I searched for 2 days...Vibration fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ken Dawg, Dec 2, 2016.
Fix it or torch it?
  1. Fix
    62.5%
  2. Torch
    37.5%
  1. Dec 2, 2016 at 8:02 AM
    Ken Dawg
    Ken Dawg [OP] Well-Known Member
    EAST COAST
    08 Prerunner TRD Sport LB
    Tranny rebuilt 12/2016 at 142,500 Pioneer deh-p400ub head unit Alpine spr-69c fronts Alpine 17c rears. Rockford Fosgate 4 channel amp JL sub behind seat Upper console solder fix Recall: Rear leaf's 12/2016 To Do List: JVC KW-V820BT with Backup cam Zelwig Helper Spring Clazzio Dark Gray seat covers /heat Viper alarm w/ Starter Then drive to 250,000 miles!
    Hi.
    2008 Tacoma TRD Sport 2wd DBL Cab Auto 1st owner 142,000 mi
    I have HOURS looking into someone, anyone who had this fixed via TSB hammer etc.
    I have Bilsteins all around...(fronts up 1st setting)
    Rear Leaf TSB and now recall 4 leaf kits
    So maybe 1/2" or so over stock height.
    Stock size tires.
    The vibration has gotten worse at 28 mph.(been a vibe since bought new) Last 3-4k miles I get when under light load at 38mph or so a vibration similar to the feel of safety grooves on the side of an Interstate highway. (perfect description)
    Left dealer when they could not duplicate yesterday. Turned around and asked for tech to come with me for ride. His eyes bugged out when I got the vibration at 28 then at 38mph.
    He initially thought it was tranny but its been ruled out.
    I have a case opened with Corporate and will get $some help$ from them.
    The Rear engine mount and Carrier bolt are not loose per visual inspection by tech. (head tech fwiw)
    Is it possible that the rubber in Rear engine mount or CB (both?) has gotten brittle and causing this?
    Could the Old Man Emu Drop kit be answer?
    Could a 5 gal can of gas and a match be the fix?
    I dont post here much as I learn way more than I could contribute.
    If anyone can help here I'd once again appreciate it!
    Thanks- Dawg
  2. Dec 2, 2016 at 8:08 AM
    tacoshin
    tacoshin Well-Known Member
    Brian
    the name of my truck, WA
    2008 Lexus IS250 AWD/2014 Tacoma SR5 4x4 short bed
    Smittybilt step bars, Toyota skid plate, All Pro bed rack w/ tonno pro retrofitted thanks to pushingcasket for helping, trd exhaust 14019 miles
    possible humming?? maybe wheel bearing or weak needle bearing. get the clamshell from east coast gear supply and replace the old needle that should help. I have the same issue on my truck got the OME lift and had it on for 6000 miles and already making vibes, and its louder since its cold weather. I haven't installed it yet but from other peoples experience they said the sound and vibe went away
  3. Dec 2, 2016 at 8:11 AM
    Ken Dawg
    EAST COAST
    I thought wheel bearing but...not!
    What is clam shell?
    Thanks for reply!!!
  4. Dec 2, 2016 at 8:15 AM
    tacoshin
    Brian
    if you goto east coast gear supply site they have a clamshell its a steel round tube thing with Teflon on the outer side and its suppose to handle your side load on your truck with lift on it. I went to the stealer ship they couldn't replicate either. also check your cv axle by pushing up and if it moves up then possible you need that clamshell
  5. Dec 2, 2016 at 8:20 AM
    Ken Dawg
    EAST COAST
    that is for 4wheel drive
  6. Dec 2, 2016 at 8:23 AM
    tacoshin
    Brian
    oh snap didn't know that it was only for a 4x4 I thought it was for both
  7. Dec 2, 2016 at 8:24 AM
    tacoshin
    Brian
    I would email them and see if it will work on a 2wd
  8. Dec 2, 2016 at 8:25 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    U joints maybe, or rear diff? Do your u joints have grease zerks? I'm not sure if 08 Sport had them or not.
  9. Dec 2, 2016 at 8:26 AM
    tacoshin
    Brian
    I haven't messed with it since I got it, like grease it up. I did the lift and since then had the vibes and diff growl so everything I read on TW leads to the bushing and its only on the driver side
  10. Dec 2, 2016 at 8:48 AM
    Ken Dawg
    EAST COAST
    Not sure...will check it out
    I have no problem throwing cash at this truck but throwing PARTS at it isn't what I want to do.
    Rear differential is a maybe!!
    Tacoshin: No worries, I love the help and thought process
    I called and its 4x4 only
  11. Dec 2, 2016 at 8:52 AM
    tacoshin
    Brian
    @Ken Dawg bummer bro well hopefully its just the wheel bearing and that can get replaced quick but good luck brother hopefully you get it fixed as I should with mines.
  12. Dec 2, 2016 at 8:53 AM
    TACO TX
    Kelly
    Denison ,Texas
    If you have zerks be sure and give them a shot of grease and see if that helps it. Good luck and I hope it's nothing major.
    tacoshin likes this.
  13. Dec 2, 2016 at 9:18 AM
    Ken Dawg
    EAST COAST
    Thanks
    Zerks is on list
    Stumbled on a couple of "rumble strip" sound posts for Tacoma's and Tundra's
    Rear wheel bearings(not it) and different differential issues appear so far...
    I have time to read so....
    Thanks
  14. Dec 2, 2016 at 9:58 AM
    Ken Dawg
    EAST COAST
  15. Dec 2, 2016 at 10:13 AM
    doorsidedown
    doorsidedown Well-Known Member
    There are a million different scenarios that cause and fix vibes. What fixed mine, after I lifted it, was a street tacos carrier bearing drop and 3 degree axle shims under my leafs.
  16. Dec 2, 2016 at 10:17 AM
    Ken Dawg
    EAST COAST
  17. Dec 2, 2016 at 12:28 PM
    Ken Dawg
    EAST COAST
    boom! transmission rebuild
    TORCH LOL
  18. Dec 2, 2016 at 1:12 PM
    Ken Dawg
    EAST COAST
    ok....
    fix or trade in? Own it outright... trades look like $12,500
    I'd prefer a 4x4 at this juncture in life. F150 XLT Crew with 5.0?
    Input or opinions please?
  19. Dec 2, 2016 at 1:18 PM
    tacoshin
    Brian
    how about trading It in for a 4x4 Tacoma unless you don't want another taco, f150 is big ass truck, anyhow bruddah I would say keep it but if you are gonna change trucks that's your call bro. but I hope whatever decision you make is the right one for you. ( im not writing this in a bad way) im just saying its really up to you, cause im in the same boat as well thinking of selling my truck and get a SUV. so yeah im just in the thinking mode.
  20. Dec 2, 2016 at 1:28 PM
    Ken Dawg
    EAST COAST
    drop $2500 in.... 2008 truck with no payments
    vs.
    sell and drop $12,000-15,000 down on new truck with warranty, 4x4 and payments.
    New Tacoma TRD Sport 4x4 is $35-37k?
    SUV? have kids?
    My use is now in Connecticut so snow and 1,200 mile trailer trips.
