I repent lighting wired to a single switch
Discussion in 'Lighting' started by Emtmeyer, Apr 28, 2019.
  1. Apr 28, 2019 at 5:38 PM
    Emtmeyer
    Emtmeyer [OP] Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    4" maxtrac spindles, extended brake lines, custom fab bumper, sound system, 33x12 federal couragias, cibie driving lights, otrattw dash switches
    so i have revers pods, fog light pods and a 50” light bar that are all independently wired. I’m wondering what is the best way to connect all of these lights to one switch that has a flasher for emergency lighting? Any help is very much appreciated. I have all of my aftermarket lighting on an independent blue sea fuse box with relays for each and an optima yellow top.
  2. Apr 28, 2019 at 5:40 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    So you don’t want to be able to control these lights independently? Best thing would be the switch pros
    whatstcp likes this.
  3. Apr 28, 2019 at 6:18 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    I still want them to function independently however i want to be able to flip a switch and they all activate on a whelen flasher module.
  4. Apr 28, 2019 at 6:43 PM
    anthony250f
    Anthony
    San Diego, CA
    So long as they are all on relays, you could splice each trigger wire and connect that to the Whelen flasher with a separate switch to activate it.
  5. Apr 28, 2019 at 6:48 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    That’s exactly what i was thinking also but i wasn’t sure if when i active an individual if it would back power the rest of the lights.
  6. Apr 28, 2019 at 6:50 PM
    anthony250f
    Anthony
    San Diego, CA
    it shouldnt so long as the whelen flasher has its own seperate power wire, which it most likely does. In that case the lights can not flash until you turn on the switch to the whelen flasher.
  7. Apr 28, 2019 at 6:59 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    A diode on each splice would block any back signal. Think of it as a check valve for a sump pump.
  8. Apr 28, 2019 at 7:10 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    The flasher has its own power supply.
    I also was reading about the diode scenario but i don’t understand it very well. I’m looking for a good diagram with resistance and powerage.
  9. Apr 28, 2019 at 7:13 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Is it a sin to independently wire your lights??
    Tullie D likes this.
  10. Apr 28, 2019 at 7:24 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    It only takes about a hundred milliamps to activate a typical bosche style relay so a common 1 amp axial lead diode (wire on each end) should be fine, no resistors or special calculations needed. Since the flasher relay is connected to all the individual lighting circuits via the splices each splice gets a diode to prevent one switch signal backtracking to where the splices come together and propogating from there to turn on all the rest. Diodes have a line on the (-) end and should get soldered with that end towards the individual relay switch wires. That allows one way current to flow from the flasher but not the other way. All the flasher does is trip all the individual relays in synch.
  11. Apr 29, 2019 at 6:28 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Maybe he's repenting just in case. :anonymous:
    Hobbs[QUOTED] likes this.
  12. Apr 29, 2019 at 9:09 AM
    Hobbs
    Yep…
    Trying to cover his bases, I suppose.
