I tried search but didn't find anything. 16" vs 17" wheels
Discussion in 'Wheels & Tires' started by babytruck, Oct 11, 2011.
  1. Oct 11, 2011 at 3:07 PM
    babytruck
    babytruck [OP] Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    What would be the advantage of either?
    -OR-
    Why would a person choose one over the other?
    2nd gen AC.
  2. Oct 11, 2011 at 3:08 PM
    KingMoo
    KingMoo Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    looks.
    cost?
  3. Oct 11, 2011 at 3:09 PM
    canyonchaser
    canyonchaser Duae Rotarum per Sempre
    Dave
    Salt Lake City
    08 Tacoma Double-Cab TRD Sport
    I'm swapping down from 17's to 16's because 16" tires are quite a bit cheaper
    dp
  4. Oct 11, 2011 at 3:16 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    17s less likely to have brake caliper clearance issues.
    Lower profile series 17" tires will handle a little crisper on the street.
    Higher profile series 16" tires will protect the rim a little better and be able to air down a little lower to a slightly larger contact patch for offroad.
    It's not a big difference either way.
  5. Oct 11, 2011 at 4:41 PM
    S.S.T.
    S.S.T. Well-Known Member
    Torrance, CA
    07 TRD Off Road Access Cab
    Icon 2.5 Extended Travel Coilovers, 5100 rears, Icon Progressive 3 leaf AAL, Hankook Dynapro ATM 265/75R16, 16x8 Renegade 6 wheels, AFE Pro Dry S air filter, BHLM.
    Something to consider is what tires come in what load range. For instance if you wanted Load D KM2s in a 285: 285/75r16 come in load E only and 285/70r17 come in load D only.
    All the aforementioned are also true.
  6. Oct 11, 2011 at 5:19 PM
    babytruck
    NorCal
    Okay I'm a virgin to all this load stuff. I've had this truck for as long as 3,000 miles and I truly don't understand what you are saying here. :confused: Please explain? :eek:
    The tire size I was looking at was 265/70R/17 on 17x9.
  7. Oct 11, 2011 at 5:35 PM
    babytruck
    NorCal
    OoooooOOooooOooo I get it now!!! :) Thanks!
    (So how do I know what load I need?)
  8. Oct 11, 2011 at 5:38 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    you will want a d load range thats what most people have
  9. Oct 11, 2011 at 7:25 PM
    babytruck
    NorCal
    So which is softer with less layers, D or E? Oh wait. So is D softer because if the larger tires have D, that means less sidewall which means they are stiffer from the get go, right?
  10. Oct 11, 2011 at 7:26 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Some guys running LT had some issues rubbing their UCAs on the inside of the 16" rims. Thats why I went with a 17. 16's are definitely cheaper tires.
  11. Oct 11, 2011 at 7:30 PM
    babytruck
    NorCal
    Kewl link, Whipper. Thanky. :)
    So back to wheel size. So most feel that 16s can or might be risky in regards to brakes. So me going 17 would be best, right?
  12. Oct 11, 2011 at 7:32 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Just be sure not to generalize this.
    Generally, tires for 17" rims are going to be a higher load rating and ride rougher because of it. Tires for 16" rims are generally going to be a lower load rating and ride a little better because of it.
    I had MTZ's on my 2007 Sport, 17" rims, and they were Load Range E. If I had 16" rims, I could have gotten them in Load Range D.
    D is going to be softer simply because of tire construction; they're not designed to take as much weight, so they don't need to be as rigid.
    The more sidewall you have the better, regardless of the tire rating.
    Fink
  13. Oct 11, 2011 at 7:37 PM
    Ripcord
    Ripcord KM6PIM
    Jim
    SoCal
    13' DCSB TRD-OR Spruce Mica
    I went up from 16's to 17's for brake clearance on the tundra brakes. 17 is the absolute max I would go.
    I have 285/70/17 D Duractracs and it rides just fine, I noticed a bit of a difference from the D rated 285's and 16's, but not much.
    I don't ever plan to get E's though, always hear people complaining about them riding stiff.
  14. Oct 11, 2011 at 7:39 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    17s look cooler, less sidewall so it may ride rougher than 16s, but doubt it'd noticeable. 17s may cost a little more, be wider, or have different offset.
