I spent about half the day with a Toyota Engineer who designed 2nd gen! How was your day? :)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jboudreaux1965, Dec 5, 2016.
  1. Dec 5, 2016 at 8:18 PM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Life is crazy, you never know from day to day who you will meet. At about 10:00 this morning I met one of the Toyota engineers that worked on the design for the 2nd gen Tacomas. He started out as a design engineer for Porche and when he left Germany he started working for Toyota. He actually built and designed his own 911. He was part of the original design team for the 1st gen Tundras. He said, basically, the Tundra project was a last minute attempt to compete with the US full size truck market. There target was to compete with the Ford F150. They deemed the F150 as owning the largest portion of the market that they could compete with. They were given hardly anytime to get it into production. As we all know the Tundra did not turn out that way. When Toyota (internally) announced the the Tundra was basically a complete failure he joined the Tacoma design team working with TRD in early 2000's until he retired in 2007.
    I spent about 4 hours with him talking! LOL, I could tell he REALLY loved his job! The conversation started when I mentioned my head gaskets... and his eyes perked up and questions and answers and comments and conversation just started rapidly coming.
    Like we all suspected the head gasket design flaw was discovered by Toyota and it is a recognized problem. He also said that only manufacturer owned dealerships actually did the replacement as a 'semi-recall' of sorts and since there are only a few in the US we got screwed. Franchise owned/privately owned dealerships were not authorized to do the replacement under a 'recall' basis. He also mentioned that if there are any left in the US, a manufacturer owned dealership will honor most TSB repairs as a 'recall' repair if you complain enough to the service dept. But he was not sure if there were any left in the US. If anyone discovers one, please post!!!!
    I showed him the lab results from Blackstone, he saw the potassium levels... immediately asked if the dealership machine the block and the heads. I said yes they machines the heads. He asked about the block? I said no. He said with these levels there are most likely fishers in the block that is where your coolant is leaking in. You have to machine the block also are it wont be perfect. He also admitted because the release date for the 2nd gen was supposed to be in Sept. 2004 and they were way behind schedule pressure was put on them to start production.
    I also told him that after the head gaskets were replaced I had the dealership do pressure testing. He said those test are useless with this problem. The proper Toyota test is way more involved and he went into details that I honestly don't understand, but basically, a tech sits there all day with it running with something hooked up monitor specs. I am for sure going to get more details and write it all down before I go back and complain about work done to my truck!
    Some more interesting fun facts...
    TRD did design a twin turbo for the 4.0 TRD ONLY 4.0 engines for the 2ng gen. Tacomas. In tests it performed extremely well! He said they are even a few test production trucks roaming around Japan. The reason they scrapped the turbo was because the cost to the consumer would have been at least double that of the supercharger and the powers that be in Toyota decided the price would be too high for the American market!
    To elaborate on this comment above... "4.0 TRD ONLY 4.0 engines" ... TRD designed 2nd gen. Tacoma 4.0 engine blocks are in fact slightly different than the none TRD blocks from the factory. Also the OEM pistons and several other internal parts are different than non-TRD 4.0's when shipped from the factory. The differences are at the micrometer level in order to create extremely high tolerances vs the none TRD 4.0 engines. So parts are technically interchangeable and unless. I forgot to ask how you get OEM TRD parts, next time I talk to him I will.
    As far as tuning to gain horsepower... On a TRD 4.0 in the 2nd gens there is not much you can do. TRD pushed the limits on tolerances on the internals, a better air intake is about all you can do and that gain is minimal. Slight mods to exhaust yield VERY VERY minor increases in HP in rare cases. Major mods to exhaust usually have a negative effect.
    ECU programming... not a good idea. On TRD editions they pretty much tuned it to peak.
    There was so much to digest and so much I am probably forgetting, but I had to share. He is actually one of my customers now so we will be talking on a regular basis.
    How cool is that :) Today was a good day! :)
  2. Dec 5, 2016 at 8:22 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sweet jesus
    Midnighttaco08 likes this.
  3. Dec 5, 2016 at 8:23 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    My day was alright. Trying to figure out what to gif next.
    igno1tus, SC2SC, AR15xAR10 and 12 others like this.
  4. Dec 5, 2016 at 8:24 PM
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    Wow... impressive.
    Definite sub for more random facts :taco:
  5. Dec 5, 2016 at 8:31 PM
    JTD408
    JTD408 Well-Known Member
    Santa Clara
    2015 DCSB 4x4 TRD Sport
    Icon stage 3 SCS stealth 8's Clazzio sear covers Weathertech floor loners Redline hood struts
    my day was shit but this post is legit
  6. Dec 5, 2016 at 8:40 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Oh, another fun fact. He said they tested just about ever type of engine oil on the 4.0 engines. AmSol performed the best. Under test, after running each oil under normal conditions for extended periods of time they would run lab tests periodically. Then after a certain length of time they would completely drain the engines of oil and let them run until they seized. Amsol test engines took over 8 hours to seize. I USED to use Mobil1, LOL!
    Rambo54, HandOfGod, PzTank and 8 others like this.
  7. Dec 5, 2016 at 8:43 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Impressive..........memory you have there.
    brysonallenn6 and DustStorm4x4 like this.
  8. Dec 5, 2016 at 8:45 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Feels kinda sticky in here. Nice.
  9. Dec 5, 2016 at 8:50 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    Wow, that's awesome, subbed!!
  10. Dec 5, 2016 at 8:53 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Performance wise, there is plenty you can do. Trust me. ;)
  11. Dec 5, 2016 at 8:56 PM
    Mossyjaws
    Mossyjaws Well-Known Member
    VA
    2015 dclb
    Footprint Gas Pedal
    o_O Soooo....the trd 4.0 is a different engine than a base model.
  12. Dec 5, 2016 at 8:59 PM
    FlyByNight
    FlyByNight Well-Known Member
    Patrick
    WA
    2015 Black Tacoma TRD OR DCSB
    That's super cool! That guy probably knows a metric f*ck ton of stuff about these rigs that you'd never be able to find out online.
  13. Dec 5, 2016 at 8:59 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    basically... yes. Parts are interchangeable and the engine will run, but tolerances on TRD parts are higher, so using non TRD internals will affect total performance.
  14. Dec 5, 2016 at 9:02 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I don't want to badger him. But, if we can compile some specific questions I can ask him. :)
    PzTank, Tsinajinii and Markcal like this.
  15. Dec 5, 2016 at 9:05 PM
    Markcal
    Markcal Well-Known Member
    Just curious, what you do for work to meet him?
  16. Dec 5, 2016 at 9:06 PM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
  17. Dec 5, 2016 at 9:10 PM
    Taco de Carnista
    Taco de Carnista Well-Known Member
    michigan
    2005 TRD OFF ROAD
    keep it coming, keep digging his brain.
    Markcal likes this.
  18. Dec 5, 2016 at 9:10 PM
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    Damn
    Thanks for sharing.
    How'd you discover he worked for Toyota?
  19. Dec 5, 2016 at 9:12 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    Now that's what I'm talking about :bananadance:
    Benzdriver81[QUOTED] likes this.
  20. Dec 5, 2016 at 9:12 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Ask him why the Fuck I've only got a two speed wiper? My 75 ford was two speed and no change for 2012. Other than that it's pretty cool you got to talk to him.
