I think my truck is stuck in 4x4...help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by briandischinger, Feb 12, 2012.
  1. Feb 12, 2012 at 9:14 PM
    briandischinger
    briandischinger [OP] Member
    brian
    inland empire
    03 4x4 trd v6
    Sorry, I know this sounds weird but I just bought an 03 ext cab 3.4 trd, the indication light for the 4 wheel drive doesn't come on when the button is depressed, I also don't feel any difference in the driving when i switch on the 4wd. if anybody out there has a 3.4 4x4, are the rpm's supposed to be at 3000 while going 80 on the freeway? :rolleyes:
  2. Feb 12, 2012 at 9:17 PM
    fadippides
    fadippides Well-Known Member
    NEPA
    12 TRD Off Road
    Whats it do when you turn a sharp corner?
  3. Feb 12, 2012 at 9:24 PM
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    x2.
    If you turn a corner in 4x4 on dry pavement you will feel everything bind up.
    I am thinking more so that you are not stuck in 4x4, but you cannot engage it for some reason.
    I don't know much about the RPMs on the 1st gens at certain speeds, but I can't imagine that you are too far off from the norm.
  4. Feb 12, 2012 at 9:34 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    if the light does not come on and you dont feel any shuddering or binding when turning tightly then the 4wd is not engaging, not stuck in 4wd. go into a soft dirt lot, try to put it in 4wd an floor it, you will know if you have 4wd or not then you can go from there. my 4cyl auto reves at about 75 when doing 70ish, i would imagine 80 could be pushing 3k. also may seem obvious but make sure over drive is off, if you have high revs that may be the reason if you dont notice it
  5. Feb 13, 2012 at 10:45 AM
    briandischinger
    brian
    inland empire
    03 4x4 trd v6
    Thanks guys, i was just wondering if it was normal for the truck to have the rpm's that high under normal conditions (2700 @ 75mph) if that sounds right then I need to look into why the 4wd is not engaging in 4 high... I can definitely feel it when i put it in 4 low.
