I really need help with my truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by mauibuilt41, Oct 25, 2010.
  1. Oct 25, 2010 at 3:21 PM
    mauibuilt41
    mauibuilt41 [OP] Active Member
    Maui
    02 PreRunner Dbll Cab
    Hey guys! My truck has a very bad right hand pull to it. I have done a bunch of things to it, but nothing has worked. I am really at a loss right now. Could you guys please help? Here is what I have done so far:
    1 - New tires
    2 - alignment
    3 - New Tie rods and alignment
    4 - new brake calipers and pads
    I will be changing the steering rack bushings and brake rotors in the next couple of weeks. Anything else you guys can think of?
  2. Oct 25, 2010 at 3:23 PM
    08pretaco
    08pretaco IG @14burrito
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Is your frame twisted to shit?
  3. Oct 25, 2010 at 3:25 PM
    mauibuilt41
    Maui
    Hell I hope not! Is it easy to check?
  4. Oct 25, 2010 at 3:28 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Frame is probably tweaked. What was your alignment spec after it was done?
  5. Oct 25, 2010 at 3:30 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Have you hit or done anything that would have tweaked the frame?
  6. Oct 25, 2010 at 3:31 PM
    mauibuilt41
    Maui
    Everything was perfect. They couldnt align it earlier because the tie rods were shot. So I had those changed and another alignment. After that, the alignment was all in spec.
  7. Oct 25, 2010 at 3:31 PM
    trd7
    trd7 4wd tacoma
    Tyler
    Columbia, SC
    95.5 Tacoma 4x4 4cyl auto
    AEM air intake
    you might have to take it to the dealer to get it aligned if you just took it to a local shop?
  8. Oct 25, 2010 at 3:32 PM
    mauibuilt41
    Maui
    I bought my truck used so I am not sure what the previous owner did. I sure as hell didnt hit anything.
  9. Oct 25, 2010 at 3:53 PM
    mauibuilt41
    Maui
    How do I check the frame?
  10. Oct 25, 2010 at 5:06 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Take off the bumper see if any damage, i took mine off and it was previously crashed, thats why mine pulls to the right aswell. even after aligmnent.
  11. Oct 25, 2010 at 5:10 PM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
    call up some shops and ask if they can check to see if your frame is bent. they usually dont charge for that. but dont hold me to that
  12. Oct 25, 2010 at 5:10 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma Rims, ARE Series II Lid,
    Take it to your local body shop, find out how much to put it on the frame machine that's the only true way to find out if the frame is bent or twisted.
  13. Oct 25, 2010 at 5:17 PM
    mauibuilt41
    Maui
    Alright, I'll go check with a local shop. Hopefully it isn't tweaked
  14. Oct 25, 2010 at 5:30 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Before rushing off to check the frame, did you do a lift of any kind and is the alignment shop you used experienced in doing lifted trucks.
  15. Oct 25, 2010 at 6:45 PM
    mauibuilt41
    Maui
    No lift on the truck. It is basically all stock.
    So is there nothing else besides a bent frame that could be wrong? I'm really hoping it aint the frame.
  16. Oct 25, 2010 at 9:18 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Describe the pull in more detail. For instance, when you are going down the road, coasting at say 25 mph, if you let go of the steering wheel, does the steering wheel turn on its own?
    This may be a long shot but have you checked your rear brakes? If the right one is dragging it would cause a pull to the right that wouldn't involve the steering wheel. If one rear brake is dragging, the wheel and drum on that side would be hotter to the touch compared to the other side.
    Just a thought, since you seemed to have eliminated all the front components as possible culprits.
  17. Oct 25, 2010 at 9:32 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Have someone follow you and study your tracking-is it looking like a crab running? The dragging brake is a good idea too-I got nothing else other than a possible slipped belt in a front tire-
  18. Oct 26, 2010 at 7:02 AM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    You said calipers were replaced but how about brake hoses? They could be blocked causing a pull
  19. Oct 26, 2010 at 11:09 AM
    mauibuilt41
    Maui
    No I haven't changed the brake hoses. When I let go of the sterring wheel, the wheel does turn to the right. I basically need the steering wheel cocked to the left to drive straight. If I let it go, the truck starts heading right and the wheel turns to the right. I did notice that when I brake hard, the truck seems to pull even harder. I almost feel like I have to fight it to keep it straight. Any ideas what would cause that?
  20. Oct 26, 2010 at 11:11 AM
    mauibuilt41
    Maui
    If it looks like a crab, would that be the frame?
