I think I killed my baby
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doffroad, Jan 3, 2015.
  1. Jan 6, 2015 at 3:39 PM
    #61
    Aerial Tacoma
    Aerial Tacoma Well-Known Member
    Andre
    Kodiak Ak
    2010 TRD Off Road Access Cab
    TRD Cold Air Intake, TRD Catback, Original HomerTaco Raptor Grill, TRD Trail Teams "Black", Duratrac 265/75/16, ALL PRO apex rear bumper, Retrofits W/ BHLM halos and deamon eyes
    If there was a lot of water in the gas, can that cause the fuel filters to get bogged up? If so replacing those might not hurt. Then again i am not an auto mechanic lol
  2. Jan 6, 2015 at 3:45 PM
    #62
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Possible short circuit of ignition system, fuel pump, MAF sensor, etc...I'd check all fuses before anything else. Any chance the o2 sensors could be fouled from water in the cats?
    Have you hooked up a code reader to check for any diagnostic engine codes?
    If it's turning over, it's a good sign. I can't see a head gasket blow unless it was overheated, and you'll snap a rod or piston before losing compression if there was water in your combustion chambers.
