I think i have an exhaust manifold leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OCTaco, Mar 25, 2010.
  1. Mar 25, 2010 at 6:42 PM
    OCTaco
    OCTaco [OP] Well-Known Member
    OC
    '16 TRD Sport DCSB
    Whenever i start my truck up and its cold outside, by cold i mean below 65F, i get this weird winding/buzzing/humming noise. Then when i start to drive it, it sounds like the exhause manifold is leaking. After a while it goes away but i still get it between 2000-2500 rpm. I took the truck to an exhaust shop and they told me they couldnt hear anything. I also couldnt here anything on the way home but that was probable because it was 84F outside and the truck had been running all day. Since it only happens on cold mornings and when the truck is cold im thinking it might just be the gasket on the exhaust manifold? Also ive been experiencing some vibrations throught the steering column and the floor board, and some on the gas pedal. Truck makes a lot of engine noise at 2000 rpm. Im hoping this is all related to the exhaust manifold. Anyone have the same thing going on, or some advice for me?
  2. Mar 25, 2010 at 7:47 PM
    06aztaco
    06aztaco Screw you guys, I'm going home.
    Cole
    Phx AZ
    06 Prerunner 2.7
    not sure what problem you have, but smelling exhaust in the cab when stopped is more characteristic of an exhaust leak..
    Good luck though
  3. Mar 25, 2010 at 8:13 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    i know its a little different, but my cast I4 manifold on my 98 cracked and would only hiss like you say until it warmed up and the metal expanded and closed the crack. but our manifolds arent cast...but i think your trouble shooting it right when you say it only happens when cold and not when the truck is warmed up and such.
    start the truck up when cold and try to find the source of hte noise...that will give you a better idea of what is going on.
  4. Mar 25, 2010 at 8:27 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Sounds like a gear issue. They sound tell its warm. Check your fluids.
  5. Mar 25, 2010 at 9:46 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    Gear issue? What fluids do i check? BTW my truck is a 2006 a/t with 84k.
  6. Mar 25, 2010 at 9:51 PM
    desertdude59
    You still have a warranty on it? The whirling noise can be a dry gear, a bearing, a belt. Exhaust leaks usually tick and dont go away depending on how bad the leak is. That front diff could be making noise. Without hearing it I can only guess. You sure its not your fan clutch? Sounds like thats most likely it.
  7. Mar 25, 2010 at 9:53 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    ^ im guessing with him on this, usually dont agree with a 4x4 grrrr
  8. Mar 25, 2010 at 9:56 PM
    desertdude59
    Kinda sounds like a fan clutch before they warm up during start up. What do you think?
  9. Mar 25, 2010 at 10:10 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    Its not 4x4. And now that you mention it, it does sound like a clicking noise at times. This is apearantly do to the exhaust manifold. I just found a tsb for it but it only cover 96months and 80k. Im at 84k. Im speaking to the service manager tomorrow, i hope he'll go ahead and fix it anyways. Im praying like crazy right now. Is there anyway to diagnose the fan clutch?
  10. Mar 25, 2010 at 10:16 PM
    desertdude59
    Just try and spin it when its cold. If it spins in your hand with some resistance thats a good sign. If it wobbles going from front to back then the bearings are going bad so you should change it. Just ask them to check the fan clutch to if you can bring it to the shop.
  11. Mar 25, 2010 at 10:18 PM
    08pretaco
    Oliver
    az
    ^gosh darn i hate agreeing with a 4x4 again but he beat me... :( haha jk................ i can run spindles so im happier :D
  12. Mar 25, 2010 at 10:20 PM
    desertdude59
    lol:D
  13. Mar 25, 2010 at 10:20 PM
    08pretaco
    Oliver
    az
    no way am i gonna compete with a person that has a 4x4 on advice :lalala: .....
  14. Mar 25, 2010 at 10:23 PM
    desertdude59
    uh oh :eek:. bahahaha
  15. Mar 25, 2010 at 10:29 PM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    my buddy has an exhaust leak in his cherokee and it sounds like a lawn mower when he starts it, but once the pipes warm up it goes away.
    so that kinda relates to your symptoms, but not sure if your "humming" is the same thing as his lawn mower.....the lawn mower is very obvious when the car starts
  16. Mar 25, 2010 at 10:32 PM
    08pretaco
    Oliver
    az
    hey man lets wheel out by you some time....ill hit you up when ill be out there :D
  17. Mar 25, 2010 at 10:32 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    No mine does the same shit. I just have a hard time explaining noises. Im weirt that way. Thanks for the advice.
  18. Mar 25, 2010 at 10:36 PM
    desertdude59
    For sure.
