I really could use somebodies help with getting my truck back on the road.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Erumaren1, Sep 1, 2022.
  1. Sep 1, 2022 at 8:57 AM
    Erumaren1
    Erumaren1 [OP] Member
    2003 4x4 Tacoma
    Hello!
    I made an account here today in hopes that one of you fine tacoma enthusiasts would be able to help me end a two month long issue of a replacement rear diff.
    Back in July, I was in an accident where I was hit in my rear driver side tire, bending my axle and cracking the housing, since then I have spent just about every single day attempting to track down the part that I need. About a month back, I found what I thought would be a replacement, the part having all the listed requirements provided by my mechanic, so I bought it, and had it shipped to me, costing me about half a grand to do so. It gets here, turns out my truck has ELD, which I was not informed of, and my grandfather whom I purchased the truck from was not aware of either. Issue being that it is the wrong bolt pattern and can't be put onto my truck.
    So now I'm in a position where I am entirely stuck at home, having lost my job due to having no transport to and from work, and spending most of my nights awake and anxious unsure of what I'm gonna do.
    If any of you would be so kind as to let me know of any outlets of finding a replacement part outside of the usual junkyard/pick-and-pull solutions everyone has thrown at me, I would be more grateful than I could effectively put to words.
    My rear diff has the following specifications: 4:10 Gear Ratio, ELD, 13 bolt pattern, open differential
  2. Sep 1, 2022 at 10:04 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Where are you at?
    sounds like you either need a locking 3rd member, or a complete axle, or a non locking axle to put your new 3rd into
    Bivouac likes this.
  3. Sep 1, 2022 at 11:14 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What did you actually purchase, an axle housing? Or a differential for your axle housing. It might just be me, but it's hard to tell from your description.
    By ELD, I assume you are referring to an e-locker. If so, Toyota refers to this as an 8.0" ring gear diff. To confuse things, non elocker diffs also came on 1st gen trucks. The non elocker diff is referred to as an 8.4" ring gear diff. The parts and the axle housings for these two diffs are not interchangeable.
    04Pre_Runner likes this.
  4. Sep 1, 2022 at 11:30 AM
    Cryptictoy
    Cryptictoy Well-Known Member
    Esperance, N.Y
    Where are you located? You could always get a an 8.4 center and drop in the new housing and reuse your axles to get you going. Depending on how it was hit I have seen the wheel mount/axle flange get tweaked too.
  5. Sep 1, 2022 at 11:41 AM
    Queue Eh
    Queue Eh Well-Known Member
    You are looking for a TRD OFFROAD axle.
    The TRD OFFROAD package came with an Electronic Locking Differential. call local pick 'n pulls and ask if they have any 01-04 OFFROAD tacomas.
    Not the Sport, not the SR5. OFFROAD.
    This has the axle, bolt pattern and 3rd member you need.
  6. Sep 1, 2022 at 11:44 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Welcome to the forum!!
    You ask for help but never mention where you are.
    Pictures please post pictures !!
    I also have no idea just what you need.
    If i was close i could make something work!!
  7. Sep 1, 2022 at 11:45 AM
    la0d0g
    running for the hills
    For crawling not hauling
  8. Sep 1, 2022 at 12:16 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Can take take Sport of that list. Sport started with 2nd gens which was LSD no locker. 1st gens had Limited trim but that's not LSD. LSD was not offered for 1st gens afaik but I have heard a few people saying they were.
  9. Sep 1, 2022 at 12:20 PM
    Queue Eh
    I think you're correct here. Thanks.
    1st gens had 2wd, Pre-Runner, SR5, TRD Offroad and Limited. The only model that will work for OP is the OFFROAD in 4wd, as it will have the correct lug pattern and differential. Right? Or did the Pre-Runners have the same diff and lug pattern when OFFROAD package was purchased?
  10. Sep 1, 2022 at 12:22 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yep Prerunner TRD will work too, same rear end as 4WD TRD.
  11. Sep 1, 2022 at 12:23 PM
    Queue Eh
    Alright OP,
    You need to find a 1st GEN OFFROAD, whether it be 4wd or Prerunner.
    la0d0g likes this.
  12. Sep 1, 2022 at 12:24 PM
    Clearwater Bill
    Billy
    Largo Florida
    And the insurance of the person hitting you isn't funding the parts/labor for the repairs because????
    But yes, posting your location (city/state is fine to start) and you might wind up with someone able to physically assist as the previous posts indicate.
    Best of luck!
    la0d0g and knayrb like this.
  13. Sep 1, 2022 at 12:26 PM
    Erumaren1
    2003 4x4 Tacoma
    Hello! I apologize, I am very new to this, and very much so not car savvy
    I live in New Jersey, I need a housing and Axle, everything else is functional. The accident bent my axle and cracked my rear housing, I'll work on getting pictures from my mechanic when I can! Thank you for replying
  14. Sep 1, 2022 at 12:27 PM
    Erumaren1
    2003 4x4 Tacoma
    I need a housing and Axle!
  15. Sep 1, 2022 at 12:29 PM
    Clearwater Bill
    Billy
    Largo Florida
    NJ is a small state, but many cities and a bit spread. So the city is?????????
    Bivouac likes this.
  16. Sep 1, 2022 at 12:30 PM
    Erumaren1
    2003 4x4 Tacoma
    For anyone asking for Details, I am in Clayton, New Jersey, I need the rear axle housing and Axle itself, everything else on my rear is fine
  17. Sep 1, 2022 at 12:31 PM
    Erumaren1
    2003 4x4 Tacoma
    Clayton New Jersey, its down south near Glassboro
  18. Sep 1, 2022 at 6:46 PM
    Bivouac
    Sadly to far from me!
    Just what did you buy that you can not use??
    Are you getting a labor discount to source parts?
    If your mechanic failed to notice you had a locker Might be time to rethink things unless the mechanic ate the cost since it was there fault.
    If your Truck has been down Two months why not just install a non locker axle to get up and running?
    Install a Locker axle when you can locate one.
    Since your without a vehicle.
    Aircates likes this.
