I ordered LT265/70R17 E rated tires. Is E rated too much? Keep or cancel the order?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoma384058, Dec 23, 2022.
  1. Dec 24, 2022 at 10:04 AM
    #41
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I have E rated tires. Truck rolls on them just fine.
    Junkhead, NuckTrutz and Mark77 like this.
  2. Dec 24, 2022 at 10:06 AM
    #42
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    keep the e rated... have had them on various trucks for the last 35 years and can't remember ever having a flat.
    Junkhead, Mark77 and Christmas like this.
  3. Dec 24, 2022 at 10:15 AM
    #43
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    ‘20 Tacoma Off Road DCSB 4x4 MT
    Lots to come
    OP another great quality tire in C rated is the Nitto trailgrapplers...I am running a 285/70/17...don't know if the C rated is available in the size you want but they are worth looking into...Great tire!
  4. Dec 24, 2022 at 12:33 PM
    #44
    tacoma384058
    tacoma384058 [OP] Member
    They are a great tire. I’ve ran Trail Grapplers before. They got very noisy on the highway after 20,000 miles.
  5. Dec 25, 2022 at 5:35 PM
    #45
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    80 psi on E rated? I regularly have 800 pounds in the back of my Taco, and I never inflate over 30psi winter or summer no matter what load I carry.
    I normally have about 800 pounds of gear in the back when I am off road. Boat, toolbox and all of my camping gear. Tires are 265 75 16.
    With an 800 pound load, I still deflate to about 25psi off road, but down to 20psi if the conditions require.
    I am retired and off road all the time with my 2016 TRD OR, so E rated it is. I am at this about 35 years now, meaning off road with 4x4's.
    Any C tires I have used off road have all blown, usually sidewall punctures. I am on my 2nd set of BFG K02s on my Taco, and those tires are taking a beating and no blowouts. Last set had about 10K off road miles on them.
    Downside is that the KO2s that are driven hard off road, tend to get really noisy and rough for city driving once you hit 40K miles on them.
    As for city driving, they are fine for me and I am running Bilstein 5100s which are stiffer than stock. Still is ok. With that said, if you want a really soft smooth car like ride and don't go off road a lot, then a C rated tire is fine.
    velomutt and Junkhead like this.
  6. Dec 25, 2022 at 5:57 PM
    #46
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I don’t think E-Rated tires are too heavy for a small truck, in fact I’ve never had a blow out or a shredded sidewall running mine over rocks or going freeway speeds with them. Gas mileage is affected bit, but 16mpg isn’t bad for all the weight I have on my truck.
  7. Dec 26, 2022 at 11:43 AM
    #47
    tacoma384058
    Yes, LT265/70R17 E with max 80psi.
    I actually had a Gen2 TRD Off-Road Tacoma back in 2015-2016 and it had a 3” Toytec lift kit and LT285/65R18 Open Country RT’s with load E. Those specific tires have a max 80psi and I have no idea what psi I ran them at back then, but I guess everything always seemed fine. Same 3.5L V6 engine, so I’m assuming with the Falken Wildpeak AT3W tires I ordered that are 7 pounds lighter per tire compared to the RT’s and only lifting the front 1.1” and leaving the rear stock height that the power should be similar or a little better than the setup I ran on my old Gen2. It should be fine probably. I was debating between the 1.1” or 1.55” notch on the Bilstein 5100 but it seems my truck is exactly 1” lower in the front when I take measurements. It’s the Gen3 TRD Sport 4x4 Access Cab and there’s not much info online about Access Cabs.
    ppat4[QUOTED] likes this.
  8. Dec 26, 2022 at 1:34 PM
    #48
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    Lots to come
    Im sorry i meant to say I have a set of RidgeGrapplers not Trail....i have 25k on them and no issues what-so-ever. They wear very well and are a great hybrid of the mud and highway tire
  9. Dec 26, 2022 at 8:06 PM
    #49
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    I personally strongly dislike E rated tires. Too heavy, too jarring. If you drive over sharp rocks a LOT maybe, but otherwise there’s no reason. I’ve been on countless trails with C rated KO2s just fine.
    BC Hunter likes this.
  10. Dec 26, 2022 at 8:19 PM
    #50
    Kwikvette
    Fresno County
    4 run, 2 don't
  11. Dec 26, 2022 at 11:19 PM
    #51
    Christmas
    Christmas Well-Known Member
    No matter the rating F thru C they work the same with the correct pressure. Seems to me those with the reserves for higher ratings want their trucks to drive like a common car. Tires that come on new trucks are car like and won't last past 20k mi. due to the need to sell smooth riding trucks. Can you imagine your sports car with some soft tire expected to not feel every pot hole. Why do would you expect your truck to do that? More sidewall rating is a good thing. It's all about air pressure.
  12. Dec 27, 2022 at 7:45 AM
    #52
    2019 TRD Off Road
    There’s a big difference in on-road ride comfort between E and C. It’s not like a C rated tire is weak either.
    Stephen1988 likes this.
  13. Dec 27, 2022 at 9:00 AM
    #53
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    Same. Im on and off sites all day long and running P tires I would get 2-3 nails a year. I have never had to patch an E rated tire (5 sets so far).
  14. Dec 27, 2022 at 10:19 AM
    #54
    ppat4
    Paul
    Kelowna, BC
    In BC, most FSR and trails are full of sharp rocks. Driving over literally thousands per day is normal for my driving. I have blown 2 sets of C rated tires through the sidewall, including 2 of the garbage stock tires the 2016 TRD OR came with. Those 2 blown out on my first offroad trip with this Taco, both on the same day.
    Been running E rated for about 12K off road miles now with no issues.
    Same with my old 1986 F150 which I bought new. Blew the tires up on the first few trips, and then E rated tires after that for 10 years with no blowouts.
    None of this is rock crawling either, just typical bad off roads in BC.
    For sure if the roads are better you don’t need E rated tires. They are a lot harder riding than C.
    I also have to take into acount I am remote solo 30+ trips per year, and so less breakdowns is better. I never see any other trucks on my trips, so no posse coming to the rescue.
  15. Dec 27, 2022 at 10:27 AM
    #55
    2019 TRD Off Road
    Sounds to me like you’re conflating P (aka SL) and C ratings. C is higher rated than the stock P rating that comes with trucks.
    I run C rated KO2s on sharp rocks in CO and UT trails with no issues so far. I do air down to 17-25 psi at all times though, depending on conditions. For me, they work great for what I need. Decent durability, good comfort, and lighter weight.
  16. Dec 27, 2022 at 11:05 AM
    #56
    ppat4
    Paul
    Kelowna, BC
    No, not confused. C rated tires are equivalent to a 6 ply tire. E equivalent to a 10 ply in strength.
    My new snow tires, are Nokian Hakkapeliitta LT3 at 265 75 16 and they are D rated, so equivalent to an 8 ply tire.
    A few weeks ago, I had SL rated snow tires on the truck, the Michelin X-ice snow. Really soft tires, drove like a car. I was lookimg for better ice performance on our streets in winter. Unfortunately, they were not good in snow, but the dealer offered a full refund within 30 days so I went with the heavier duty Nokian Hakkapeliitta LT3. So far so good with them. Driving on deep snow and ice daily for a couple of weeks with them. For sure a much firmer ride but that is something I am accustomed to.
    In spring, back to the KO2s.
    To each their own. For me, it is all about trying to avoid breakdowns. So many remote trips off road and no one around to help, so the E rated offer a better insurance plan. In spring, I am back to carrying 2 spares on every trip.
    BC Hunter and Junkhead like this.
  17. Dec 27, 2022 at 11:26 AM
    #57
    2019 TRD Off Road
    You said the stock tires were C rated. They are not. They are SL. The fact they blew has no bearing on C rated tires.
  18. Dec 27, 2022 at 11:27 AM
    #58
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    If you have to ask, you don’t need them.
  19. Dec 27, 2022 at 11:10 PM
    #59
    ppat4
    Paul
    Kelowna, BC
    You are correct, I checked the specs on the Goodyear Kevlar tires it came with originally and they are SL.
    For my old 86 Ford, I blew the stock tires, then swapped out the stock tires for some Toyo that were C rated. One blew on a bad shale road, and 2 others developed huge sidewall bulges that trip. I was fortunate to get out of that area. Since then I have ran only E rated tires, other than the first month I owned this Taco.
    I get many wanting to find a tire that is rugged and is also light weight. For the roads I travel and from past experiences, I will no longer drive less than E rated. I personally am just not willing to keep taking the risks.
    Also why I swapped over to the Hakkapellita LT3 winter tire, so I can keep off roading through winter. Ice fishing here we come.
    Hey, a ton of guys here on tacomaworld drive E rated and state they will never go off road. At least they look the part. :)
    Junkhead and Christmas like this.
  20. Dec 27, 2022 at 11:29 PM
    #60
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
