much worse.
  6. Dec 23, 2022 at 5:24 PM
    tacoma384058
    tacoma384058 [OP] Member
    They won’t let me cancel the order so I’m going to keep them I guess. They are great tires and that was never the issue. My only concern is how many mpg I might loose and how much acceleration and deceleration will slow down with 52.9 lb tires compared to 45 lb, 46 lb, 48 lb tires when I’ll have a 1.1” front lift. Maybe it won’t be too noticeable.
  7. Dec 23, 2022 at 5:25 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    don't get E-rated tires. way too much tire, too heavy, and will ride like a dump truck. it will noticeably slow down your truck. i run P-rated tires and have done lots of off-roading over rocks, driven over glass bottles, mangled steel, and have yet to have a single puncture in 16,000 miles.
    BmTaco91 likes this.
  8. Dec 23, 2022 at 5:27 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    yea, rotational weight is a big factor in acceleration
  9. Dec 23, 2022 at 5:28 PM
    Christmas
    Christmas Well-Known Member
    I have been running E-rated on all my trucks without a flat or failure since the 90's. My Tundra has Nitto Ridge Grapplers 12 ply F-rated. Where I live in the mountains there is not a 1/2 mile of straight or flat road. The ride is not car like but never had a reason to complain about the durability or performance. I also gave up on gas mileage a long time ago. We are talking about trucks after all.
    runandgun18 and NuckTrutz like this.
  10. Dec 23, 2022 at 6:15 PM
    gudujarlson
    Minnesota
    You’ll be fine. It’s not what I would call an optimal tire for your use case, but it’s not going to ruin your truck by any means. I’ve been running my LT tires since spring. I should have swapped them out for my winter/road tires a while ago.
  11. Dec 23, 2022 at 6:40 PM
    AZYotes
    AZYotes Well-Known Member
    Glendale, AZ
    '20 TRD Sport Previous - '14 Prerunner Access Cab
    I ran P285/70r17s on my '13. I got 16's on my '20 because the wheels I wanted sell out fast and I didn't want to wait for another run of 17's to come out so I had to go with LT285/75R16s. Both are ATs not mudders. The LTs are heavier. That's the only difference. They ride the same on the road and don't wear any faster. Both trucks get crap mileage but I knew they would. I don't do any off-roading so can't give any opinion there.
  12. Dec 23, 2022 at 8:40 PM
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    I’ve run P rated passenger tires (aka very light tires), C rated and E rated tires on my 2nd and 3rd gen Tacos.
    For normal use plus some off-road needs, C rated is the sweet spot.
    P rated would be fine for a daily, E rated would be good for a hardcore off-roader, but P rated for chewed up off road and the E rated we’re brutal as a daily tire on the Taco (with varying PSI to try to improve it).
    Just one more opinion to count on your journey.
    Stephen1988 likes this.
  13. Dec 23, 2022 at 8:51 PM
    Christmas
    How many of ya'll have chalk tested your tires for optimal pressures? If you're guessing on pressure for what you're doing you are "Assuming".
  14. Dec 23, 2022 at 9:29 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Cancel the order unless you need the e rated.
    cryptolime likes this.
  15. Dec 24, 2022 at 9:37 AM
    #35
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    yea, i think we'll be seeing a post in about a month about how he regrets his decision.
    BattleKat likes this.
  16. Dec 24, 2022 at 9:41 AM
    #36
    tacoma384058
    Please actually read through the thread.
  17. Dec 24, 2022 at 9:41 AM
    #37
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    why do you think i didn't read it? E-rated tires are too heavy for a small truck.
  18. Dec 24, 2022 at 9:54 AM
    #38
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
  19. Dec 24, 2022 at 9:58 AM
    #39
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I went with E rated K02's because I would rather have them and not need them, then need them and not have them. But the ride is a bit stiffer on the E-load tires but honestly they remind me what driving a 4WD truck use to feel like! :) And you will take a small MPG hit but I personally could care less about that.
    9th, NuckTrutz and Christmas like this.
  20. Dec 24, 2022 at 10:00 AM
    #40
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    It's fine! Buy the tires. Some dudes w super sensitive ass's on this sight. First thing I did was switch to big ko2s in E when I got the truck.
    johnnytwotimes, 9th and Christmas like this.
