I think I bricked my ECU doing the B04 update..[OVTune Fixed it!!!]
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Double Phister, Aug 18, 2018.
  1. Aug 19, 2018 at 2:51 PM
    #81
    tAcomaPueblo
    tAcomaPueblo Well-Known Member
    Virginia Beach, VA
    2017 Tacoma TRD OffRoad 4x4 DCSB
    I've sewn my own wound up with a needle and thread before. Because of it, nobody should ever question my lack of going to medical professionals.
    Whitetail Assassin likes this.
  2. Aug 19, 2018 at 2:53 PM
    #82
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Why would I have any reason to question such decision? It's your body. Do with it as you please.
  3. Aug 19, 2018 at 2:55 PM
    #83
    TFly
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Did you flash the correct file? There's one for the 16-17s, and one for the 18s.
    scottalot likes this.
  4. Aug 19, 2018 at 2:56 PM
    #84
    Double Phister
    Double Phister [OP] Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    yes. Techstream confirms it's correct. It was going to go from B03 to B04. The 18s have a different number.
    scottalot and TFly[QUOTED] like this.
  5. Aug 19, 2018 at 3:08 PM
    #85
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    What I would like to know is what are the metrics for a TSB? As an engineer I know what it is for our company and generally for a lot of companies but, due to Toyotas staggering volume just with Tacoma I really have no clue at all. Is it 10? 100? 1000 complaints? Even 10,000 is less than 5%... a year. Also more goes into a TSB or voluntary recall than pure complaints. Optics are just as important, meaning how does it look from a customers point of view. It's a balancing act for sure but again, because of volume, I have no idea. Even my friends at Toyota engineering don't know, but I don't have the ear of any of the top level managers though.
    Plus, there is a huge difference between a wheel falling off (extreme example) and a whine between 58 and 62 mph from the rear diff on some vehicles lol, so priority comes into play too.
    MOC221_[QUOTED] likes this.
  6. Aug 19, 2018 at 3:15 PM
    #86
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    You can avoid a dealership and still get updates. The private shop I worked at ~10 years ago had Toyota, GM, and Ford factory scan tools with subs that would let us get the updates so I'm sure it's more ubiquitous now. Kept my 2007 and my family's Ford trucks up to date without issue.
  7. Aug 19, 2018 at 4:25 PM
    #87
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Actually, priority could definitely come into play when it comes to ECU updates for the manual trans in particular. Literally every one of the driveability related TSBs (involving a flash reprogram) have been strictly for the auto trucks. Makes sense, since we know the vast majority of the ridiculous number of units sold have that trans. It also seems likely that we were thrown a bone (sort of) because one or more of the symptoms outlined in these latest TSBs carry over to M/T trucks (the stumble, for instance). It's obvious that they made changes to engine specific code, in that the truck drives completely differently now (OVtune also confirmed that Toyota made a large number of changes). Anyway, albeit belated, I'm glad Toyota has chosen to act and make the product better.
  8. Aug 19, 2018 at 4:39 PM
    #88
    MOC221_
    Frank
    Good luck man :thumbsup:
    Mat is a stand up guy, I'm sure he'll get you fixed up.
  9. Aug 19, 2018 at 5:18 PM
    #89
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    ECU update best practices:
    Don’t use hacked versions of Techstream for an ECU update.
    Don’t use a virtual machine environment to do an ECU update.
    Don’t use Bluetooth or WiFi dongles for an ECU update. (USB only)
    Do turn off Windows update service.
    Do turn off Windows system sleep functionality. Use the “always on” setting in power management pane.
    Do turn off USB power management for the USB port you’re using.
    Do plug the laptop into a wall outlet.
    Do hook up a battery maintainer to the vehicle during an ECU update.
    Do turn off all electrical consumers during ECU update.
  10. Aug 19, 2018 at 8:24 PM
    #90
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    shakerhood likes this.
  11. Aug 19, 2018 at 8:46 PM
    #91
    nartmot
    nartmot Well-Known Member
    Sorry to hear about this, OP. Hope you get it sorted.
    Does someone have a write-up posted somewhere for a DIY b04 update? I tried searching but I can't find it.
  12. Aug 19, 2018 at 8:56 PM
    #92
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Not that I have seen. There is a lot of good info in the manual transmission update thread, but you got to dig through all 40 pages. It has all the files and links to all the downloads needed.
    nartmot[QUOTED] and tacoguy88 like this.
  13. Aug 19, 2018 at 11:00 PM
    #93
    Double Phister
    Sacramento, CA
    Got a loaner car from a friend. Went to the in-laws for dinner. Came home and got the ECU out. Will ship to Mat tomorrow.
    scottalot, Freegolf and tonered like this.
  14. Aug 19, 2018 at 11:01 PM
    #94
    Double Phister
    Sacramento, CA
    :anonymous: Don’t use hacked versions of Techstream for an ECU update.
    :anonymous: Don’t use a virtual machine environment to do an ECU update.
    :thumbsup: Don’t use Bluetooth or WiFi dongles for an ECU update. (USB only)
    :thumbsup: Do turn off Windows update service.
    :thumbsup: Do turn off Windows system sleep functionality. Use the “always on” setting in power management pane.
    :thumbsup: Do turn off USB power management for the USB port you’re using.
    :thumbsup: Do plug the laptop into a wall outlet.
    :anonymous: Do hook up a battery maintainer to the vehicle during an ECU update.
    :thumbsup: Do turn off all electrical consumers during ECU update.
  15. Aug 20, 2018 at 4:09 AM
    #95
    cstern1
    cstern1 Well-Known Member
    Caleb
    KCK
    2017 DCSB Sport
    I wonder what caused the issue cause mine was more like this and it worked fine
    :thumbsup: Don’t use a virtual machine environment to do an ECU update.
    :anonymous: Do turn off Windows update service.
    :anonymous: Do turn off Windows system sleep functionality. Use the “always on” setting in power management pane.
    :anonymous: Do turn off USB power management for the USB port you’re using.
    :anonymous: Do plug the laptop into a wall outlet.
  16. Aug 20, 2018 at 4:45 AM
    #96
    MOC221_
    Frank
    :thumbsup: Do turn off Windows update service. Note - My flashing laptop never sees the internet. Files are transferred via USB stuck. WiFi function is turned off.
    :anonymous: Do plug the laptop into a wall outlet. Note - I used to do this, but the laptop is always fully charged as I only use it for flashing.
    :anonymous: Do hook up a battery maintainer to the vehicle during an ECU update. This is a good idea, but I daily my truck so the battery is always topped off.
    :thumbsup: Do turn off all electrical consumers during ECU update.[/QUOTE]
  17. Aug 20, 2018 at 5:07 AM
    #97
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You can do the opposite of all of these best practices and still not screw anything up. It’s all about eliminating variables.
  18. Aug 20, 2018 at 5:22 AM
    #98
    MOC221_
    Frank
    I know, I'm just sharing my experience. It's best to mitigate any possibility of failure.
  19. Aug 20, 2018 at 7:48 AM
    #99
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Mine does the same as did the Camry rental that I had. I believe that this is more of a nuisance warning than actual information. It might help if something unexpected was left on, but usually, just having a door opened or the key on ACC will cause it to come up.
  20. Aug 20, 2018 at 7:55 AM
    #100
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    PSA,
    MOC221_ likes this.
