I think my 5100s are at the wrong setting!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bobbybreach, Aug 12, 2013.
  1. Aug 12, 2013 at 4:51 PM
    bobbybreach
    bobbybreach [OP] Well-Known Member
    bobby
    westchester NY
    09 TRD
    I had 5100s installed at 1.75" and I measured the before and after and it only raised it 1". Can someone post pics of there 5100s at the 1.75" while it's actually installed on the truck. I want to see if it's on the correct notch. I'm at work and can't take the pic of it myself. I have a DCSB if that helps with ideas.
    Thanks
  2. Aug 12, 2013 at 4:54 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Measure from bottom fender to center hub.
  3. Aug 12, 2013 at 5:07 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  4. Aug 12, 2013 at 5:11 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, you don't need to see anyone else's shocks, just look at your own and count the notches.
  5. Aug 12, 2013 at 5:19 PM
    bobbybreach
    bobby
    westchester NY
    09 TRD
    It's the second one down from the top
  6. Aug 12, 2013 at 5:22 PM
    Pugga
    Massachusetts
    That should be 1.75, perfect.
  7. Aug 12, 2013 at 5:24 PM
    bobbybreach
    bobby
    westchester NY
    09 TRD
    Wow. Any reason why it only raised it 1" instead of 1.75"
  8. Aug 12, 2013 at 5:31 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I think the 1.75" is a fair estimate but on an access cab maybe. On my RC I got 1.1" from the .84 setting alone. Also do you have a winch or heavy bumper?
  9. Aug 12, 2013 at 5:53 PM
    bobbybreach
    bobby
    westchester NY
    09 TRD
    It's a 09 DCSB. No winch or heavy bumper. On flat ground from hub to fender I gained 1". It went from 20" to 21". I measured it on the same flat ground before and after and I used the same measuring tape as well. I'm thinking I should go up to 2.5". Cause my rear is 23.5" with the AAL. The prob is I really don't want to spend $700 on UCLs. I'm might risk it. I've seen a lot of ppl do it with out the UCAs and it was fine. And the other half had problems. Not sure what to do. Advice?
  10. Aug 12, 2013 at 6:03 PM
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    LR UCAs are ~$400. I had my 5100s set @ 2.5", alignment was terrible.
  11. Aug 12, 2013 at 6:09 PM
    bobbybreach
    bobby
    westchester NY
    09 TRD
    If I added a 1/2" spacer to the 1.75" will I have to get UCAs? And another alignment?
  12. Aug 12, 2013 at 6:15 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    1/2" spacers will give you about another inch of lift, totaling about 2". You should be fine without UCAs. You should get another alignment though.
  13. Aug 12, 2013 at 6:45 PM
    bobbybreach
    bobby
    westchester NY
    09 TRD
    Ok that's not bad. At least I won't have to do UCAs and my ride hight will be a lot closer. I don't mind rake, I just want less of it
  14. Aug 12, 2013 at 6:50 PM
    bjboucher
    Brad
    San Antonio, Texas
    There's still no guarantee you won't have alignment issues but you should be fine. 2.5" is usually where you start running into issues. There are folks with 3" lifts and no issues on stock UCAs though. Seems really hit or miss.
  15. Aug 12, 2013 at 8:54 PM
    Spruce12
    Spruce12 Member
    why would 2.5 inch cause a problem? what kinds of problems would it cause?
  16. Aug 13, 2013 at 4:02 AM
    bjboucher
    Brad
    San Antonio, Texas
    An alignment that is not within specs and premature tire wear. Not sure if a bad alignment wears other things out too, I would imagine it could.
  17. Aug 13, 2013 at 4:14 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    and will cost you another $400 in repairs or bushings and basll joints over a 10 year period.....
  18. Aug 13, 2013 at 8:32 AM
    OZ-T
    Peter North
    British Columbia
    Why don't you buy different UCA's ?
  19. Aug 13, 2013 at 8:33 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    Working on it
    Just dont have your kinda cash
  20. Aug 13, 2013 at 8:36 AM
    OZ-T
    Peter North
    British Columbia
    :rolleyes:
