I Put 7-8 Gal of diesel in my V6 taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rs5, Nov 10, 2012.
Thread Status:
Not open for further replies.
  1. Nov 10, 2012 at 7:01 AM
    rs5
    rs5 [OP] TACOLIFE
    Tampa, FL 33578
    05 DC PreRunner SR5 V6 TRD Off-Road
    K&N Air Intake
    and now i find out it has no drain plug what can i do i left the gas station and 1/4 down the road it stalled and shut off on me i cranked it twice maybe three times then i realized my mistake but since i tried cranking it it probably means theres now diesel in the combustion chamber i had it towed to my home and now i go to drain the gas tank and im not finding any drain plug please help?!?!
    UPDATE: ok first and foremost FUCK ALL OF YOU WHO JUST CAME IN TO FLAME YET HAD NOTHING CONSTRUCTIVE TO SAY...on that note yes it was 3 in the morning and I was high as a kite but it was a BP gas station where all the pumps are next to each other and are the same color that being said my truck is completely ok and yes I did all the work myself I removed the bed which was pretty damn easy and was able to reach the entrance of the gas tank at which point I syphoned all the diesel out I purchased a can of seafoam and put it in the fuel tank with 5 gallons of UNLEADED PLUS after 5 or 6 cranking attempts i got it to start it was stalling so I held it at 4000 rpms for a couple of minutes then left it idle for about half an hour after all is said and done all it cost me was $162 for towing and my Sunday afternoon it is now Tuesday nd is running perfect no smoking so take note if this ever happens to you removing the bed is your best bet don't fuck with the fuel lines or the fuel pump just remove the bed thank you all who left some constructive criticism truth be told this is how I best learn about the technical aspect of every vehicle I've ever owned having a major fuck up then fixing it myself with the help of the interwebs ofcourse
  2. Nov 10, 2012 at 7:03 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    youre either going to have to syphon it all out or drop the tank
  3. Nov 10, 2012 at 7:05 AM
    rs5
    rs5 [OP] TACOLIFE
    Tampa, FL 33578
    K&N Air Intake
    i tried putting a small plastic tube through to syphon it and it wont completely go down into the tank
  4. Nov 10, 2012 at 7:09 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    I think there is a screen there to prevent syphon tubes from going in. FWIW, I read somewhere that its fairly thin and can be persuaded to get out of the way fairly easy...
  5. Nov 10, 2012 at 7:11 AM
    rs5
    rs5 [OP] TACOLIFE
    Tampa, FL 33578
    K&N Air Intake
    does anyone know of any video or how to manual on removing the fuel tank?
  6. Nov 10, 2012 at 7:11 AM
    GreatBasinTaco
    GreatBasinTaco Well-Known Member
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    you will have to have the entire fuel system flushed. check your spark plugs also, they may be fouled. The Tacoma's have something in the fuel fill neck to prevent syphoning (could be mistaken but pretty sure they do). Good luck.
  7. Nov 10, 2012 at 7:12 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    You will have to drain the tank. I'd take it off. After that fill it up and keep cranking until it starts it may take a while to get the diesel out of the fuel lines and injectors.
  8. Nov 10, 2012 at 7:15 AM
    GreatBasinTaco
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    yep. OP this is probably not a diy.
  9. Nov 10, 2012 at 7:18 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Not even sure how this could have happened... A diesel nozzle is larger than a regular gasoline nozzle. For this reason, the diesel nozzle will not fit into the gasoline tank.
    The Hunter likes this.
  10. Nov 10, 2012 at 7:24 AM
    rs5
    rs5 [OP] TACOLIFE
    Tampa, FL 33578
    K&N Air Intake
    anyway to purge the lines?
  11. Nov 10, 2012 at 7:25 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    agreed.
  12. Nov 10, 2012 at 7:26 AM
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    HELLO EXACTLY
  13. Nov 10, 2012 at 7:28 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Not always. Some of the old school pumps have the same size nozzle but the handle is green to let you know it's diesel. The small town I grew up in is like that. The gas pumps are on the ends and the diesel pump is in the middle with a green handle but the nozzles were the same size.
  14. Nov 10, 2012 at 7:29 AM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    :drunk:There may have been some adult beverages involved. :cheers:
    Seems like a tough one to pull off. No offense OP
  15. Nov 10, 2012 at 7:29 AM
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    Ah ok.
  16. Nov 10, 2012 at 7:29 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Dude didn't you smell the diesel as it was coming out? It has a very distinct smell, and you should have noticed unless you were sleeping. The big mistake was driving it ...
  17. Nov 10, 2012 at 7:32 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
  18. Nov 10, 2012 at 7:33 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    x2
  19. Nov 10, 2012 at 7:35 AM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    My sister did this with her jeep. Had it towed to a shop and like 400 bucks later it was fine. Needless to say, she always double checks when getting gas now.
  20. Nov 10, 2012 at 7:37 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
Thread Status:
