I think I bought too much tire for my truck – “E” minimum pressure?
Discussion in 'Wheels & Tires' started by JJK, Oct 9, 2010.
  1. Oct 9, 2010 at 9:34 AM
    JJK
    JJK [OP] Active Member
    08 SR5 DC
    TrueTrac Limited Slip
    2008 DC LB 4x4 - 4155lb curb weight empty.
    Hi guys – I just replaced a set of regular Goodyear Silent Armor tires (50k on them,) with the “Pro-Grade” load rang E version because that is what the dealer had in the warehouse and they have a little more tread.
    I ran my old set at 36PSI and they road nice and lasted 50K (could have gone another 10K or 15K but the snow is coming soon). This new set rides a bit harsher. Is there a “minimum” pressure I should stay above on a load range E tire? – They ride better at 33PSI but I worry that it might be too low to support the sidewalls?. Door jamb sticker says 29PSI for the stock tires. – Thoughts?
    I didn’t find any “minimums” mentioned for this load range when I searched.
    Thanks
    JJK
  2. Oct 9, 2010 at 9:37 AM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    i have 10 ply tires on mine. they are load range E. i run about 40 psi in mine.. they are a stiff tire because they are made for a full size truck and made to carry a load.
  3. Oct 9, 2010 at 9:39 AM
    zebra1550
    zebra1550 Well-Known Member
    Midwest
    4X4 SR5 DC OR Package
    16X8 Raceline Renegade 6's, 265/75R16 Revo 2's, Jason Tonneau, De-Badged, De-Chromed, Wet Okole's, 5100's & Rear TSB, Window's Tinted
    I run my "E" rated REVO 2's at 40 PSI all the way around. I've got over 15K miles on them so far and I can just now notice a little wear from when they were new. I still have nice deep tread, and they are wearing perfectly even. I've rotated them every 5K so far. I'm really happy with the ride, as they are smoother than my wife's mercedes.
  4. Oct 9, 2010 at 9:40 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I have load range E BFG KM2s and I run them at 36psi and get 19mpg. :cool:
    I've got about 7,000 miles on them and they haven't worn much. They look brand new.
  5. Oct 9, 2010 at 10:13 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    I have BFG AT KO Load E on mine and run them at 40 psi.
  6. Oct 9, 2010 at 3:53 PM
    JJK
    08 SR5 DC
    Well – Digging around I found some good info from Goodyear on capacity vs. inflation pressure for LT rated tires.
    The LT245/75/16 is rated at 3042lbs per corner at 80PSI, and 1700lbs per at 35PSI - so It looks like I should be able to run them at 33psi (for the ride factor) on the light weight Tacoma. I don’t think the front or rear axle weight is anywhere near 3400lbs (1700x2). I just need to remember that LT tires need to be pumped up for very heavy loads. I could exceed the load capacity of the truck before I exceed the load rating of the E range tire at 35psi. I only carry duck decoys and dogs most of the time with the occasional load of wood and the odd appliance now and then.:)
    http://www.goodyear.com/rv/pdf/rv_inflation.pdf
    I found the exact same chart for Bridgestone too.
    Thanks
    JJK
  7. Oct 9, 2010 at 3:57 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    X2 except i have cooper zeon ltz's
  8. Oct 9, 2010 at 4:33 PM
    DevL
    DevL Well-Known Member
    You can run whatever you want. High load rated tires can hold higher presure for heavier loads but dont require higher pressure. You can run 29 if you wanted.
  9. Oct 10, 2010 at 6:25 AM
    Archangel
    Archangel Insurance Agent
    Charlotte, NC
    '13 IS250
    I run 35 psi on my KM2's Load Range E and get almost 20mpg
  10. Oct 10, 2010 at 12:09 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    ^Same PSI on my BFG A/T E load and I also get about 20-21 mpg.
  11. Oct 10, 2010 at 7:44 PM
    bivey
    bivey Well-Known Member
    X2
  12. Oct 10, 2010 at 7:54 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    Have you guys running the load range "E" tires noticed a big difference from stock tires going down washboard dirt/gravel roads? Is the ride noticably rougher or about the same??
  13. Oct 11, 2010 at 1:22 PM
    JJK
    08 SR5 DC
    I had been reading on other truck forums that it is NOT OK to run LT load range E tires at low (passenger tire type) PSI because of the risk of heat related issues etc, and that they should not be run below 50PSI – so because I have OCD I ran the numbers based on all the data I could gather from various sources.
    Tacoma 16” Steel wheels 32lb (original wheels) – according to the wheel spec thread on this site.
    Tacoma 16” Alloy wheels 26lb ship weight. (replaced when I replaced the tires with LT load range E tires) +12lbs total with the new heavy tires.
    Load range E – LT245/75R16 = 46lbs
    Load range C – P245/75/16 = 38lbs (my original tire)
    Truck Curb weight 4190 empty (2008 DCLB 4x4 SR5)
    Truck front axle weight 2300lbs empty
    Truck rear axle weight 1890lbs empty
    LT254/75/16 load range E tire max load at 35PSI – 1700lb (data from Goodyear and Bridgestone)
    LT 245/75/16 Load range E tire max load at 50PSI – 2205lbs (same as P245/75/16 at 29PSI – data from Goodyear and Bridgestone)
    Max new tire rear axle load at 35PSI = 1510lbs (3400lbs – 1890lbs)
    Max new tire front axle load at 35PSI = 1100lbs (3400lbs – 2300lbs)
    So – I will exceed the max payload of the truck (1260lbs) before I exceed the max load of the new tires at 35PSI. No need to run at 50+PSI.
    Also of note – This morning I made a 180 mile round trip to scout a new hunting spot. I took it easy the whole way and managed to pull 23MPG! I don’t expect this from my normal driving habits but it is an encouraging sign none the less.
    To “OffroadToy” I was on a few miles of washboard dirt road today and I could definitely feel the difference – They are “rougher” than the “P” tires – However the steering wheel shake I use to have on dirt roads is GONE. I don’t know why that would be. Might be the new wheels – not sure.
    I'm pretty happy with them so far.
    JJK
  14. Jan 20, 2015 at 12:44 AM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Toyo has a great chart / specs etc on both P and LT tires on their site. The one thing I have noticed with the several charts I have seen on LT tires is that none of the mfg's list a load rating on the charts with less than 35psi inflation. Might be due to the heat issues associated with LT type tires. Have been considering dropping the pressure on the "D" rated LT's that came on my Pro down to 35 to see how it affects things.
