I think I killed my LSD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dtrujillo63, Jan 22, 2009.
  1. Jan 22, 2009 at 5:24 PM
    dtrujillo63
    dtrujillo63 [OP] Well-Known Member
    Denny
    Los Angeles
    08 Tacoma DC 4x4 Sport
    So I went offroading on Sunday, on my way home I kept hearing a "woo-woo-woo-woo-woo" noise coming from the rear of the truck every time I let off the gas. As soon as I would give it gas again the noise would go away. At the time, I just ignored it since I usually get tons of noises after hitting a trail (they all normally go away after I wash the truck). After washing the truck the noise was still there. I double checked my tires, took a look under the truck and everything checked out. This morning I decided to take the truck to the dealer, they took a ride with me and noticed the noise. Right away the tech tried blaming it on my tires. "It’s probably your tires", "did the truck come with those?", "all terrain tires develop noise as they wear down"... blah blah blah. When we got back to the dealer, they put the truck on the lift and ran it, right away you could hear the noise LOUD and CLEAR coming from inside the pumpkin. The tech decided that changing the differential oil might help. About two hours later the dealer calls me informing me that they found a bunch of metal shavings in the oil. They decided to order me a new 3rd member. It should be here tomorrow. Luckily they are going to cover it under warranty :D!
    I have a feeling I might have caused the problem :eek:. Since I don't have a locker, I do what I like to call a "poor mans locker". Whenever I lose traction on one of my rear wheels, I hit the ebreak and keep going until I gain traction again. It locks my rear tires 90% of the time. Do you guys think doing that is what probably caused the problem?
  2. Jan 22, 2009 at 5:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    It may have, but I have doen this many times with no ill affects.
  3. Jan 22, 2009 at 5:46 PM
    dtrujillo63
    Denny
    Los Angeles
    You've probably done the poor mans locker trick 100x more then me. I did use it heavily on Sunday though. My truck only has 9k miles on it.
  4. Jan 22, 2009 at 5:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There are a number of things that could have caused it, But I dont think it was from useing the E brake.
  5. Jan 22, 2009 at 5:53 PM
    dtrujillo63
    Denny
    Los Angeles
    Good to hear, because the poor mans locker is one of my most useful tools out on the trail :D!
  6. Jan 22, 2009 at 5:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    did you have your rear end submerged in water for any length of time?
  7. Jan 22, 2009 at 5:57 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Doubt it, but have you changed the oil and forgot the LSD additive
  8. Jan 22, 2009 at 5:58 PM
    TacoNut
    Adam
    Denver, Co
    Did anyone else just notice that LSD is spelled like acid, LSD HA :playball:
  9. Jan 22, 2009 at 5:59 PM
    tacoma08MZ
    tacoma08MZ Well-Known Member
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    tinted head/tail lights-blacked out badges-3 inch tuff country lift 33 inch nittos-black steelies custom spare bed mount-hilift-weathertechs-kenwood dnx5120 dvdnav headunit-remote start-painted grille surround-fog lights-grillcraft black mesh grille
    haha whats this poor mans locker guys. i dont have a locker either it might come in handy. do you just put the ebrake on the first click or the whole way down? sorry to derail this thread :eek:
  10. Jan 22, 2009 at 5:59 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you just figuring that one out Adam???:poking::D
  11. Jan 22, 2009 at 6:00 PM
    TacoNut
    Adam
    Denver, Co
    It just sorta hit me... Maybe that's the first time I've ever typed LSD
  12. Jan 22, 2009 at 6:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Last time I heard of this happening, it was caused by a LSD temporary shim/spacer that is installed when the diff is put into the carrier. If the shim/spacer isnt removed after the install (which happens), it can cause this sound, and tear up a bunch of stuff inside. They are warantying it, so no worries. Its a 1 in 100,000 or more that this happens.
  13. Jan 22, 2009 at 6:01 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    gotcha:)
  14. Jan 22, 2009 at 7:05 PM
    dtrujillo63
    Denny
    Los Angeles
    Nope, no water. Drove to the trail on Sunday morning with no noise, drove home with the noise.
    Never changed the diff oil, truck only has 9k miles on it.
    Hahaha, you click the ebreak 1 or two clicks, just enough to stop any wheel spin and gave it has while the ebreak is engaged. This will make both wheels spin the majority of the time.
    Are you talking about when they are actually putting together the differentials from the factory? Funny thing was that I entered the trail with no noise and exited the trail with it.
  15. Jan 22, 2009 at 7:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. I had one go just backing out of a convieniance store. Different truck, LSD diff.
  16. Jan 22, 2009 at 7:11 PM
    dtrujillo63
    Denny
    Los Angeles
    Weak sauce! I guess its time for an ARB. Originally, my plan was to keep using poor mans locker in the rear and adding an ARB in the front. The front would have only been used as a last resort. After this situation, now I'm just thinking about putting an ARB in the rear and be done with it.
  17. Jan 22, 2009 at 7:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If what I mentioned was indeed the problem, it wont happen again. The diffs they send the dealers have all been checked, and the spacers removed. It usually only happens during the manufacturing process at the factory.
  18. Jan 22, 2009 at 7:23 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    haha ,sorry to hear but what i tell you lastnight..might be the dear diff. they couldnt just replace the clutch pack? in any case though, you're getting a new member hahahahahaha. i agree with everyone else most likely not caused by the "poor mans" locker.
    i had a front and rear diff service done at 6k just for preventive maintenance and that stuff that came out was pretty bad even at that low milage, but mind you i'm out and about somewhere just about every weekend.
  19. Jan 23, 2009 at 11:01 PM
    SiRMarlon
    SiRMarlon The Photo Ninja!
    Marlon
    Los Angeles
    Canon 5D MarkIII
    Just get the ARBs already bro! Fuck the supercharger! The Truck has enough power already! Come Tax time homie slap the ARBs on that bitch! :D
  20. Jan 24, 2009 at 1:32 AM
    tacoholic
    tacoholic 09 but I drive a 012 Expedition...
    Jeff...I'm pretty sure
    East Bay, CA
    Quite possibly, someday...
    You sure you didn't drive through Oakland recently and get a whistle tip installed???
