I think I decided on my lift setup. Do I need anything else?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StealthTaco, Jan 8, 2014.
  1. Jan 8, 2014 at 9:30 PM
    StealthTaco
    StealthTaco [OP] www.ecgfabrication.com
    Alec
    NC
    05 Black Tacoma TRD Sport 6-speed
    Hey guys. Newish to the whole lifting specifics, looking to see if anyone has any critiques. I do some light offroading and go through decent mud (that North Carolina clay), and towing every once in a while, but nothing ridiculous. I load up the bed mostly. When I get the lift I'll be trying to fit 285/70/R17 Nitto Trail Grapplers, I know a little trimming will have to be done. Here's what I'm considering:
    Front:
    Bilstein 5100s @ 2.5 - Edit...not sure why I put 2.75.
    OME 884 coils
    Toytec top plate spacer for full 3 inches
    Rear:
    Dakar leaf pack
    All Pro U-Bolt flip kit
    Also extended brake lines.
    Just wanted to make sure that I shouldn't need UCAs right? Also, are new shocks needed in the rear? Thanks for any help.
  2. Jan 8, 2014 at 9:34 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Bilsteins are 2.5 max and most are able to get away without new UCAs.
    884's are awesome,can't go wrong. Should be somewhere around 2-2.25 lift
    with the 3" spacer you will most likely need UCAs. I believe anything 3"+ needs them replaced.
    keep in mind with any of these lifts replacing the control arms will make for a much nicer ride.
    and yes. You need new shocks in the rear.
  3. Jan 8, 2014 at 9:36 PM
    Techy
    Techy Well-Known Member
    Montrose, CO
    06 trd off road dbl cab
    Can't run OME coils and set the billies at 2.5"
  4. Jan 8, 2014 at 9:39 PM
    Techy
    Montrose, CO
    Keep stock coils or set billies at zero. And you will need UCA' s st close to 3 inches. Most likely anyway.
    I am guessing you have a access cab. If it is double cab I would go with 885's.
    I am no expert though
  5. Jan 8, 2014 at 9:42 PM
    StealthTaco
    Alec
    NC
    Yes I have an access cab which is why I chose the 884. I don't want to shell out $600 so maybe I'll try to get away without the top plate spacer first.
    So bilsteins set @ 0 with the coils? Or should I just not worry about the coils and do just 5100s @ 2.5?
    And what shocks for the rear, 5100s as well?
    Too many damn questions haha
  6. Jan 8, 2014 at 9:53 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    Bilsteins at 2.5 on stock coils makes the ride fairly stiff. I ended up going with 884s on bilsteins set at 0.... If you're going 5100 in the front, you might as well go 5100 in the rear.
  7. Jan 8, 2014 at 9:54 PM
    Techy
    Montrose, CO
    With the one coils set billies at zero. Otherwise you are stacking lifts and that is bad. You could keep stock coils and set billies at 2.5 but the ride will be better with the ome coils. Get some uca's like light racing.
    I just did darn near the same set up. In the rear I put 5100's and a 1.5" wheeler progressive aal (overload left in) and 5100's. That brought my rear up about 2.25"
  8. Jan 8, 2014 at 9:55 PM
    Techy
    Montrose, CO
    I love my setup so far. Rides amazing IMO. Many more informed people should chime in though.
  9. Jan 8, 2014 at 10:04 PM
    StealthTaco
    Alec
    NC
    You make a good point Beavis. I'll go with the 885 coils.
    So as of now....
    Front:
    5100s @ 0
    OME 885 coils
    Rear:
    Dakar leaf pack
    5100s @ 0
    All-Pro U-bolt flip kit
    Extended brake lines
    So this should be a solid setup? Hopefully I can get away without UCAs.
  10. Jan 8, 2014 at 10:10 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Like pee's and carrots .:D
    Thanks,
    Brett
  11. Jan 8, 2014 at 10:17 PM
    StealthTaco
    Alec
    NC
    You know I'm not sure, I guess I've just seen people on here running that combo and assumed it was the way to go.
    So I'm assuming the OME 90000 shocks up front and then the rear shock set would be the way to go instead of the 5100s all around? Makes a lot more sense now that I think about it lol.
  12. Jan 8, 2014 at 10:22 PM
    StealthTaco
    Alec
    NC
    Makes sense!
    Haha thanks man, I really do appreciate it.
    Appreciate anyone else who helped too!
  13. Jan 9, 2014 at 8:21 AM
    Techy
    Montrose, CO
    Billies will work fine with ome coils if that is what you want. I believe most run 884 coils on access cab, 885 on double, and 886 if there is a heavy bumper. And most need uca's, or she floats around on you.
  14. Jan 9, 2014 at 8:22 AM
    Techy
    Montrose, CO
    Not sure if you need extended brake lines or not.
  15. Jan 9, 2014 at 8:36 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    I believe the 5100's are quite a bit cheaper. I bought my 5100's on TW for cheap with no miles which is why I bought them. They are awesome and love the ride! The Nitrocharger's are made for the coils but I can't imagine it's a huge difference. If I was buying new I'd do it again. I couldn't find the Nitrocharger's cheap so...
    I have my 5100's @ 0 with 885's
    Can't go wrong with either and if you have the extra coin get the Nitrocharger's.
  16. Jan 9, 2014 at 1:32 PM
    high voltage taco
    high voltage taco Well-Known Member
    Monticello, Ky
    05 TRD 6 speed 4x4
    so far, URD throwout bearing kit(sleeve), weathertechs, 285/70/17's on Ion 17x9 and OME 885s and Dakars and nitro sports. BHLM
    two reasons I didn't go with 5100's with my 885's. 1. I emailed toytec about the setup and they responded "do not run bilstein and OME 885's together". 2.I ran 5100s on the tundra I had and they lasted about 20k miles and went to leaking oil. So this time I went all OME and Dakar. I love the setup as I haul fire wood and pull a trailer from time to time but the ride unloaded on the road is stiffer than stock. Offroad the ride is much better than stock. I have nitro charger 90000 and 885x's up front and nitro charger sport and dakars with extended brake lines in the back. I got about 3 inches in the back and 2.75 in the front.
  17. Jan 9, 2014 at 7:28 PM
    StoopidHead
    StoopidHead Well-Known Member
    Brendan
    CA
    09' ACCESS CAB TRD 4X4
    So if I keep the stock coils and run the 5100s @2.5 the ride will be a little rough?
  18. Jan 9, 2014 at 7:46 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    A tad bit more stiff. I currently have my truck set at 2.5 using stock coils and it's not as bad as you might think. I had a Samurai lifted, now that thing was rough. A Tacoma's at 2.5 is like a caddy compaared to that. I like how my truck rides currently with this set-up.
  19. Jan 10, 2014 at 4:37 AM
    Onurnez
    Onurnez Well-Known Member
    Richmond, Virginia
    2008 Toyota Tacoma
    Fog Light Anytime Mod, LED dome and Map, Alpine Head unit, w/ Alpine door replacements, De-badged/De-Flapped, Anzo Black Headlights, Anzo Black Tail lights, Satoshi by Homer, Full OME Kit, LR UCA's Black interior dash parts, UltraGauge, Custom Decals By RuggedT, TRD Exhaust, Volant CAI, Weathertech Rainguards, Weathertech Floormats, Blueinstinct Center and door handle covers, Tacoma Bed Mat, 17x9 Fuel Kranks, 285/70/17, Window Tint: 5% back/35% front, Powerslot Rotors, Redline hood strut, 14'' Black Billet Antenna, LED Bed Light Mod, 100k mile mod
    Maybe I should do some searching, but does anyone know why Toytec would advise us not to run the OME coils with 5100's? I know that the Nitro's would be a better choice in this scenario, because they designed together. I guess I am just looking for the why the 5100's wouldn't work.
  20. Jan 10, 2014 at 5:17 AM
    teneighty
    They will work and hundreds of people use them. Toytec says that because the nitros are made for the coils and I'm sure They want to push those products together.
    I'm so impressed with the ride of my 885's and 5100's. Both are great setups. If I would have had the extra cash I would have done the nitro's I guess just because they are made for them.
