I think my front shocks are topping out
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Junkhead, Feb 27, 2023.
  1. Feb 27, 2023 at 5:28 PM
    #81
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    1000% right.
    Junkhead[QUOTED][OP] likes this.
  2. Feb 27, 2023 at 5:31 PM
    #82
    Junkhead
    Junkhead [OP] TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Isn’t it approximately 4” up and 4” down stock?
    908tacoma likes this.
  3. Feb 27, 2023 at 5:31 PM
    #83
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Do you understand who makes the factory springs for the TRD yellow Bilstein shocks on the 3rd gen?
    Suggest you contact the manufacture of the factory suspension and get educated about the spring rate placed on new factory TRD Tacoma.
  4. Feb 27, 2023 at 5:31 PM
    #84
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Here's what I tell myself when I hear random noises on my truck...
    "Ignore it until something breaks. Once it's broken, it will be much easier to find."
  5. Feb 27, 2023 at 5:33 PM
    #85
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    yes, approximately. With variables. I quoted a post based on a 3 inch lift which I believe is causing mass confusion here. My apologies
  6. Feb 27, 2023 at 5:36 PM
    #86
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    yes, which is of no relevance here since the OP is not running bilstein shocks but OME. Spring rates on newer OME coils with “x” on the product description are completely different than what you are referencing.
  7. Feb 27, 2023 at 5:36 PM
    #87
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I think the confusion is that "down travel" typically means the amount of suspension travel between ride height and full droop, not the full suspension travel between full bump and full droop.
  8. Feb 27, 2023 at 5:37 PM
    #88
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    I am in total agreement here
  9. Feb 27, 2023 at 5:40 PM
    #89
    Fast1
    Minneapolis, MN
    it is if you throw a 700lb/in spring on a truck that has no extra weight. You will end up with a top out contraption that the shock rebound can not control and rides like $hit.
  10. Feb 27, 2023 at 5:46 PM
    #90
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    But I’m running OME 590 pound spring.
    908tacoma and FloridaFree like this.
  11. Feb 27, 2023 at 5:46 PM
    #91
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    Haha!
    Well it’s been fine for a year, nothing broke. Yet…
    Bertw192[QUOTED] likes this.
  12. Feb 27, 2023 at 5:47 PM
    #92
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    I can live with it as long as nothing breaks.
    Rock Lobster[QUOTED] likes this.
  13. Feb 27, 2023 at 5:48 PM
    #93
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    where are you getting 700 from? The 887 are 400mm in height with a 590 pound spring rate???
    FloridaFree and Junkhead[OP] like this.
  14. Feb 27, 2023 at 5:50 PM
    #94
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    Yes.
    908tacoma[QUOTED] likes this.
  15. Feb 27, 2023 at 5:50 PM
    #95
    908tacoma
    New Jersey
    2018 MGM
    OME, SPC, TRD
    check your bushings! OME 3133 work wonders
  16. Feb 27, 2023 at 5:55 PM
    #96
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    Hm, thanks for advice sir. I’ll check them out.
    Is the install straight forward?
  17. Feb 27, 2023 at 6:00 PM
    #97
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    Sway bar links worn out?
  18. Feb 27, 2023 at 6:41 PM
    #98
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
  19. Feb 27, 2023 at 6:41 PM
    #99
    Junkhead
    Serge
    Prince George, BC
    Some Serious Tires
    No sway bar sir. Did exactly the same with the sway bar.
  20. Feb 27, 2023 at 6:43 PM
    #100
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    The front IFS only has about 4.5” of shock stroke. Lots of people like to to reference tire travel but it’s misleading. Ideally your ride height would be in the middle with 50/50 up and down travel which is basically 2.5” up or down. Without changing geometry a 2” lift would theoretically make it 4” up and .5” of down travel. I don’t know how ARB configured their strut but surprised this wouldn’t have come up before.
    That said I’ll occasionally thud my kings when dropping off rocks and stuff so it happens and I have maybe 3” down travel.
    ARB has a sleeve so can’t tell how much of the shock rod is exposed to measure.
    Bertw192, Junkhead[OP] and 908tacoma like this.
