I stripped one of my bed bolts....help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcliff, Apr 14, 2010.
  1. Apr 19, 2010 at 2:36 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    If you rounded the head with a torx bit and couldn't get it out, then a screw extractor and heat on the bolt still couldn't turn it, do you guys really think that cutting a slot into it and using a flat top screwdriver will remove it?
    Weld a nut on the top of the bolt and be done with it. Replace with a new one and chalk it up as a learning experience.
    Philrab, gugman and asuchemist like this.
  2. Apr 19, 2010 at 2:52 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    best advice yet^^
    and if that cant be done id use the dremel method, but since the torx head is bigger than most flat blades i would cut a slot in one side and hammer the end of a big flat blade into it on an angle where it would back out the bolt. or maybe some channel locks on the head and try it that way
  3. Apr 19, 2010 at 3:05 PM
    BH15001
    BH15001 Well-Known Member
    SW PA
    09 Tacoma DC LB SR5
    Grab it with vice grips and turn it out.
  4. Apr 19, 2010 at 3:08 PM
    beetlejuice2275
    beetlejuice2275 Well-Known Member
    Reximus
    Queens, NY
    Drift inspired 08 Reg Cab
    custom ram air. blacked badges, hids, rewired front turn signals and park lights, URD short shifter, Pioneer t-screen (no nav), 10" 1200 watt.
    YOU NEED A NEW TRuCK!
    jon_elc and bluezzy like this.
  5. Apr 19, 2010 at 3:10 PM
    Cars0n`
    Carson
    Alberta
    03 2.7L 4x4 5spd
    x2, i wonder if theres a tsb for this??
  6. Apr 19, 2010 at 3:12 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Drill it!!! Start with small bit and work your way up. Then knock the head off.
  7. Apr 19, 2010 at 3:13 PM
    beetlejuice2275
    Reximus
    Queens, NY
    Take it to the dealer!
  8. Apr 19, 2010 at 3:15 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    weld a bolt or a socket and then take the screw out with a ratchet or air gun. $5 dollar cheapo socket will do the trick,
  9. Apr 19, 2010 at 4:41 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Be carefull welding a nut on it.
    Not sure how much heat the composite bed can take.
    GPsevinSixx likes this.
  10. Apr 19, 2010 at 4:53 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    x2 on getting a dremel, I didn't really know what I would need one for when I got one, but it has been one of the handiest tools for working on vehicles, those little cutoff wheels have come in real handy many times. I have gotten many a stuck bolt or nut removed when nothing else would work.
  11. Apr 19, 2010 at 8:15 PM
    ChaseUA
    ChaseUA Well-Known Member
    Chase
    Bama
    Present: 2016 White TRD Sport DC Past: 2010 MGM TRD Sport AC 4x4
    OK, this may sound crazy, but I've done this before with luck. You'll still need a replacement bolt (duh).
    Take an old screwdriver/torx driver that you don't mind damaging (though you should be able to clean it back up fairly easily if you are patient), put a dab of JB Weld or something similar on the damaged bolt and place the head of the screwdriver in place, when the JB Weld (or similar product) sets you should be able to have enough of a grip to wind the bolt (or screw) back out.
    Edited to add:
    As I've had problems with this in the past I've found the easiest solution is anytime a screw/bolt is giving you trouble spray it with "PB Blaster" and then place a little "Valve Grinding Compound" on the tip of your screwdriver and the job will get a lot easier.
    econwatch likes this.
  12. Apr 19, 2010 at 8:21 PM
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA/Tucson AZ
    2018 TRD PRO
    Wescott lift Wescott rock sliders Prinsu Cabrack SpartanXcustoms skewp light Demon Hook front recovery point Diamondback SD (just shipped) N2 Designs Remote Start A few meso goodies
    Both! but rotary for this particular job
  13. Mar 19, 2017 at 2:41 PM
    Buffdeez
    Buffdeez Well-Known Member
    Hamilton, Ontario, Canada
    2008 DCLB SPORT
    Old Thread, New Info.
    Stripped mine doing Bedside reinforcement bracket install.
    Got them out with pipe wrench
    Tougher you pull, more it bites.
    worked like a charm.
    Trip to the dealership for replacement ones. Corroded to hell
    Cheers
    Rick's 2012, TinyTech626 and socataco like this.
  14. Mar 19, 2017 at 5:19 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    quoting this to help me remember just in case :thumbsup:
  15. Apr 26, 2017 at 3:51 PM
    #35
    TinyTech626
    TinyTech626 reverses st. signs & steals everyone's left shoe
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    Well I don't feel like as much of an ass now... Going to try a pipe wrench after I grab replacement bolts.
  16. Apr 26, 2017 at 3:54 PM
    #36
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    take a chisel hammer it in there and try turning the chisel with vice grips. Make sure to torque that sucker down when you cross thread it on the way back in. Makes for a good security device.
  17. Apr 26, 2017 at 4:14 PM
    #37
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Or a small proper sized file to make the slot. Then go with the screwdriver.
  18. Apr 26, 2017 at 4:33 PM
    #38
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    You put a nut on top of the bolt that has a hole the same size as the top of the stripped bolt,and then weld in the hole with a welder,then you just use a a socket that fits the nut and presto the bolt will come out.
  19. Apr 26, 2017 at 5:53 PM
    #39
    tacojefe
    tacojefe Well-Known Member
    Eric
    Western Maine
    2012 Tacoma
    You can reach the front one's from underneath, it's a bitch but put a sharp (new) vicegrips on the unthreaded part. Much easier to just tack a 3/4" nut on the top.
  20. Apr 27, 2017 at 3:26 AM
    #40
    topcathr
    topcathr Well-Known Member
    2015 limited
    go to a shop and plug weld a nut on the top of the bolt....
    Jcyr likes this.
