I recently bought a 2011 Taco with 57,000 miles. 74 year old retiree living in Mesa Az
Discussion in 'New Members' started by noelnochim, Aug 14, 2015.
  1. Aug 14, 2015 at 11:42 AM
    noelnochim
    noelnochim [OP] New Member
    2011 Tacoma
    However, when I bought the pickup, I didn't notice that the passenger side door has no keylock. To unlock the passenger side door, I have to climb in the cab, reach across and unlock the door....a real PITA. My wife and I are "Golden Agers" and almost always travel together. After every stop, we have to go through the ritual of unlocking the passenger's door.
    Is it possible to install a door handle with a keylock to replace the existing handle? If you look closely, the door handles on both sides are perfectly symmetrical and you would guess that Toyota would make the handles suitable for use on either side to reduce inventory.
    I'm guessing that I could go to a junk yard and buy a whole replacement door of'n a wreck but that seems to be pretty extreme. Does anyone care to share your thoughts on a minimal solution? Thanks eversomuchly in advance
    noelnochim
    opteron likes this.
  2. Aug 14, 2015 at 11:49 AM
    tguil
    tguil Well-Known Member
    Nebraska
    2018 Double Cab TRD Sport 4X4 AT
    Didn't you get a remote opener? Should have.
    DrFunker and magneticwhite88 like this.
  3. Aug 14, 2015 at 11:54 AM
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    Good luck OP I'm not too sure how to fix your issue... Don't forget to look over the vehicle well when buying used
  4. Aug 14, 2015 at 11:58 AM
    noelnochim
    2011 Tacoma
    The truck is not equipped with remote entry....just keyed entry on driver's side
  5. Aug 14, 2015 at 11:58 AM
    Yotamac
    Yotamac Well-Known Member Vendor
    Ze
    562- Cerritos, CA
    07 PreRunner
    Stuff, stuff and more stuff
    Welcome to TW... I'd check with the dealer if possible.
  6. Aug 14, 2015 at 11:59 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    SR5? If so, you should be able to obtain the remote and have it programmed.
  7. Aug 14, 2015 at 12:01 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    when unlocking w your key, you turn to unlock your door right?
    turn twice OR turn and hold to unlock all doors w the key.
    ..wait does this work w tacomas? i know it works on my corolla
    tcBob likes this.
  8. Aug 14, 2015 at 12:02 PM
    noelnochim
    2011 Tacoma
    Kinda late to close the horses after the barn door got out...Whooda've thunk that the door wouldn't come equipped with a keylock Betcha might've upped the cost of the new truck about $0.13 per month on the easy pay plan. You're right...hindsight, etc, etc....Thanks for taking the time to respond
  9. Aug 14, 2015 at 12:06 PM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    I didn't even know they made a model like this, once in the cab there's a unlock button on the driver side door panel near the window switches (at least in my truck) you can press that and it opens all doors and there's no need to reach/lean over
  10. Aug 14, 2015 at 12:08 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    AZBACKCOUNTRY likes this.
  11. Aug 14, 2015 at 12:20 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    That's why I asked it if was SR5 as I know there are probably base models out there without the power door locks and windows. I would say it if it is power door locks that it would have the unlock button on the driver side.
  12. Aug 14, 2015 at 2:34 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Welcome!
  13. Aug 14, 2015 at 2:57 PM
    noelnochim
    2011 Tacoma
    No such luck...the only button on the driver's inside door is the button that the opens when the key is used. It's just hard to believe that Toyota wouldn't put a keylock on the passenger side. The dealer is willing to help out...The parts guys will install a keyless entry system for $400 and change. I'm sure that I can buy a whole door at a used parts place for less than that...this just leaves a bad Toyota-ish taste in my mouth...chicken-feces-ish...thanks for your input
  14. Aug 14, 2015 at 3:02 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    $400! :eek: That's a little steep in my opinion... Then again it is the dealer.
  15. Aug 14, 2015 at 3:15 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    You can probably get a nice alarm with door lock actuators installed for $400.
