I reset the ecu by disconnecting the battery...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2004tacoprerunner, Jun 22, 2012.
  1. Jun 22, 2012 at 4:55 AM
    2004tacoprerunner
    2004tacoprerunner [OP] Well-Known Member
    byron, mn
    2004tacoprerunner
    This should be in the 1st Gen forum. See what happens when you can,t sleep.
    After I seafoamed the engine, I changed the plugs(I think they might have been original)after 100k on them and cleaned the throttle body. I got my oem plugs at the Toyota dealership.
    It at first ran like ass but after about a100 miles of driving it runs really good again. It went from no guts and late shifting to normal shifts again and smooth running engine. I don't know if the sea foam did much but the plugs and throttle body cleaning seemed to help tremendously. I didn't toss any seafoam in the oil just gas and carefully in the brake booster vacuum line.
    Saw a little smoke but nothing like the videos on the internets. I put the sea foam in when it was a quarter full waited till my low gas light came on and filled it with 89 octane.
  2. Jun 22, 2012 at 5:08 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    All that before breakfast?!
  3. Jun 22, 2012 at 7:07 AM
    2004tacoprerunner
    byron, mn
    2004tacoprerunner
    Sort of. Imnsonia keeps you busy
  4. Jun 22, 2012 at 7:12 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Are you asking a question or just telling us you learned something new? :D
  5. Jun 22, 2012 at 7:15 AM
    2004tacoprerunner
    byron, mn
    2004tacoprerunner
    Learned something new and tired now.
    And I built these last night cause I was bored.
