I think my fuel mpg has gotten worse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ob1-adobe, Apr 24, 2021.
  1. Apr 24, 2021 at 12:35 PM
    Ob1-adobe
    Ob1-adobe [OP] Well-Known Member
    2019 Tacoma TRD Off-Road DCSB Magnetic Gray
    Maybe I’m crazy but I think my fuel economy has gotten drastically worse. I usually get 21 mpg on the high way, now I’m getting 18.
    stock tires
    Stock psi
    No mods
  2. Apr 24, 2021 at 12:43 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    how far and fast are you driving when you're getting these measurments?
    Is your speed consistent, CC, step on the gas to pass someone? etc etc..
    I drive the same route to work everyday on the freeway, some days i can get 24mpg, other days i can get 18-19mpg, all depending on how i drive.
    the.sight.picture and SJBrown like this.
  3. Apr 24, 2021 at 12:44 PM
    tedusmc1345
    tedusmc1345 Well-Known Member
    ted
    2018 Tacoma Sport 4x4
    Oil change helps too
  4. Apr 24, 2021 at 12:45 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Wind direction is a major factor for these rolling bricks.
    4×4×4, shakerhood, GBR and 9 others like this.
  5. Apr 24, 2021 at 12:49 PM
    Ob1-adobe
    60 mph, maybe 70 for a couple seconds. Usually I get 21 mpg, but lately 18.
    im making an appointment to get the fuel pump recall done, maybe they can check it out, maybe they won’t.
  6. Apr 24, 2021 at 2:21 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Absolutely!
    I just took the work F150 down to the farm, and headed back today. 80 of the110 miles in to a decent 10-15 mph wind, so I got about 2-3 less than usual.
  7. Apr 24, 2021 at 2:27 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Clean the maf, maybe (perked mine right up even if it is still the slowest vehicle on the Planet)
    Hooper89 likes this.
  8. Apr 24, 2021 at 2:28 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Check your air filter.
    Also, this goofy predictive software changes up how the engine responds from time to time. It seems like it takes a solid month of granny driving before you get good mileage.
  9. Apr 24, 2021 at 2:31 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Do you log it? I have logged my tank fills in every car I’ve owned and that allows me to track mileage to behavior to winter mix to conditions with much accuracy and trend.
  10. Apr 24, 2021 at 2:33 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Just drive! I try to maintain 80 in SoCal and get 18.8 all day long.
  11. Apr 24, 2021 at 2:35 PM
    Hofmann’s Tacos
    Hofmann’s Tacos Professional Asian
    Nor Cal / South FL
    2020 off-road 6MT (SFOB 2.0)
    SFOB 2.0
    Apparently these trucks foul the spark plugs quite quickly, might wanna check those too
    Steves104x4 likes this.
  12. Apr 24, 2021 at 3:00 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Tighten the air intake ducting, a smidge. Switch out the rear diff oil. Check parking brake cable
  13. Apr 24, 2021 at 3:14 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Put your wallet in you opposite pants pocket and trim your eyebrows that got me an extra 1mpg.
  14. Apr 24, 2021 at 4:40 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Well if i'm heavy on the go pedal my fuel milage will dip to under 20 mpg.
    Junkhead likes this.
  15. Apr 24, 2021 at 6:34 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You are forgetting paint wax, the truck will glide smoother trough the air, another 1 mpg right there.
  16. Apr 24, 2021 at 6:34 PM
    f86sabjf
    f86sabjf Well-Known Member
    Jeff
    Deltona, Florida
    2020 Trd sport
    I avg 19.5 in flat florida running 70-75 . I’ve noticed it also depends on the vehicle your following .
  17. Apr 24, 2021 at 7:36 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Disconnect the battery for a while and see if a reset sorts it out, or if your crazy.
    Junkhead and Hofmann’s Tacos like this.
  18. Apr 24, 2021 at 8:00 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    get it tuned!
  19. Apr 24, 2021 at 8:07 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Find an independent mechanic with a deluxe scan tool that does more than checking CEL codes. It can tell you if your injectors are dirty , it’s running too rich, the cat is clogged, etc.
  20. Apr 24, 2021 at 8:21 PM
    A Florida Man
    A Florida Man Well-Known Member
    NW Florida Gulf Coast
    ‘13 Tacoma Limited Double Cab
    Bought my ‘13, 4.0 double cab, five weeks ago. Tracked in town mileage for 125 miles: 15 mpg. Today, drove west on I-10 against strong winds and back, 100 miles total= 22 mpg. But I don’t give a crap...glad to have it no matter the mileage. Don’t plan on long trips in it.
