I threw 2 crank rods 1GRFE @ 185k
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bobsuruncle, Nov 18, 2018.
  1. Dec 17, 2018 at 10:25 AM
    #201
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Did you check the tensioner?
  2. Dec 17, 2018 at 11:46 AM
    #202
    bobsuruncle
    bobsuruncle [OP] PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    It seems to be functioning correctly. It returns all the way without the belt on it and spins smooth.
  3. Dec 18, 2018 at 10:38 PM
    #203
    Taco47
    Taco47 Well-Known Member
    Norcal
    2016 2TR 5-Speed
    I had the fan and shroud off the last time I changed my belt which helped me sight the fit.
  4. Aug 29, 2019 at 4:08 AM
    #204
    Tnronin
    Tnronin Two things in this world smell like fish!
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    I believe I just did this. Dang. Is there a write up on the?
  5. Aug 29, 2019 at 4:54 AM
    #205
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Unbolt pulley. Pry out old seal. Grease inner swipe of new seal. Tap back in. Align and bolt down pulley.
    bobsuruncle[OP] and DocME like this.
  6. Aug 29, 2019 at 7:40 AM
    #206
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    It’s easy. Happened to me.
    bobsuruncle[OP] likes this.
  7. Aug 31, 2019 at 6:26 AM
    #207
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Do you have a flow of oil coming from behind the crank pulley while the engine is running?
    Step 1: buy new front crank seal and new serpentine belt.
    Step 2: remove or cut off old serpentine belt.
    Step 3: use an impact gun to remove crank bolt if room allows, otherwise the breaker bar against the frame and bump the starter trick will do.
    Step 4: remove pulley. It may need some persuasion, mine slid right off.
    Step 5: extract old seal. Seal picks are your friend or needle nose pliers and just mutilate it, just be careful not to score the crank shaft or the area where the seal seats.
    Step 6: find a socket or similar diameter object and gently tap the new seal into place with a rubber mallet. Make sure it goes in equally the entire circumference of the seal and not cocked or it won't seal correctly and you may damage the new seal. A finger of grease around the outside edge will help.
    Step 7: reassemble crank pulley and install new serpentine belt. The crank bolt is tq'd to 175ft/lbs iirc. I'm sure someone will correct me if I'm wrong.
    You'll need a crank pulley holder or something similar to properly tq the bolt without turning the engine over.
    Shouldn't take more than an hour and is easily accessible when the skid plate is removed.
    TacoLeeSD and Torspd like this.
