I think I have an electrical issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rondog, May 1, 2012.
  1. May 1, 2012 at 7:37 AM
    rondog
    rondog [OP] Well-Known Member
    Ronnie
    Escondido/San Diego
    For some time now, I've been noticing anything electric in the truck I use will cause the engine idle to drop pretty noticeably. For example, rolling the windows down, using the fan etc. I really started to notice when it had rained this past day. Any time the windshield wiper would be wiping, the idle would drop. What does this sound like? Alternator? I have a yellow top and its about 3 years old. I also have 2 amps and 2 subs + four 50 watt HIDs
  2. May 1, 2012 at 7:42 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Might want to have the alternator checked out. Also, check the voltage at the battery to make sure it's being charged when the engine is running. Keep the volt meter hooked up and see what happens when you turn something on, like the windows.
  3. May 1, 2012 at 7:42 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's
    I would look into upgrading the "alternator to battery", "engine ground to battery", and "frame ground to battery" cables. With all of your high draw accessories, having thicker cable for all of this provides a little less resistance in the electrical system. Also, yellow tops are deep cycle batteries. These are designed to provide low amp draw over long periods of time. High amp draws will kill them faster. What you want next time is a red top.
  4. May 1, 2012 at 7:42 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    time for dual optimas!
  5. May 1, 2012 at 7:46 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    directly from Optima's website:
  6. May 1, 2012 at 7:50 AM
    Pugga
    Massachusetts
    F-150 Mod
    Also from Optima's website for the yellow top:
    Trucks with winches, vehicles with multiple electronics, cars with high-demand audio systems, commercial vehicles and heavy equipment all rely on this battery to provide ultimate starting and deep cycle power
  7. May 1, 2012 at 7:52 AM
    Maticuno
    03 F250 CCSB
    Then what he wants is a dual RedTop setup. Subjecting a deep cycle battery to heavy loads will shorten its lifespan, regardless of the manufacturer.
  8. May 1, 2012 at 8:04 AM
    Maticuno
    03 F250 CCSB
    I'm really not trying to be an asshat here, guys. I've just lived on an off-grid solar electric system for 4 years and there is a lot of technology difference between battery types.
    From WindSun.com:
    Gelled electrolyte
    Gelled batteries, or "Gel Cells" contain acid that has been "gelled" by the addition of Silica Gel, turning the acid into a solid mass that looks like gooey Jell-O. The advantage of these batteries is that it is impossible to spill acid even if they are broken. However, there are several disadvantages. One is that they must be charged at a slower rate (C/20) to prevent excess gas from damaging the cells. They cannot be fast charged on a conventional automotive charger or they may be permanently damaged. This is not usually a problem with solar electric systems, but if an auxiliary generator or inverter bulk charger is used, current must be limited to the manufacturers specifications. Most better inverters commonly used in solar electric systems can be set to limit charging current to the batteries.
    Some other disadvantages of gel cells is that they must be charged at a lower voltage (2/10th's less) than flooded or AGM batteries. If overcharged, voids can develop in the gel which will never heal, causing a loss in battery capacity. In hot climates, water loss can be enough over 2-4 years to cause premature battery death.
    Using a deep cycle battery as a starting battery
    There is generally no problem with this, providing that allowance is made for the lower cranking amps compared to a similar size starting battery. As a general rule, if you are going to use a true deep cycle battery (such as the Concorde SunXtender) also as a starting battery, it should be oversized about 20% compared to the existing or recommended starting battery group size to get the same cranking amps. That is about the same as replacing a group 24 with a group 31. With modern engines with fuel injection and electronic ignition, it generally takes much less battery power to crank and start them, so raw cranking amps is less important than it used to be. On the other hand, many cars, boats, and RV's are more heavily loaded with power sucking "appliances", such as megawatt stereo systems etc. that are more suited for deep cycle batteries. We have used the Concorde SunXtender AGM batteries in some of our vehicles with no problems.
    It will not hurt a deep cycle battery to be used as a starting battery, but for the same size battery they cannot supply as much cranking amps as a regular starting battery and is usually much more expensive.
    So, I will take back what I said about the shortened battery life, but the above points out why the engine RPM's drop due to the increased load on the alternator because the deep cycle battery cannot supply the initial amperage necessary to start rolling up/down the windows, etc.
  9. May 1, 2012 at 9:55 AM
    rondog
    Ronnie
    Escondido/San Diego
    Thank you guys for the replies. I will try the volt meter as I don't think it is an issue between red and yellow top. I've hady yellow top and all these electronics for years and it has only begin doing this maybe the past few months.
  10. May 1, 2012 at 10:07 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Clean the battery terminals if you haven't already, even if they look ok on the outside. If the trouble continues, have the battery load tested, and the alternator output tested.
  11. May 2, 2012 at 12:18 AM
    JKD
    JKD Well-Known Member
    I have seen this happen in vehicles where a main ground is corroded through, or one or more ground wires have a bad connection to the chassis.
    The FIRST thing I would do is check all the ground wires you can find, especially the ones in the engine compartment between battery--frame/body, frame/body--engine, and engine--battery.
  12. May 2, 2012 at 10:54 AM
    rondog
    Ronnie
    Escondido/San Diego
    I'll try cleaning them. I just had the battery tested about a month ago and it was at 60% after the truck only sitting for 5 days, so who knows maybe the battery is going bad because that doesn't seem right
    My engine bay is pretty dirty so that is a possibility. I've seen at least 5 grounds in there that I can think of
  13. May 3, 2012 at 6:57 AM
    Maticuno
    03 F250 CCSB
  14. May 3, 2012 at 7:31 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    An easy way to check connections is to run the engine, turn on headlights, heater fan on high, even turn the wipers on high, and measure voltage drops with a voltmeter. Simply measure between the negative battery terminal and the engine block, also between the block and the body. Then, measure from the positive post of the alternator to the positive battery post. Anything over .5V indicates a bad connection.
    I should have mentioned it in my earlier post, but I consider this part of testing alternator output, where many do not.
  15. May 3, 2012 at 7:34 AM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    go to sears - get the Group 31m Platinum deep cell - its built by Odyssey and branded for sears. Its a beast, but it fits in stock location and better than 2 smaller 24 or 34 IMO - less weight, less wiring/expense. Best bang for you buck.
  16. May 3, 2012 at 7:45 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  17. May 3, 2012 at 7:47 AM
    Wicked 2007
    Bay Area, CA
  18. May 3, 2012 at 7:48 AM
    Pugga
    Massachusetts
    F-150 Mod
  19. May 3, 2012 at 7:52 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    :notsure:
    I never asked. :eek: FWIW, they go from 250A to 390A.
  20. May 4, 2012 at 8:39 AM
    Wicked 2007
    Bay Area, CA
    the 390amp is $1250
