I think my front shocks are topping out
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Junkhead, Feb 27, 2023.
  1. Feb 27, 2023 at 4:20 PM
    #41
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Glad someone said this... Sure looks like the shock took a shat.
    908tacoma likes this.
  2. Feb 27, 2023 at 4:21 PM
    #42
    Junkhead
    Junkhead [OP] TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Thanks.
    Interesting that you said that peeps with OME suspension on their trucks have got the same clunk/thud.
    Im definitely going to jack up the front of my truck and see wth is happening. If like you said it wont take much to lift my tires off the ground then everything will make perfect sense to me. Limiting straps would help right? But then I’ll have even less downtravel?
    Also, why didn’t they make the shock 2” longer, wouldn’t that fix the “topping out” issue?
    Learning quite a bit over here.:)
  3. Feb 27, 2023 at 4:22 PM
    #43
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    Dude. It’s fluid film.
  4. Feb 27, 2023 at 4:24 PM
    #44
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    by heavier I meant that they are intended to lift the vehicle ride height.. a higher spring rate vs stock
    not physical weight of the springs
  5. Feb 27, 2023 at 4:27 PM
    #45
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    Thanks for advice man.
    Won’t be picking up my truck till
    The weekend, will measure them.
  6. Feb 27, 2023 at 4:27 PM
    #46
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    your shocks might not have enough valving for the spring rate if it's been doing it since new. sounds like you need more rebound damping.
    Junkhead[OP], Fast1 and 908tacoma like this.
  7. Feb 27, 2023 at 4:27 PM
    #47
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    No they are actually lower spring rate. Stock is like 730 I believe, these are 650.
    71tattooguy likes this.
  8. Feb 27, 2023 at 4:27 PM
    #48
    Fast1
    Minneapolis, MN
    limiting straps are not going to solve the problem.. longer shocks are going to bind the front drive line, have the upper a-arms hit the coil at full droop.. etc.. watch the video very closely.. it is an excellent resource
    Junkhead[QUOTED][OP] likes this.
  9. Feb 27, 2023 at 4:28 PM
    #49
    Fast1
    Minneapolis, MN
    stock is less than 650
    730 is way over sprung for a stock Tacoma,,, just facilitates a quicker top out..
  10. Feb 27, 2023 at 4:28 PM
    #50
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    This kit was designed to work together tnough? I don’t get it.
  11. Feb 27, 2023 at 4:29 PM
    #51
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    :notsure: is there a way to reduce preload?
    Fast1 likes this.
  12. Feb 27, 2023 at 4:30 PM
    #52
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    You must’ve been in some Tacoma’s with either poorly installed components or ones with wrong coil/shock combos for the weight. Nitrochargers are great shocks and can handle down travel, up travel and everything in between better than many others. Our shop has installed tons of OME on Tacoma’s, as well as others, with nothing you mention ever occurring.
    Junkhead[OP] likes this.
  13. Feb 27, 2023 at 4:31 PM
    #53
    Fast1
    Minneapolis, MN
    what should the down travel be on that suspension package with a 2" ride height over stock on a factory 3rd gen 4 door V6?
  14. Feb 27, 2023 at 4:32 PM
    #54
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    My shocks are not adjustable, so I would say no? Orr I could just add a huge steel bumper:)
  15. Feb 27, 2023 at 4:34 PM
    #55
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    :goingcrazy:
  16. Feb 27, 2023 at 4:35 PM
    #56
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    Approximately 2”, did I win?
    Fast1[QUOTED] likes this.
  17. Feb 27, 2023 at 4:37 PM
    #57
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’ve never driven a vehicle that didn’t make a thud sound when hitting a sufficiently large enough bump. The sound you are hearing might be normal and nothing to worry about.
    How do you know that hitting your max downtravel makes a thud sound? Have you jumped your truck off the ground and heard the same sound after lift off but before landing?
    You can measure your down travel very simply by measuring the distance between the center of your hub to your fender flare at ride height and when the front end is jacked off the floor and then subtracting the two.
    As I understand it, OEM and OEM replacement shocks are designed to “top out” and have a quasi bump stop inside the shock. The forces of topping out the shock are much more limited than those from bottoming out the shock, thus there is an external bump stop to precent the shock from bottoming out.
  18. Feb 27, 2023 at 4:43 PM
    #58
    Fast1
    Minneapolis, MN
    Depending on the wheel offset and tire width this might not be accurate because from the center of the hub up to the fender flare requires the tape measure to bend around the tire side wall. I specifically tried this method and found that issue. If you have a straight line going up from the center of the hub to the fender, it may work. Mark each point with a piece of tape so you don't deviate your two from the two end points.
    Shock measurement will be the most accurate.
  19. Feb 27, 2023 at 4:47 PM
    #59
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    It depends if you have any added weight. Especially up front. You never answered if you are on stock bushings or the OME 3133. I would hope the latter
  20. Feb 27, 2023 at 4:48 PM
    #60
    gudujarlson
    Minnesota
    Measuring the shock is a PITA and the result still needs to be multiplied by motion ratio to get the down travel. The hub to fender is easier and will get us to within +/- 0.25” I guesstimates.
