I think I'm overweight
Discussion in 'Towing' started by 2015NoVaTaco, Sep 4, 2017.
  1. Sep 4, 2017 at 5:45 AM
    2015NoVaTaco
    2015NoVaTaco [OP] Member
    Northern Virginia
    2015 TRD Sport 4x4
    I finally got around to having my trailer and truck weighed. I don't think I pulled on the scale right (there was nobody to explain it) but these are the numbers. My guess is that's it's also not balanced right. Please give me your thoughts.
    Steer Axle: 2400
    Drive Axle: 5480
    Trailer Axle: 3700
    Total: 11580
    Car inside weighs about 2900.
    That said, the truck did pretty nice pulling it up and down RT29 to VIR through the big hills in Nelson County Virginia. Had to drop it to 3rd a couple of times but it did OK. IMG_20170904_080924229.jpg
    Toyko Joe and Roland79 like this.
  2. Sep 4, 2017 at 5:48 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I thought you meant you were fat
  3. Sep 4, 2017 at 5:55 AM
    2015NoVaTaco
    Northern Virginia
    2015 TRD Sport 4x4
    I'm consistent with height.
    jpneely likes this.
  4. Sep 4, 2017 at 6:04 AM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    More cardio less carbs!
  5. Sep 4, 2017 at 9:15 AM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    According to Toyota the GCWR is 11,100 pounds so you're a couple of fat guys worth of overloaded. Your truck is supporting 7880 pounds of the total weight which is 50% more than the 5500 pounds it's rated for.
    What stands out to me is your drive axle weight. In short your numbers also don't quite add up. With a weight distributing hitch in your picture and for your truck to sit reasonably level your front axle weight should be close to 4000 pounds.
    2015NoVaTaco[OP] likes this.
  6. Sep 4, 2017 at 1:28 PM
    2015NoVaTaco
    Northern Virginia
    2015 TRD Sport 4x4
    I agree the numbers don't make sense. I wonder if I pulled onto the scales correctly. How much does a short bed double cab weigh? I'm about 200# and probably didn't have more than 100# of gear in the truck.
  7. Sep 4, 2017 at 1:36 PM
    YDCtaco
    YDCtaco Well-Known Member
    Alexandria, VA
    2016 DCSB TRD OR 4x4-Auto
    its mostly water weight
  8. Sep 4, 2017 at 1:42 PM
    coma toy
    coma toy Off Road Taco
    Short for my weight
  9. Sep 4, 2017 at 1:43 PM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    Much does the trailer weigh empty? The car and the truck are about 7300. You and your stuff weigh about? I doubt the trailer weighs 4000...but who knows.
  10. Sep 4, 2017 at 1:44 PM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    The first step to admitting you have a problem is to have a problem.
  11. Sep 4, 2017 at 1:50 PM
    2015NoVaTaco
    Northern Virginia
    2015 TRD Sport 4x4
    That's part of my problem. I don't know. The guy I bought it from said it was about 2400#. All I have in there is a set of wheels/tires ~200# and maybe 200# of tools and miscellaneous junk.
  12. Sep 4, 2017 at 1:52 PM
    Piratefish
    Piratefish Well-Known Member
    Sebastopol
    2011 Tacoma Off Road
    Sadly None
    I'm not an expert on towing, but I have done some. I would not tow that with tacoma. Your right at max
  13. Sep 4, 2017 at 1:53 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Weigh on a CAT scale? Separate platforms for each set of axles...
  14. Sep 4, 2017 at 2:02 PM
    Piratefish
    Sebastopol
    Sadly None
    If I remember correctly my 28' car hauler was 3500lbs
  15. Sep 4, 2017 at 2:14 PM
    2015NoVaTaco
    Northern Virginia
    2015 TRD Sport 4x4
    Yes, it looks like max to me as well. What did you tow your hauler/car with?
    I guess so, but I told the guy I had never done it before and he just said drive on. That front axle number makes no sense, it seems like it would be porpoising all the way down the road. It wasn't. It was obviously heavier than my open car set up (see avatar) but not "bad".
  16. Sep 4, 2017 at 3:09 PM
    Piratefish
    Sebastopol
    Sadly None
    04 f250 diesel 4x4. I didn't even know it was back there. Trailer car and gear 8500 9000lbs. 75 MPH no problem.:thumbsup:
  17. Sep 4, 2017 at 3:10 PM
    Piratefish
    Sebastopol
    Sadly None
    Also there is a towing thread here. I would repost there.
  18. Sep 4, 2017 at 6:23 PM
    2015NoVaTaco
    Northern Virginia
    2015 TRD Sport 4x4
    Isn't this the towing Forum? :)
    Toyko Joe likes this.
  19. Sep 4, 2017 at 6:53 PM
    Piratefish
    Sebastopol
    Sadly None
    Lol my bad :facepalm: Thought I was somewhere else
  20. Sep 4, 2017 at 9:28 PM
    hr206
    Western Washington
    I think a 2nd gen weighs about 4300 pounds - usually that weight is without gas, floor mats, etc. So I'd figure you, your truck + stuff is probably around 4800 pounds. I'd guess your trailer is in the mid to upper 2000's. The front slopes which helps a lot with drag at highway speeds. Since you're so close to the limit and your numbers seem weird it may be worth a re-weigh and/or carry less stuff.
