I stumbled upon this torque/filter/spec info. for the 2005+ Tacoma...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by P. Bauer, Nov 25, 2008.
  1. Nov 25, 2008 at 6:06 AM
    P. Bauer
    P. Bauer [OP] Well-Known Member
    San Jose
    08 Tacoma 4x4 TRD Off-Road
    TRD S/C :: Intake Camburg SwayAway Magnaflow American Racing Donahoe Racing Wheelers OffRoad
    Formatting is terrible, I just copied and pasted....
    This information is ONLY TO BE USED AS A GUIDE. Always consult your manual for further information. LUBRICATION Date Mileage Detail Cost Chassis Lubrication 2WD Fittings, 0 Plugs 4WD Fittings, 0 Plugs ** Synthetic multi-purpose grease NLGI #2 Clutch Fluid SAE J1703 or FMVSS No.116 DOT 3 Front Drive Shaft Thrust Bushings NLGI #1 Propeller Shaft - Spiders NLGI #2 - Slide Yokes NLGI #2 ** Synthetic multi-purpose grease TIRE PRESSURE ** Proper Tire Pressure Is Printed On Sticker ** ** Located On/Near Drivers Door Jab
    ** TORQUES Differential Front Drain Plug ft-lbs Fill Plug ft-lbs Differential Rear Fill Plug ft-lbs Manual Transmission Drain Plug ft-lbs Fill Plug 27 ft-lbs Spark Plug Gap Specifications 1.0 - 1.1mm (0.0394 - 0.0433in) Oil Drain Plug 30 ft-lbs Wheel Lug Nut 85 ft-lbs Page 2 Expendables Air Filter Toyota 2.7L 17801-0C040 Toyota 4.0L 17801-0P010 Fram 4.0L CA9683 K&N 4.0L 33-2281 AmsOil 4.0L 46888 Cabin Air Filter Toyota 88508-01010 micronair.us ( Pontiac Vibe) TY02116P Differential Rear Fill Plug Gasket Toyota 12157-10010 Fuel Filter Toyota None Serviceable Light Bulbs High & Low Beam Headlamp H4 or 9003 Front Turn Signal 4157 Rear Turn Signal & Tail Light 3157 Back Up Light 921 High Mount Stop & Map & License Light 168 Fog Light HB or 9145 Dome Light 3022 Oil Filter AmsOil 4.0L EaO57 AmsOil 4.0L (oversized) EaO34 Fram 4.0L (DG/TG/XG)3614 Fram 4.0L (oversized) (DG/TG/XG)3600 K&N 4.0L HP-1002 K&N 4.0L (oversized) HP-2009 Mobil1 4.0L (oversized) M1-209 SuperTech 4.0L ST3614 SuperTech 4.0L (oversized) ST3600 Toyota 2.7L 90915-YZZD1 Toyota 4.0L (oversized) 90915-YZZD3 Toyota 2.7L TRD PTR14-00000-04 Toyota 4.0L TRD PTR14-00000-07 Page 3 Date Mileage Detail Cost Date Mileage Detail Cost Expendables (continued) Oil Drain Plug Gasket Toyota 90430-12028 Toyota (??) 90430-12031 Oil-Tite 9/16″ M14 Metal/Rubber 65269 Oxygen Sensor Denso 4.0L Front 234-9002 Denso 4.0L Rear 234-4622 Bosh PCV Valve Toyota 2.7L 12204-0C010 Toyota 4.0L 12204-31030 Serpentine Belt Toyota 2.7L No A/C 90916-02639 Toyota 2.7L With A/C 90916-02640 Toyota 4.0L 90916-A2001 Spark Plug Toyota 2.7L 90919-01191 Denso 2.7L SK20HR11 NGK 2.7L ILFR6C11 Toyota 4.0L 90919-01235 Denso 4.0L K20HR-U11 NGK 4.0L LFR6C11 Manual Transmission Fill/Drain Plug Gasket Toyota 90430-18008 Windshield Wiper Driver (22in) 85222-04030 Passenger (21in) 85212-04030 Page 4 Manufacturers Recommended Maintenance Schedule These are the recommendations, your mileage may vary.
  2. Nov 25, 2008 at 12:10 PM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
