I think I have a hole in my gas tank!!!
Discussion in '2nd Gen. Builds (2005-2015)' started by patdeal, Dec 4, 2013.
  1. Dec 4, 2013 at 3:09 PM
    HalfTaco
    HalfTaco Danger Dave
    Dave
    OC
    02 Single Cab Prerunner
    If you put larger diameter tires on, your odometer is no longer an accurate means of measurement for mileage. Every mile it reads now needs to be modified with a multiplier to determine the true amount of miles you have travelled since changing tires.
  2. Dec 4, 2013 at 3:11 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
  3. Dec 4, 2013 at 3:17 PM
    HalfTaco
    Dave
    OC
    Correct me if I'm wrong but.... New tire circumference / old tire circumference x mileage read on odometer trip = actual miles travelled.
  4. Dec 4, 2013 at 3:19 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Spend much time in 4WD? Forget and leave it in?
  5. Dec 4, 2013 at 3:51 PM
    patdeal
    patdeal [OP] Member
    concordia ks
    2010 dbl cad tacoma sport
    Any ideas what the problem may be?
  6. Dec 4, 2013 at 3:53 PM
    patdeal
    patdeal [OP] Member
    concordia ks
    Put it 4x4 just for a sec while towing 67 fastback. But thats it.
  7. Dec 4, 2013 at 4:03 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    That is strange... towing and 4X4 usually help gas milage :facepalm:
  8. Dec 4, 2013 at 4:03 PM
    patdeal
    patdeal [OP] Member
    concordia ks
    I figured the new tire size and my actual mileage was 173.5. But only brought it from 9.44 to 9.91 mpg.
  9. Dec 4, 2013 at 4:06 PM
    patdeal
    patdeal [OP] Member
    concordia ks
    Well any ideas on things I can check would be great.
