I think this is the lift I want...Toytec Ultimate
Discussion in '1st Gen. Tacomas (1995-2004)' started by veg hed, Jul 4, 2010.
  1. Jul 4, 2010 at 2:48 PM
    veg hed
    veg hed [OP] Well-Known Member
    Grand Teton, WY
    04 Toyota TRD SR5 V6 Access Cab
    Bilstein 5100s, Toytec 620 springs, OME Dakar Leafs, ARB Bumper, Warn 8000 Winch, Grey Wire Mod.
  2. Jul 4, 2010 at 2:53 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    That is a great lift. If you want 2" you can use a spacer, 5100's, or just set the ultimate kit to 2".
  3. Jul 4, 2010 at 3:03 PM
    veg hed
    Grand Teton, WY
    Does that mean I need to do an AAL in the rear? 5100's all around? What spacer would I use?
  4. Jul 4, 2010 at 3:10 PM
    Chad
    Chad Well-Known Member
    Chad
    Raleigh, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- BHLM -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- 09+ Access Cab Rear Headrest Removal
    I believe Toytec has a 2" spacer lift. I think you could just bump the 5100s up and use just the stock coils.
  5. Jul 4, 2010 at 3:29 PM
    veg hed
    Grand Teton, WY
  6. Jul 4, 2010 at 3:32 PM
    veg hed
    Grand Teton, WY
  7. Jul 4, 2010 at 10:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Wait. Why would you use spacers on the front if you are going with 5100s?
    The 5100s are adjustable to 2.5". Use your stock coils with them.
  8. Jul 4, 2010 at 10:23 PM
    Finks99Taco
    Finks99Taco Well-Known Member
    'Fink'
    Coconut Creek, Florida
    1993 pickup
    I'm buying that lift as soon as I get the bank to increase my credit line.
    I looked under the Toytec vendor section and I believe he posted they were back in stock but on their website it still says backorder so I'm not sure.
    EDIT: I lied...the 5100's are for the '05+ =(
  9. Jul 4, 2010 at 11:32 PM
    veg hed
    Grand Teton, WY
    So then 5100s up front adjusted to 2.5 and an AAL in the rear? Will this give me a level 2" lift all around?
  10. Jul 5, 2010 at 12:29 AM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    back order is for the leaf packs i believe........ i am getting ready to pull the trigger on the ultimate with LR UCA's, the ome dakar leaf paks. waiting on some reply's from toytec before i purchase....I will be so happy to get rid of the revtec spacers and 1.5" AAL....
  11. Jul 5, 2010 at 9:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It is always somewhat of a crap shoot as to where you will end up. But yeah, I think with the billies set for 2.5 and using your stock coils you'll end up somewhere in that neighborhood. 2-2.5" higher in front. What shape are your rear leaf springs in now? How many miles on them? Do they have a positive arch? Flat? or Negative arch (frown)?
  12. Jul 6, 2010 at 8:19 AM
    veg hed
    Grand Teton, WY
    My 2004 only has 28,000 original miles on it. It used to belong to a female doctor who did not beat it up...So the rear springs are still in good shape. So will an AAL in the rear set me up a level 2" if I put 5100s all around and set the fronts to 2.75". This might be a less expensive way to do what I want.
  13. Jul 6, 2010 at 9:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
    With hat low a mileage on the springs, I would say go for it. The progressive TRD coils will eventually sag a little bit but the 5100 set at the top is a much better option that putting a spacer on top of those coils. In the rear, the stock springs will likely see the full benefit of the 2" AAL. Maybe even a little bit more.
