I phone mount
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stripstrike1, Oct 26, 2022.
  1. Oct 26, 2022 at 11:09 AM
    Stripstrike1
    Stripstrike1 [OP] New Member
    Wade
    2022 Tacoma TRD Offroad
    None
    Need a good one. I have the cup holder mount currently and would rather have something really nice mounted on the dash that doesn't get in the way of the AC or Touch Screen.
    New Poster here....I appreciate the help.
  2. Oct 26, 2022 at 11:14 AM
    SuperAir
    SuperAir Well-Known Member
    Maine
    19 TRD ORAC Cement
    Eibach Stage 1, 17x8.5 Ray 10s, 265/70-17
  3. Oct 26, 2022 at 11:16 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
  4. Oct 26, 2022 at 11:16 AM
    LiquidArrogance
    LiquidArrogance Well-Known Member
    Streets of Bakersfield
    2021 SSM Sport 4x4
  5. Oct 26, 2022 at 11:18 AM
    Tacospike
    Two Trucks
    All good options above.
    Welcome!
  6. Oct 26, 2022 at 1:15 PM
    McPickle
    McPickle IG: @ThatTopoTaco
    Dillon
    Central Oregon
    2019 TRD OR DCSB in MGM
    https://www.etsy.com/listing/631496947/3rd-gen-tacoma-3d-printed-magnetic-phone?ref=yr_purchases
    This is what I'm running with. Doesn't require any permanent mods to your truck (definitely recommend using double sided tape once you find the spot you want it in to prevent sliding). Works even when you slip the magnetic plate on the inside of your phone case. Love how easy it is to put the phone on and take it off, and if you tighten it pretty tight to lock in a slightly upward angle, your phone doesn't slide off even on the bumpiest roads.
    Highly recommend this option, especially for $30
    atc250r likes this.
  7. Oct 26, 2022 at 1:50 PM
    LouDawgIII
    LouDawgIII Active Member
    Lou
    2024 TRD Off Road
    Quad Lock MAG w/ some cable management. Very clean setup in my opinion.
  8. Oct 26, 2022 at 2:53 PM
    AnonymousHairyTacoma
    AnonymousHairyTacoma Member
    Brady
    2022 TRD OR
    I agree with the Taco Bar. I have the three ball mount and love the options it gives you. I have the magnetic and claw style attachments so I can use the magnetic when road cruising and the claw for off-roading so it wont fall off of the magnet. If you want something a little cheaper look into the Offroam too. I had one on my old F150 work truck and really liked it as well. Mounts to the air vent, but the way it mounts wont block your vent. It will also secure your phone well enough it wont fall off when off-roading.
    https://getoffroam.com/products/toyota-tundra-tacoma-phone-mount
  9. Oct 26, 2022 at 3:39 PM
    LiquidArrogance
    2021 SSM Sport 4x4
    I used Bullet Point's stuff to mount my ultra gauge, too:
    https://www.tacomaworld.com/threads...er-up-to-the-lake.743505/page-2#post-26829537
