I stripped one of my bed bolts....help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcliff, Apr 14, 2010.
  1. Apr 14, 2010 at 7:11 PM
    bcliff
    bcliff [OP] Well-Known Member
    Massachusetts
    07 TRD Offroad DCSB
    leaf TSB, added D-Rings, bed mat, weathertechs
    well, I did it good this time. While doing the d-ring mod, I stripped out one of the T55 bed bolts. Do any of you have a suggestion for getting this thing out? I'll need to get a replacement bolt from the dealer but have no clue how to remove the damaged one.
    jonnytacoo likes this.
  2. Apr 14, 2010 at 8:00 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Removing broken bolts is a pain in the ass.
    You need to pick up a screw extractor, many are called easy outs although it is seldom easy, you can pick them up at most hardware stores and you need the correct size drill bit to go along with it.
    You drill a hole as close to the center of the bolt and insert the extractor into it and then as you turn it left the threads will bite into the bolt and hopefully back the bolt out.
    This is the best style I have found, you need a smaller one but this pic came up in the search to show you.
  3. Apr 14, 2010 at 8:10 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Dealer replacement bolt = $12.00. Ask me how I know this...
    wilcam47 likes this.
  4. Apr 14, 2010 at 8:21 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    :facepalm: How did you do that?
    Thread it back in with Loctite.
  5. Apr 14, 2010 at 8:23 PM
    atebit
    atebit What's all this, then?
    The basement of the Alamo
    18 Inferno TRD OR 4x4 AC
    When you say "stripped", do you mean you rounded off the head, or did you cross-thread the bolt?
    If you rounded off the head, the screw extractor will work. Otherwise...
    jonnytacoo and theredofshaw like this.
  6. Apr 14, 2010 at 8:45 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    In my case, genius that I am, it was cross threaded via using air tools. Derr... However, usually when someone says they "stripped" the bolt, they mean rounded off the head.
    Gosh, that sounds weird...
  7. Apr 14, 2010 at 8:50 PM
    Series1000
    Series1000 Well-Known Member
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    Lots
    How do you know this?:D
    winkel likes this.
  8. Apr 14, 2010 at 9:00 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^See above, lol
  9. Apr 15, 2010 at 7:00 AM
    bcliff
    Massachusetts
    07 TRD Offroad DCSB
    yes, rounded off the head. The "star" shape of the T55 bolt head now looks like a freakin circle. I hate it when I'm a shithead.
    OK...I'll try the screw extractor.
  10. Apr 15, 2010 at 7:05 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I have learned that lesson once before. I always hand thread all bolts before using air tools on them to make sure I don't cross-thread.
    Ezriderga likes this.
  11. Apr 15, 2010 at 7:10 AM
    Gringo
    Gringo Active Member
    MA
    '10 2wd AC SR5
    HID's, extra D-rings
    Or if you have a Dremel tool with a cutting wheel, you can cut a big slot across the top and use a big flat-bladed screwdriver
  12. Apr 15, 2010 at 7:15 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    ^ was just going to recommend that. It is usually the easiest way. Be sure to cut a wide enough slot for your screwdriver but not too wide that it will be loose.
    I never have luck with the extractor bolts. I'm probably not using them correctly but I can never get them to grip.
    If all else fails, use a dremel and flatten out the sides of the bolt in a hex patter. Then grab the closest fitting socket and wrench it out.
    AND NEVER USE AIR TOOLS ON STUFF LIKE THIS!
  13. Apr 15, 2010 at 7:23 AM
    macgyver
    Brad
    Canton, GA
    Yep, Then just get a sacrificial socket and pound that bitch on there with a hammer.
  14. Apr 15, 2010 at 7:38 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I would try first to drill it with a small bit then repeat it with a large screw extractor bit.($7 at home depot)
  15. Apr 15, 2010 at 8:14 AM
    Beach Croc
    Beach Croc Member
    Virginia Beach
    Debadged 4x4 TRD On Road
    Truxedo LoPro Tonneau. Home made bedslide. Removed rear seats & added homemade carpeted 60/40 shelf.
    If the torx head is what is stripped, then if the head of the fastener is high enough, I'd try using vice grips like one would use a jar opener.
    Make sure you are able to get a good hold on the head of the fastener and then just unscrew.
    boston23 likes this.
  16. Apr 15, 2010 at 8:21 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You can also try pounding a robertson ( square drive ) bit into the head of the bolt prior to trying the extractor , because the square drive only has to cut a square out of the hole , I've had pretty good luck with it , just try to match the square drive size to just cut the corners into the hole ,
    best of luck ,
    OZ
  17. Apr 19, 2010 at 1:56 PM
    bcliff
    Massachusetts
    07 TRD Offroad DCSB
    update...the bolt extractor didn't work even after heating up the bolt with a torch. I'm considering buying a dremel and cutting wheel so I can grind a slot in the head but to be honest, I've never had a need for a dremel and am not sure it makes sense to buy one just to get this bolt out. All this so I can add another d-ring that I'll seldom use! ugh.
  18. Apr 19, 2010 at 2:10 PM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    2016 SR5
    Get a dremel. You'll immediately start coming up with reasons you can use it.
    winkel, Ezriderga and CroResident like this.
  19. Apr 19, 2010 at 2:14 PM
    bcliff
    Massachusetts
    07 TRD Offroad DCSB
    do you recommend rotary or oscillating? Any particular brands or models? I'm always happy to add new tools to my workshop!
  20. Apr 19, 2010 at 2:19 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I used a bigger allen wrench, I hammered it in there and the applied force while turning to get it out.
    I'd do the dremel route personally....lol I'd be an excuse to buy another tool
    DEMikey likes this.
