I think im due!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maple85, Aug 1, 2010.
  1. Aug 1, 2010 at 4:23 PM
    Maple85
    Maple85 [OP] Well-Known Member
    Portland Oregon
    Lots to come at some point. Hopefully soon.
    Okay so I have a 2006 Prerunner. Its pretty standard, not a sport or TRD off road. It has 37,000 miles on it and just took her in for a oil change at Jiffy Lube (shame on me lol). Of course they told me my baby is on the verge of death unless I pay them big bucks for my front and back differential service and my transfer case service. As far as im aware I don't even have a front diff right?:confused: So what exactly do i need, how much is it gonna set me back and who should do it? Thanks guys and gals!:)
  2. Aug 1, 2010 at 4:28 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    If you have a rear locker I think Toyota recommends changing the rear diff fluid every 15,000 miles so that might not be a bad idea to have done. If it were me, I wouldn't go back to that place though, they sound like a bunch of crooks who have no business under the hood of a truck. Next thing they'll be charging you for changing halogen fluid in your headlights...
  3. Aug 1, 2010 at 4:29 PM
    Pugga
    Massachusetts
    F-150 Mod
    And no, you do not have a front diff in your prerunner.
  4. Aug 1, 2010 at 4:31 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    Only 4x4s have transfer cases too.
  5. Aug 1, 2010 at 4:38 PM
    747 function > form
    1st Gen.
    OP, if it makes you feel any better, I change my pre's rear diff fluid every 30k...no problems so far *knocks on wood*.
    FWIW, jiffy lube sucks imo...they stripped the oil drain bolt on a car of mine, and inserted a self-tapping bolt w/o disclosing their mistake. Who knows what else they did to that car. Been doing my own fluid changes ever since.
  6. Aug 1, 2010 at 4:56 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    you have no front diff or transfer case...those guys are idiots
  7. Aug 1, 2010 at 5:44 PM
    Maple85
    Portland Oregon
    Yeah its good I walked then! Since I didn't want to do it he said he would give me a deal, The front and back diff plus the transfer case for the price of just doing two! What a joke. Just a simple question on this board and bam I got exactly what i needed. Thanks.
  8. Aug 1, 2010 at 5:53 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    We have to change our halogen? [​IMG] Yikes! [​IMG]
  9. Aug 1, 2010 at 5:56 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Wtf.... you should've said yeah and watch them look stupid haha
  10. Aug 1, 2010 at 5:57 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Yup, sounds like a bunch of idiots.
    No transfer case or front diff on a prerunner. The owner's manual seems to recommend nearly no maintenance for "normal" driving, and almost excessive maintenance for towing, off-road, etc. Most of us fall somewhere inbetween.
    I think that the rear diff is worth doing at least every 30k. I would be especially vigilant if you have the limited slip rearend with clutches to wear out. Mine is a stick, I plan on 30k intervals on the transmission as well. Not sure what the interval is for autos. 50K seems about right on a newer truck, maybe more often if you are towing. 5K on the oil and filter, air filter when needed, plugs every 30-40K.
    Around here it's about 50-60 bucks per diff, gearbox. Auto trans is usually around 100 bucks if you are paying someone to do these things.
    I would recommend you find a real mechanic or do things for yourself. I had a buddy who worked at Jiffy Lube for awhile and I heard lots of stories about cars getting run briefly without oil, then filled with oil and let out the door. There is always going to be the possibility of an encounter with an idiot at any shop you choose. Using a kwikee lube type place drastically increases your chances of finding that idiot. I use the local independent toyota specialist. The owner still works in the shop with his guys and keeps on eye on things. I feel much better taking my truck in there instead of to a corporate run place with managers and techs that may or may not be there next week.
  11. Aug 1, 2010 at 6:01 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Oh, I paid around 350 to have new plugs, oil and filter, both front and rear diffs, manual trans and transfer case fluids changed on mine. Yeah, it's not cheap but I don't like getting gear oil on me anymore.
  12. Aug 1, 2010 at 6:52 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    I just did mine this weekend on my truck. Took me 2 hours since it was my first go around on front, rear, transfer case, and manual transmission. Used Amsoil in all, so should be good for a 100k.
  13. Aug 2, 2010 at 6:18 AM
    Pugga
    Massachusetts
    F-150 Mod
    Transmission oil change is the only one I'll pay a mechanic to do since they have the equipment to backflush the torque converter. May not make a difference but once every 50,000 miles doesn't hurt too much. Everything else is just pull a plug, drain, fill and repeat.
  14. Aug 2, 2010 at 7:10 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    You should take it back to them and tell them you only want the front diff done and then watch them try. I'll bet they charge you for it without doing anything.
  15. Aug 2, 2010 at 7:28 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    file a complaint with the BBB on them. I wonder how many people they actually do scam like that
  16. Aug 2, 2010 at 7:37 AM
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    Way back in the eighties I took my then-new Supra into Jiffy Lube in the Bay Area, and let them change the oil. They also checked the transmission (manual 5sp) and pronounced me good to go. That afternoon I was heading north to SFO on 280 and the car started to whine, then screech, then BANG. The transmission was shelled out- Jiffy Lube had forgotten to replace the plug. After a few days of argument, they finally replaced it, but since then I have always checked them as they go. And I typically know more about my vehicle than they do.
  17. Aug 2, 2010 at 7:37 AM
    OBJMS33
    OBJMS33 Well-Known Member
    san diego
    05-4cyl-4x4
    none
    Sqrew reporting them to BBB. Call the BAR. Bureau of Automotive repair. BBB gives ratings. BAR files lawsuits and conducts arrrests. When I worked a shop. Mentioniong the BAR when complaining to the manager was like calling his wife and his mother. He was good guy too. But did not want to deal with them. Period.
  18. Aug 2, 2010 at 7:42 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
  19. Aug 2, 2010 at 7:55 AM
    OBJMS33
    san diego
    05-4cyl-4x4
    none
    I am actually guilty of letting a car leave the shop dry once. :eek: Anyone can get distracted and make a mistake. Thats why hospitals get sued so much. I would report someone I thought was trying to rip me off from behind the counter. But you cant blame the average tire monkey though. Those jobs are no different then any other entry labor positon. Its in the training. Which I guess is why its good to do your own work when you can.
  20. Aug 2, 2010 at 7:56 AM
    dhurley
    dhurley Well-Known Member
    Doug
    Colorado Springs, CO
    04 Double Cab TRD SR5 V6
    TRD, Snugtop Super-Sport, bedliner, receiver hitch, alarm mod, deck plate mod, AFE Pro-Dry S, Saddleman camo seat covers, TW decal, grey wire mod w/switch, DRL, LED cupholder mod, Dynomax Super Turbo, aux back-up lights, Devil Horns by Andres, "blue plug" mod for 2LO, shorty antenna, Pro Comp fog & driving lights, receiver shackle, 15% tint front windows, stainless nerf bars, Ultra Gauge, diff breather mod
    You should have, that's fun! When I had a 2wd S-15 they told me my power steering fluid was low (I didn't have power steering). I asked them to show me where the reservoir was so I could check from now on. Needless to say, they couldn't find one :D The manager was so embarrased :eek:
