I think my 2011 rear end was replaced with a LSD mechanical rear differential ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KJaikaran, Feb 10, 2013.
  1. Feb 10, 2013 at 1:31 PM
    KJaikaran
    KJaikaran [OP] Well-Known Member
    Orlando FL
    2011 Tacoma DCSB TRD Sport
    URD intake/maf calibrator, Icon extended travel coilovers, Icon UCA, OME Dakar leaf packs, Bilstein extended rear shocks, 3 degree axle shims, Carrier bearing drop bracket, DS2 retro, 5k HID bulds top and bottom
    2011 DCSB TRD Sport.
    Was in an accident where the other driver clipped my rear tire pushing it back and causing a lot of damage to rear end. Everything was practically replaced for precaution, including rear axle housing and differential.
    I have been getting some weird noise/vibrations in rear end similar to post i have seen with people experiencing the same thing with the 08 and previous models having to add friction modifier.
    So i think i have an LSD rear differential now. Went to change the oil today and noticed the use LSD oil only. Jacked it put the car in neutral and turned on back wheel heard something engage and both wheels are spinning in the same direction.
    So if this is the case i cant believe they would put in the wrong rear end.
    Could this possibly be a good thing ? I have no idea what i can expect with the electronic LSD it has plus possibly a mechanical LSD.
  2. Feb 10, 2013 at 1:40 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Take it back and ask them to verify the correct part number was installed.
    The electronic diff is going to be tied into the ABS and traction control systems.
  3. Feb 10, 2013 at 1:40 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    You scored.
  4. Feb 10, 2013 at 3:28 PM
    KJaikaran
    Orlando FL
    Changed oil and added friction modifier and the weird vibration I was getting while turning slowly is gone.
  5. Feb 10, 2013 at 3:44 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    I would really be smiling if I got a free mechanical limited slip in my Sport Tacoma like that!
    ETA: I think the electronics LSD will only kick in if the mechanical one doesn't. I don't see how it will be a problem unless the electronic tries to kick in first. or some situation where they're fighting against each other. Not sure...
  6. Feb 10, 2013 at 6:03 PM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    score!
  7. Feb 10, 2013 at 6:07 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Thats awesome!
  8. Feb 10, 2013 at 7:54 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Dont say shit to the dealer lol
  9. Feb 10, 2013 at 8:07 PM
    8BoltRacing
    8BoltRacing Custom Fabrication and Performance
    Jared
    Greensburg PA
    The Angry Warthog
    DO 3 hoop, Wheelers HD Leaf Set w/ES poly bushings, OME 884X Coils, 5100's, Selfmade Satoshi, Single beam headlights, Fogs anytime, high beams with low beams mod, ABS kill switch, AMSOIL fluids in everything, K&N Intake, TB Spacer, FAL Electric Fan and TRD Rad Cap, DT Long Tubes, URD Y-pipe w/xtra O2 bungs and 3" v-band , Custom 3-inch Exhaust w/v-band and 3030XL Aero turbine muffler and Aero 3040 tip, URD Fuel Pump Upgrade, B&M Short Shifter, EBC Dimpled and Slotted Rotors with EBC Yellowstuff pads, Pulseplugs, HIDs: Fogs 3000k, Highs 4300k, Lows 8000k, URD Throwout Bearing Repair kit, Fidanza Aluminium Flywheel+Competition Clutch Stage 4
    Lucky dogg.. I would trade my e-locker for a mech LSD in a heartbeat..
  10. Feb 10, 2013 at 8:34 PM
    KJaikaran
    Orlando FL
    lol, I was mad at first with the issues i was having, but i guess it all worked out for the best. If i didn't try and find out the problem and find the post about people having the same issue's with the mechanical differentials in the 08 and previous models that just needed friction modifier i would have ended up back at the dealer trying to let them figure out what the binding noise was and i could have possibly lost the mechanical diff.
    Did some more research and i don't really see a reason for the electronic lsd to cause any issues with the mechanical if its technically working through the abs.
    Feels great to have the truck back !
    Any other way i could confirm without opening it up ?
  11. Feb 11, 2013 at 5:06 AM
    P9HST2
    Iowa
    2012 MGM AC TRD OR
    Jack the rear end up so both rear tires are off the ground and spin one wheel. If the one on the other side goes the opposite direction you have an open differential. If the one on the other spins the same direction you have a limited slip.
  12. Feb 11, 2013 at 5:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This isn't always accurate. My 2000 Tacoma would spin both tires the same direction and it was an open diff.
  13. Feb 11, 2013 at 5:50 AM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    Really? Why? If my truck had a mechanical lsd, i would be driving across state to see you right now!
  14. Feb 11, 2013 at 6:29 AM
    Nacho Muchacho
    Nacho Muchacho Member
    Southern New Mexico
    10 TRD Off Road 4x4
    Toytec OME lift 885 coils and TSB add a leaf. Light Racing upper control arms. CBI Sliders w/ kickouts. 265 75 16 Duratracs. Toyota bed mat and weathertech digifits
    A possible downside is more frequent diff fluid changes.
    I believe the maintenance plan from the manual calls for a 30k mile fluid change for vehicles with mechanical lsd as regardless of normal use versus severe use. This may be due to the friction modifier breaking down because of shearing of the fluid.
    In contrast, I think the plan suggests 30k mile change for e-lsd for severe use only and an extended fluid change for normal use.
    Don't quote me on this, however. I am away from my vehicle and can't confirm the manual states this.
  15. Feb 11, 2013 at 7:04 AM
    KJaikaran
    Orlando FL
    Yah, I read up on it and they said it doesn't necessarily mean you have a mechanical LSD if both tires spin in same direction. So now i'm wondering how else i could check without opening it up.
  16. Feb 11, 2013 at 7:05 AM
    KJaikaran
    Orlando FL
    First thing i actually did. Both spun in same direction, but it seems like its not an accurate way of checking.
  17. Feb 11, 2013 at 7:45 AM
    P9HST2
    Iowa
    2012 MGM AC TRD OR
  18. Feb 11, 2013 at 7:49 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    I'd just go ask the dealer... Maybe they thought all tacoma sports had lsd diffs even though it ended in 08'.
  19. Feb 12, 2013 at 7:36 AM
    8BoltRacing
    Jared
    Greensburg PA
    The Angry Warthog
    In the 5 years ive owned her ive never taken it off-roading.. I would like to sometime but nothing serious just to ride some trails and such. I rarely ever get into a situation that calls for me to lock the diff (and having the LSD would probly solve that problem before it happens)..I do it now and then just to cycle it and make sure it still works. I would much rather have a full time LSD that turns both.
  20. Apr 14, 2013 at 4:58 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    You scored dude! I feel 08' was the last of the best, not that the newer trucks are bad ( there not) just more electronic garbage. Good deal, rock that mechanical rear for sure.
    Thanks ,
    Brett
