I thought OME was a "small lift"
Discussion in 'Suspension' started by 6spdtaco, Aug 4, 2010.
  1. Aug 4, 2010 at 9:52 PM
    6spdtaco
    6spdtaco [OP] Well-Known Member
    Nate
    East Wallingford, VT
    Taco
    Tom Woods driveshaft. TRD short throw shift kit. TRD exhaust. AFE Stage II intake. CBI Bumpers front and rear. Warn 8000i winch/ synthetic line. OME 3" lift w/ dakar springs and 886 coils. ATO Front skid. ARE MX cap. Trail Team FJ wheels. Cooper Discoverer ST 265/75-16 C tires. Diff breather relocation mod.
    I just finished installing my OME kit on the front end. I was expecting 2.5-3". I ended up with 4.25" from stock height. Haven't finished the rear end because I was in need of new leaf spring bushings. Do these measurements seem off to anyone else? Not that I mind a taller ride but I have concerns about alignment issues.
  2. Aug 4, 2010 at 9:53 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    you add on new tires at all? yea that seems a bit off to me.
  3. Aug 4, 2010 at 9:53 PM
    SoCalBlack08
    SoCalBlack08 Well-Known Member
    CA
    08 PreRunner DC
  4. Aug 4, 2010 at 9:54 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    thats not righttttt. how are you measuring lift. Ground to bottom of fender? hub to fender? Hub to fender should be around 23
  5. Aug 4, 2010 at 9:54 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    x2 , seems like a lot unless you put on bigger tires at the same time .
  6. Aug 4, 2010 at 9:54 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    not that im a proffesional or anything but i heard that it takes a little while for them to settle.
  7. Aug 4, 2010 at 9:56 PM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    What springs do you have?
    Any top spacer?
  8. Aug 5, 2010 at 9:54 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    OME?? bit vague..what springs..? 884, 885, more?
  9. Aug 5, 2010 at 10:34 AM
    6spdtaco
    Nate
    Taco
    I've got the 886 coils because of winch/CBI bumper.
    No additional spacers.
    I have stock 16x8 wheels with 265/75 tires.
    I measured my stock height and the lifted height from the top of the rim straight up to the bottom of the fender.
    Hopefully these pics work. Do the angles of the CV and control arms seem too steep?
  10. Aug 5, 2010 at 10:35 AM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    looks about right. Mines settled quite a bit over the last year. I could see most of the UCA after i did it.
  11. Aug 5, 2010 at 10:36 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Your CV's are at a bad angle and your stock UCA's are almost maxed out.
  12. Aug 5, 2010 at 10:37 AM
    FlawedXJ
    Paul
    NorAla
    Those 886's are pretty darn stiff. I have 885's and have about maxed out the UCA. I would consider some new ones at some point if your really gonna wheel. Not to mention you probably wont be able to get your alignment right.
  13. Aug 5, 2010 at 10:45 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Yeah those UCA's dont have much room to move...seems like you have a big gap between tire and bottom of fender flare. Cant really see your whole CV, but it does look like the fins are touching pretty good...
  14. Aug 5, 2010 at 11:08 AM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    You sure you installed everything correctly. What about the diff drop-do you have one?
  15. Aug 5, 2010 at 11:15 AM
    aficianado
    back to bone stock.
    wow. that is riding high!! was that pic taken right after taking the truck off of the jackstands? if so, i promise it will go down a bit.
  16. Aug 5, 2010 at 11:31 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    do the spring perches on the OME shocks come apart... are they detached prior to install?
    because they look upside down...which could be the cause of your problems...
  17. Aug 5, 2010 at 12:32 PM
    6spdtaco
    Nate
    Taco
    I had the shop where I purchased the lift reassemble to springs for me so I hope they are assembled right.
    The truck hasn't been moved in this picture so the height is right after it got off jackstands. It hasn't "settled in yet".
    I didn't do a diff drop b/c I was told by the local shop I bought the kit from that I wouldn't need one.
  18. Aug 5, 2010 at 12:33 PM
    FlawedXJ
    Paul
    NorAla
    I'm gonna go ahead and say they are wrong on that one.
  19. Aug 5, 2010 at 12:36 PM
    6spdtaco
    Nate
    Taco
    I have no problem doing a diff drop. Do you think that will resolve all the issues of too much lift or just part?
  20. Aug 5, 2010 at 12:39 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    What they should look like.
    OP, FWIW I had over 4" on my billies until it settled. With in a week it was at the expected ride height.
