I think I killed my baby
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doffroad, Jan 3, 2015.
  1. Jan 3, 2015 at 5:48 PM
    #41
    Doffroad
    Doffroad [OP] New Member
    David
    Savannah, GA
    2013 V6 4x4 off-road pkg
    Fwd steel bumper with 9.5 super winch. Aft steel bumper. 3" lift with 33" mud terrain tires.
    The alternator is fine. The water didn't go through the intake. But I'm worried about possible water in the engine through the exhaust from the truck shutting off while still in the water. I'm running a compression test in the morning. I'm also checking the fuel for possible water as well in case water might have gotten through the fuel vent.
  2. Jan 3, 2015 at 5:50 PM
    #42
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Because some people like to have fun and use their trucks?
  3. Jan 3, 2015 at 5:52 PM
    #43
    rickcrna
    rickcrna Well-Known Member
    Rick
    Central Oregon
    '13 AC SR5 4WD I4 Auto MGM
    OP....how much do you still owe on this truck?
  4. Jan 3, 2015 at 5:54 PM
    #44
    Boone
    Boone, NC
    Airbags deployed
    Why is that of any relevance?
  5. Jan 3, 2015 at 5:55 PM
    #45
    Doffroad
    David
    Savannah, GA
    Also, the only codes that popped up had to do with the maf sensor and I replaced it. Still the same issue.
  6. Jan 3, 2015 at 6:01 PM
    #46
    tunernewb92
    tunernewb92 Well-Known Member
    Brian
    Houston, TX
    2010 DCSB MGM OR
    Bills 5100 Front and Rear OME 885 Front Sway Delete 33" MTZ TRD FJ Wheels (Plasti - Black) Pioneer 10" Sub Kicker DS series component and speakers Alpine 5 way Amp Pioneer Double Din ImMrYo Mirror Bracket Escort 8100 Radar hung from mirror Waiting at house for install: TRD skid plate Retrofit Waiting on: BruteForce sliders BruteForce front bumper 2x3 6 led spot lights
    Because he wants to laugh at OP probably.
    See this is why I have a snorkle. I dont expect to need to use it, but I do expect to go off road. Peace of mind. And they look bad ass!:D
  7. Jan 3, 2015 at 6:11 PM
    #47
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
    I don't know if anyone mention this yet but there's a possible you short out the electrical system somewhere since some of the wiring are exposed to the elements. I'd clean and dry out every single connectors and any exposed wiring also.
  8. Jan 3, 2015 at 6:46 PM
    #48
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    So what's it doing now, crank crank crank and not starting?
    Are you sure you see and smell fuel? Sounds like you got something wet that is preventing it from starting. One of many electrical control units on our trucks.
  9. Jan 3, 2015 at 6:57 PM
    #49
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2021 DCSB TRD Pro
    Maybe water in the gas?
  10. Jan 3, 2015 at 7:18 PM
    #50
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Was the oil milky at all the second time it was changed, and I see the pic but when you were winching out did it get any deeper than the pic?
  11. Jan 3, 2015 at 7:18 PM
    #51
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Unless you put some serious time and effort into water proofing, breather relocation, etc. you will be limited to the same fording depth as stock. Just with peace of mind for not hydro locking and better air quality (snorkels were invented to grab clean air, not ford water)
  12. Jan 3, 2015 at 7:23 PM
    #52
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    I am amazed on how many people are surprised when I tell them this
  13. Jan 3, 2015 at 7:27 PM
    #53
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    As long as your intake manifold was well above water level as the pic shows, the water will not climb up into it from the exhaust.
    Drain the gas and replace with fresh stuff is something I'd try.
  14. Jan 3, 2015 at 11:32 PM
    #54
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    Because whats the fun in a mallcrawler? :confused:
  15. Jan 5, 2015 at 5:30 PM
    #55
    Doffroad
    David
    Savannah, GA
    Replaced the gas and it wants to start more than it did before. It kind of started last night, but didn't stay on without me holding the key turned all the way for more than a few seconds. A mechanic friend of mine thinks it might possibly be the starter gone bad. Since it is on the side that was tilted under water. So I'll be taking it and getting it tested.
  16. Jan 5, 2015 at 5:46 PM
    #56
    rogs6266
    rogs6266 Well-Known Member
    Alliance, OHIO
    '13 TRD Sport 4X4 DCLB MGM
    SOS weld on sliders, SOS bed rack, SOS front aluminum winch bumper with center and head light hoops, Stealth 6 wheels wrapped in goodyear duratracs, 285-70/17 Beer opener in bed, Thule roof rack on factory rack, Tool box, bed mat, K&N cai, flowmaster side out duals, and tailgate extender, Fog light anytime mod, no mud flaps mod Weathertech full set, Wet okoles front and rears, full OME 886 suspension lift with Dakars in rear, smittybilt X20 comp 10 winch, factor 55 yellow pro link,
    Hey David, i am in Savannah also. I might not be a mechanic but if you would need a hand with anything let me know. I'll help out a fellow TW member.
  17. Jan 5, 2015 at 5:53 PM
    #57
    File IFR
    Central MA
    I dunno about the starter, it seems to be doing it's job. Once it starts, does it remain running?
    You might have to bite the bullet and let a mechanic look it over. Best of luck, I'll be following this .
  18. Jan 6, 2015 at 11:25 AM
    #58
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    gtfo
    :woot:
    May be secondary but, as soon as you remedy the issue, may as well check for water intrusion in the rear diff to be on the safe side.
    Best of luck.
  19. Jan 6, 2015 at 11:35 AM
    #59
    la0d0g
    running for the hills
    For crawling not hauling
    I'm not. People are stoopud.
  20. Jan 6, 2015 at 3:28 PM
    #60
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I bet there are more than a few snorkle owners that were surprised to find out the snorkle didn't save their ass in 4 feet of water.
