I Spilled Motor Oil
Discussion in 'Off-Topic Discussion' started by dysfunctnlretard, Feb 19, 2010.
  1. Feb 19, 2010 at 10:56 AM
    dysfunctnlretard
    dysfunctnlretard [OP] Hi
    Manny
    CA
    2021 Jeep Rubicon
    All Over my bed. I didnt close my drain pan properly and it spilled all over. Any ideas on how to remove it? I tried liquid laundry detergent, degreaser, and powerwashing, none work. I have a rubber bed mat and thats the main location of the spill.
  2. Feb 19, 2010 at 10:57 AM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
  3. Feb 19, 2010 at 10:58 AM
    doug355r
    doug355r Well-Known Member
    Phoenix, AZ
    2017 Tacoma TRD Sport
    2.5" Lift with King shocks and TC UC, 4.88 gears, ARB compressor, ARB lockers, S POD, cheap lights
    cat litter to soak most of it up, then brush off or vacuum up. then wash the rest. Also Carb cleaner works.
  4. Feb 19, 2010 at 11:03 AM
    bigburrito
    bigburrito Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    im kind of wondering what the potential for damage is on these composite beds. oil and carb cleaner sound like they might could harm the plastic?
    ive got my drain pan full of oil sitting in the back of my truck as well, waiting to get recycled. hope mine doesnt spill, that sounds like a nasty mess
  5. Feb 19, 2010 at 11:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    Don't cry over it..........oh wait...........that's spilled milk.
    The Walmart brand is just as effective only cheaper.
  6. Feb 19, 2010 at 11:07 AM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Wow. Ouch!!!
  7. Feb 19, 2010 at 11:23 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    That sucks...
    Try this:
    1. Put down some baking soda on the oil stain.
    2. Put a piece of cardboard on top of the baking soda.
    3. stack something on top of the card board to apply pressure.
    4. Wait a few hours, overnight would be good.
    Repeat as necessary.
  8. Feb 19, 2010 at 11:26 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    Thats why you should just dump the oil in the backyard.:D
  9. Feb 19, 2010 at 11:27 AM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    car wash engine degreeser let it set for a bit then pressure wash it out
  10. Feb 19, 2010 at 11:35 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    off topic but omg your trucks sexy!
    engine bright cleans off oil well as does brake klean
  11. Feb 19, 2010 at 11:40 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Better get that cleaned up or your bed will start to rust! :anonymous:
    Use Simple Green. Non-toxic and that stuff cleans everything.
  12. Feb 19, 2010 at 11:42 AM
    yotabeast505
    David
    NE Hights ABQ NM
    THE BEAST
    off topic but thanks check out my build let me know what you think
  13. Feb 19, 2010 at 12:30 PM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    thanks for the responses people. Ill have to grab a couple of these items and try them out tonight. Thanks again
  14. Feb 20, 2010 at 11:59 AM
    doug355r
    Phoenix, AZ
    any luck?
  15. Feb 20, 2010 at 1:56 PM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2016 4Runner
    Dawn dish washing soap
  16. Feb 20, 2010 at 1:59 PM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    It was dark lAst night so I couldn't see the results but I out cat litter all over the bed and let it sit while I was at work (5hours). When i got off, I swept it up and power washed the bed at a local self service car wash. Then I poured about 60oz of simple green in the bed and scrubbed with a wire brush and rinsed. I've yet to see the results but will keep you guys posted.
  17. Feb 20, 2010 at 2:09 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    i think its a write off :/
  18. Feb 20, 2010 at 2:16 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Just set your truck on fire...that'll clean it up nicely :laugh:
    j/k
    Try Carb Cleaner bud :notsure:
  19. Feb 20, 2010 at 2:31 PM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    Most of it's gone. Some spots remain where I missed scrubbing last night. So the verdict: sufficient simple green and a wire brush will remove motor oil from our composite beds and rubber bed mats. Thanks again guys.
  20. Feb 20, 2010 at 2:32 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    +1
