I tried to tow and it sucked
Discussion in 'Towing' started by Komrade, Sep 5, 2018.
  1. Sep 17, 2018 at 12:59 PM
    #41
    la0d0g
    running for the hills
    For crawling not hauling
    :laughing: at towing anything consistantly with a Tacoma.
    jethro likes this.
  2. Sep 17, 2018 at 1:00 PM
    #42
    96carboard
    96carboard Well-Known Member
    Judging by your avatar, yours really isn't outfit for towing, so I'm sure that your experiences are not representative.
  3. Sep 17, 2018 at 1:01 PM
    #43
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    That trailer was 2800lbs, it didn't need a load distribution hitch since it wasn't even remotely heavy. The weight of the trailer isn't the only factor like I said. The truck doesn't have enough wheelbase to tow big trailers, period. So I bought a truck that can tow.
    Right, exactly right. And it's a huge benefit to have more wheelbase and weight.
  4. Sep 17, 2018 at 1:02 PM
    #44
    GREGSBSPTACOMA
    GREGSBSPTACOMA Well-Known Member
    Greg
    Phoenix,AZ
    4runner
    The day I towed with my 2012 tacoma 6speed was the day I decided to sell it the gearing just did not do well with towing. my 2006 auto handled it no problem though.
  5. Sep 17, 2018 at 1:03 PM
    #45
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    LDH help with control/sway no matter what load your towing, even with a 1/2 ton with a 5.3L.
  6. Sep 17, 2018 at 1:07 PM
    #46
    jethro
    Geoff
    Southern NH
    Well, that may be, but I haven't found one that works well with an aluminum box trailer like mine. Plus they are a PITA when you tow almost every single day. Most have to be steel trailers that you can hook the clamps onto. I also have almost no tongue to work with. Anyway, the 1/2 ton works beautifully in all the weather I pulled through last year, even with the upsized trailer.
    ColoradoTJ[QUOTED] likes this.
  7. Sep 17, 2018 at 1:12 PM
    #47
    la0d0g
    Dude, I have a tow hitch!
  8. Sep 17, 2018 at 1:15 PM
    #48
    ColoradoTJ
    Colorado
    Totally understand.
    This might be your solution to sway, since tongue weight isn’t really an issue for you. I used to run like this a lot as well.
    https://www.etrailer.com/Weight-Dis...e6HCFD8c4xvR4FT5HbtcmJgD8TnQWSXMaAtxgEALw_wcB
  9. Sep 17, 2018 at 1:25 PM
    #49
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Yes and no. I've never been a fan of the 'slippery slope' fallacy because it makes the assumption that taking an action will lead to ever increasing steps towards a ridiculous goal/end result.
    On the one hand, because I drive a 3/4 ton truck I can (and do) haul heavier things than I did when I had a Tacoma. It does a better job of towing loads that the Tacoma struggled with, and can haul more than the Tacoma ever dreamed of. But on the other hand, just because I have a truck that can tow more weight doesn't mean that I'm suddenly trying to drag a 20,000lb trailer up the Rockies and cursing my inability to do so.
    If you compare apples to apples, though, it's a straighter comparison and better judge of what vehicle is 'better' at towing.
    If you hitch 5000lbs to a Tacoma and 5000lbs to a Tundra, the Tundra will walk away from the Tacoma because it's better at towing. Plain and simple. The tradeoff is that the Tacoma gets better gas mileage as a daily driver, is better off-road, and is a hell of a lot easier to park.
  10. Sep 17, 2018 at 1:35 PM
    #50
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    towed a boat from Kelowna to osoyoos about 150kms maybe. pretty sure with the trailer it was like 5500 pounds. yeah it was pretty bad but still managed 75-90 the whole way. if you plan to tow 4500 pounds regularly I would probably be looking at a different truck.
  11. Sep 18, 2018 at 5:50 AM
    #51
    96carboard
    Wonderful. So happy that you have a tow hitch.
    Yet you have a light truck standing up a lot taller (less stable), and have wider and taller tires (lower contact PSI, lower torque -- not just for pulling, but also for stopping, means brakes are less effective). Your configuration would be terrible for hauling.
  12. Sep 18, 2018 at 6:22 AM
    #52
    96carboard
    Not really.
    You see, I actually own a backhoe. It weighs about 17,000 pounds (so plus trailer and it will be well into the 20k+ zone), and once in a while, I do need to move it distances of up to about 100 miles. If I owned a diesel dually, I'd probably try to float it myself, but I don't own one, and won't (because fuel, parking, etc.), so for that once every few years event when I need to float it, I hire someone to move it for me. But for that about once or twice a year thing where I do have to move something that is maybe around HALF that weight or less, I'll use the Tacoma, and if appropriate, stick to the slow roads, limit it to proper weather and so on. I certainly won't be stupid about it and try to move 6000+ pounds in a blizzard, or try to go 80 mph in the fast lane. For a 5000 pound trailer, I am really not going to be overly concerned about it, because frankly, this truck can handle 5000 pounds with ease -- I don't give a damn about how fast or slow it accelerates, so whether something else can "walk away" or not is completely missing the point. Rate of acceleration is NOT a factor in whether something is or is not good at towing something.
  13. Sep 18, 2018 at 6:33 AM
    #53
    Noelie84
    Noel
    Wales, Maine
    Actually, it is...Acceleration is a measure of power, and a certain amount of power is necessary for towing.
    I'll pose it another way, then.
    Hitch 5000lbs to a Tacoma and a Tundra. Which one will maintain speed better on a grade? Which one will brake the load better? Which one will be more stable in windy conditions?
    Tundra. Tundra. Tundra.
    Because it's better for towing than a Tacoma. I agree that there's more to towing than just the ability to accelerate. But just because you don't care how fast you get up to speed doesn't mean that Tacomas are good tow rigs.
  14. Sep 18, 2018 at 6:37 AM
    #54
    96carboard
    It **does not matter**
    Equal.
    The impact of wind varies based on the configuration of the load. A very heavy load may actually be more stable in heavy wind, since it has greater inertia. I'll give an example: Many bridges specify a minimum weight for transport rigs to be permitted to cross. The reason is because a heavy wind could literally knock the trailer over or throw it off the bridge.
  15. Sep 18, 2018 at 6:45 AM
    #55
    Noelie84
    Noel
    Wales, Maine
    :rofl:
    Whatever you say, slick. Tacoma's are the best tow vehicles out there.
    I'm done wasting my time here. Peace
  16. Sep 18, 2018 at 6:46 AM
    #56
    96carboard
    Bye
  17. Sep 18, 2018 at 6:52 AM
    #57
    jethro
    Geoff
    Southern NH
    It's mind boggling the amount of Tacoma owners that don't seem to understand simple physics.
  18. Sep 18, 2018 at 6:54 AM
    #58
    96carboard
    Not sure who that's directed at.
    But in general, I agree with the sentiment. That in fact, it does NOT take 500 hp to pull a bag of mulch home from HD.
  19. Sep 18, 2018 at 7:03 AM
    #59
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    No. No it's not. Haha
  20. Sep 18, 2018 at 7:38 AM
    #60
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Load the mulch in the back of the minivan; I don't want to get the back of my f#50 dirty!
    My brother in law used to borrow my 4cyl Ranger to haul crap because he didnt want to get his leased crew cab high end f150 dirty. Stupid.
