I think I messed up...I need TW's help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OCTaco, Jun 22, 2010.
  1. Jun 22, 2010 at 1:12 PM
    OCTaco
    OCTaco [OP] Well-Known Member
    OC
    '16 TRD Sport DCSB
    When I bought my Truck (05 V6 4.0 trd or) It had a KNN CAI installed and the guy didn't have the stock oem intake. In order to pass smog I needed the stock oem intake so I looked for one on CL. Here's the thing the intake came from an 07 x-runner. Anyways while I was replacing the knn i decided to clean my MAF Sensor an throtle body. When I started up the truck it rev'd real high and when I attempted to come a stop It struggled to shift down from 2nd to 1st. I figured this was because of me cleaning the throtle body and MAF. Anyways now (2months and 4k miles later) it still has a hard time down shifting from 2nd to 1st. Where did I go wrong? Is it the intake? No light's are coming on so I dont think it's the throtle body or MAF Sensor. All ideas are welcomed.
    My truck has 68k on it. It's automatic.
  2. Jun 22, 2010 at 1:17 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    What did you use to clean the MAF sensor? If you used anything that could leave a residue, you definitely messed up. ;)
  3. Jun 22, 2010 at 1:19 PM
    Brunes
    Brunes abides.
    Rotorhead
    And since it's been a while I hope you've rechecked the bolts/gaskets/connections all the way thru the system.
  4. Jun 22, 2010 at 1:21 PM
    Natetroknot
    Natetroknot Def Leppard Sucks!
    Nate
    Dubuque, IA
    '11 Black Access Cab
    Billy's @ .85, 1.5 Progressive AAL, Leer 100xl, BFG KO2's
    Did you have/notice/attach the vacuum hose on the back side of the intake plenum, by the firewall?
  5. Jun 22, 2010 at 1:39 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    I used MAF cleaner.
  6. Jun 22, 2010 at 1:39 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    All the hoses seem to be in place and everything is tight.I'm thinking of switching back to a CAI and see if that helps.
  7. Jun 22, 2010 at 1:41 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    I just spoke to the dealer and their master tech says it's because of the intake. he says intakes on x-runners and different because x-runners are meant for racing? WTF? Can anyone elaborate on this?
  8. Jun 22, 2010 at 1:44 PM
    Natetroknot
    Nate
    Dubuque, IA
    X2
  9. Jun 22, 2010 at 1:47 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    Tried that. I left the truck unplugged for like 30 mins. Any ideas on diagnosing this?
  10. Jun 22, 2010 at 2:02 PM
    Natetroknot
    Nate
    Dubuque, IA
    It would be relatively easy to make sure that vacuum hose is there, slid all the way on to both nipples, and not cracked or something.....if you've done that already then I'm at a loss; not trying to be repetitive or disrespectful, just want you to be sure that's not it b/c unless you've got a check engine light on I can't see anything else being the culprit.
    I'm not 100%, but I believe that supplies the fuel pressure regulator with necessary vacuum - which is directly related to your computer controlled shift points in an automatic. If that vacuum line isn't hooked up, you're coasting to a stop while off the throttle, and as far as your 'puter knows you're still on the throttle. Then a secondary (or supplementary) parameter such as wheel speed causes the shitty shift down to first.
  11. Jun 22, 2010 at 2:07 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    I will double tripple check the vacum hose, is that the one that goes from the passenger side throtle body to the front of the intake, or is it the small one in the back of the intake?
  12. Jun 22, 2010 at 2:08 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    No man, the closest one with a taco is in Chino Hills with you.LOL
  13. Jun 22, 2010 at 2:10 PM
    Natetroknot
    Nate
    Dubuque, IA
    Small one in back. 3/16 I believe, about 6-8 inches long. It's easy to miss, particularly if you didn't receive it from who you scored the intake from.
  14. Jun 22, 2010 at 2:12 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    You know what, now that you mention it, that hose is long,(longer than stock). Reason being that when i removed the k&n intake i didn't have the stock short hose to replace it. I will cut it down today after work and see if that does it. Thanks boss.
  15. Jun 22, 2010 at 3:03 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    I just cut down the line and it's a no go. Any other advice?
  16. Jun 22, 2010 at 3:26 PM
    hwysrfr
    hwysrfr Well-Known Member
    Dennis
    SoCal
    2008 TRD Sport Access Cab
    2" lift Raceline Renegades 17x9, BFG All Terrains 265x70x17 Billet grill with USMC emblem, Redline hood struts
    Did you take out the maf and make sure you didn't break one of thos tiny wires, that will ruin your day.
  17. Jun 22, 2010 at 5:21 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    No I haven't, I guess I should look at it. What should I look out for?
  18. Jun 23, 2010 at 4:22 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    You can pull a spark plug to see if its running too rich/lean. (black=rich, white=lean) One of the symtoms of a malfunctioning MAF sensor. I read somewhere that you can also check voltage at the sensor with a multi-meter, I am not quite sure what voltage it should read but prob. in the 5 volt range.
    I think you may have have bought a bad MAF sensor, especially used on CL. Good luck.. Here's a sparkplug chart : http://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html
  19. Jun 23, 2010 at 7:04 AM
    OCTaco
    OC
    '16 TRD Sport DCSB
    Thanks for the advice but the MAF is actually the stock one that came with the truck. The only thing I replaced was the K&n intake with the stock OEM intake.
  20. Jun 23, 2010 at 7:30 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    that's full of BS right there...
    the OEM intakes on the stock 1GR-FE are exactly the same as on the 4x4 Tacomas...
    tell that master mechanic he needs to learn more about the products he works with cause he's full of sh*t...I know I wouldn't trust him working on my vehicle had he told me that...
