I scratched my taco!!! Need help!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by linkfeeney, Feb 22, 2009.
  1. Feb 22, 2009 at 4:12 PM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    aberdeen, nj
    09 Doublecab TRD Off-Road! Magnetic Grey!
    i was putting my snowboard in the bed and i hit my truck by accident with the board and I can see a little bit of metal!!
    any suggestion on what to do to get on some scratch removal?!?!?
    the best shit please!!
    I'm so mad at myself!!!
  2. Feb 22, 2009 at 4:25 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    get some primer(if it is really bad) then take a paint OEM pen or spray can, mask the part off. and you should be good as new.
    http://OEMpaints.com
  3. Feb 22, 2009 at 4:37 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    If the scratch is down to the metal I don't think a scratch remover will help much. Go to your dealer and get some touch up paint. The touchup paint is going to leave an un-even blob. I used this to finish up the job. It's about the best you can do short of having the areas spot painted.
    www.langka.com
  4. Feb 22, 2009 at 4:41 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    always stealin' my lines.. :laugh:
  5. Feb 22, 2009 at 4:52 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Its bound to happen sooner or later. Just scratch (no pun intended) as 1 battle wound out of many. :D
  6. Feb 22, 2009 at 6:01 PM
    linkfeeney
    link the stink!
    aberdeen, nj
    I didn't want to go with the touch up paint but I might have too...
    any scratch removal can help at all or waste of my money??
  7. Feb 22, 2009 at 6:33 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    If you are seeing metal, there is no paint left in the scratch - your only options are touch up the scratch or repaint the entire panel.
    Good luck
  8. Feb 22, 2009 at 6:34 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    If you're down to the metal, gonna need touchup or a repaint.
    Marc M
  9. Feb 22, 2009 at 6:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the way you do it is to put it on layer at a time,.......drying between each coating, then when its even.......buff it with a polish....it'll blend pretty well.
  10. Feb 23, 2009 at 3:16 AM
    linkfeeney
    link the stink!
    aberdeen, nj
    man Im so pissed at myself!!! i hurt my BEAUTIFUL TRUCK!!!
    I really dont want touch up because of the BLOB is going to annoy me too... I guess I'll stop by at a pep boys today during my lunch to see options.
  11. Feb 23, 2009 at 6:16 AM
    CRFan1
    CRFan1 Well-Known Member
    Northwest Indiana
    Tacoma Pre-Runner
    DNX5120, Audsion AMp, Hertz Speakers
    LOL...it"s a truck...it's gonna end up with a scratch every now and than :D
  12. Feb 23, 2009 at 6:32 AM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    Sorry to hear that happened, hope snowboarding was fun :thumbsup:
    My truck goes in tomorrow for a fix down to the metal scrape from a hit & run. If the paint wasn't chipping off or down to the metal & wouldn't even had bothered since its on the passenger side & I don't see it. :p
    The first one is always the worst.....best of luck with the fix.
  13. Feb 23, 2009 at 6:34 AM
    freesample
    freesample Well-Known Member
    Newfoundland, Canada
    09 Tacoma Double Cab TRD Sport LB
    Visors, Deflector, Husky Liners, too expsensive for good ones :(
    got a pic fo this scratch?
  14. Feb 23, 2009 at 5:01 PM
    lasllc
    lasllc Well-Known Member
    SW Denver Burb
    13 SuperWhite DCSB Sport 4X4 Tow Pack
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    Most every one has said the obvious: if it is indeed down to the metal, scratch remover wont do it - scratch remover is not a ding remover it is simply a very mild rubbing compound in liquid form.
    You need to fill the scratch which is several mills deep; primer one or two coats (after cleaning with alcohaul or Prep-Sol; then another cleaning then start to layer on the touch up paint. It will leave a bump, but go to a professional auto paint supply store and get a small paint shaver (it is a samll tool with a razor in it) to shave the bump down; then starting with around 1000 grit wet/dry paper, wet sand lightly untill you are using 1500 or so paper; Then use a very light polishing compund to blend in the repair with the surrounding area; Then wax and polish.
    From the sounds of the posts on this forum, some folks, certainly not all, dont think enough of their rides to go to this much trouble- if it is lifted and makes a nice sound that is close enough. But it is the detail work that tells everyone what kind of mechanic you really are and just how nice that truck actually is underneath.
    Just my opinion of course, some of us are a bit more anal then others.
  15. Feb 23, 2009 at 5:06 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    if you go put an even bigger scratch in it or maybe a dent i bet you'll forget all about this scratch.
  16. Feb 23, 2009 at 5:13 PM
    Hardcorehehaw
    Hardcorehehaw 1 man wolf pack
    Evan
    09 Magnetic Gray PreRunner
    Debadged, 20" Liquid Metal Magmas, Yokohama Parada Spec x 285/50/20, Llumar clear bra, Fold-A-Cover G4, Weathertech liners, Wet Okole seat covers, JBS technologies keyless entry keypad.
    Get a touch up pen/brush. Clean the area well, take a toothpick and dip it in the paint so that you're left with a small drop of paint on the end then apply to the scratch. If you take your time and go slow you won't be left with a big blob of paint.
  17. Feb 23, 2009 at 5:17 PM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    many small coats of paint will fill it in. i did that on a couple scratches on a dark car before and it worked well. use a toothpick like the guy above me suggested.
  18. Feb 25, 2009 at 3:42 PM
    linkfeeney
    link the stink!
    aberdeen, nj
    does toyota have color code for the color? when i had my nissan that's i had to do.
    maybe I should call up the part dept to see if they have it in stock,
  19. Feb 25, 2009 at 4:04 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    toyota does offer touch up paint, but the thing is that alot of the colors that come with our trucks have that metallic glitter crap in it, the touch up doesnt have the metallic, its a solid color
  20. Feb 25, 2009 at 4:16 PM
    steviestyles
    Colorado Springs
    Bone Stock
    It should be on the driver side door jam information label. It should be a 3 digit alpha-numeric code.
