I tried
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beerline123, Nov 2, 2017.
  1. Nov 2, 2017 at 12:04 PM
    Beerline123
    Beerline123 [OP] Well-Known Member
    07 Tacoma access 4x4
    attemped rotor and break pad replacement. First time doing it and felt confident from watching videos. Driver side went well had to run out to Toyota because lug stud was stripped got lucky a local dealer had one stud and lug in stock. Went to do passenger side and broke caliper bolt in half. Most of you guys probably wouldn't have thrown in the towel but I did. Didn't feel I would be able to get other half of bolt out without damaging something else. Took it down to local mechanic and told him to get it out and loosen other caliper bolt and I'd finish job. He said just give me the parts and he would finish. I wanted to do the job to save a couple bucks along with feeling of accomplishment but he said he wouldn't charge me so I figured what the hell. Will see when bill comes in . Feel defeated.
    Gunshot-6A, lo2hi and BenTheMan like this.
  2. Nov 2, 2017 at 12:06 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Time for one of these....:cheers: keep your chin up.
    Gunshot-6A likes this.
  3. Nov 2, 2017 at 12:06 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Broken bolts are a pain. At least you gave it a shot.
    I used to do all my own maintenance that I was able to do to save a few bucks. Now I realize that my time is more important than my money.
    lo2hi, outlawtacoma and utetaco like this.
  4. Nov 2, 2017 at 12:07 PM
    jstyle
    jstyle Well-Known Member
    Josh
    2012 Taco Off Road
    Anything that was shiny is now black
    Well at least you could still drive it as long as the bolt was broken but still stuck in the caliper.
  5. Nov 2, 2017 at 12:08 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's really tough man, and very discouraging. Shit like that happens when you're working on older trucks, and just look at it as a learning process. Did you use any penetrate like PB blaster? That may have kept you from breaking the bolt in two. Just try and hold your head high and move on to the next task. At least you attempted it, which is more than most people can say.
    medic2230 and Gunshot-6A like this.
  6. Nov 2, 2017 at 12:10 PM
    taco2010trd
    Tampa, Florida
    Did rust play an issue with the broken bolt? Did you use an impact wrench? How about penetrating oil before you tried to loosen it?
  7. Nov 2, 2017 at 12:13 PM
    Large
    Large Red
    Shit happens man, just keep wrenching.
  8. Nov 2, 2017 at 12:16 PM
    98tacoma27
    Ben
    Not Beech Creek
    Happens to everyone. I broke both of my rear shock bolts last week. I could tell the first one was going to break when I started wrenching. So I went to Lowes and got enough hardware for both shocks. And to top it off, the pass side shock top nut won't thread down the entire way because of that stupid 5mm hex in the top of the shock is stripped. And I messed the threads up in the process. So now I get to put a new one on when I get home since it was just delivered this morning. I hate 10 minute jobs that turn into an hour job because of stupid shit. :annoyed:
    :cheers:
    fatfurious2 and scocar like this.
  9. Nov 2, 2017 at 12:17 PM
    Jonah
    Jonah Well-Known Member
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    Broken bolts are just part of the experience of doing your own work. Happens to the best of us.
    FYI (in case you didn't know already), when trying to loosen stubborn bolts, pull towards you rather than pushing on the wrench. Punching a metal part when one snaps or gives way can ruin your day. Don't ask me how I know this.
  10. Nov 2, 2017 at 12:19 PM
    Stewbuff
    Stewbuff Well-Known Member
    Andrew
    Centerville, UT
    '05 AC TRD OR Impulse Red
    Diff Breather Extension
    Gotta ask, did you use one of these:
  11. Nov 2, 2017 at 12:19 PM
    98tacoma27
    Ben
    Not Beech Creek
    #scarredknucklebrigade
    Bebop and stickyTaco like this.
  12. Nov 2, 2017 at 12:24 PM
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    I wear that patch.
    OP, it's all part of DIY maintenance. It happens (and happens to the pro mechanics in the shop, too). Don't be put off by this little setback.
    blu92in99 likes this.
  13. Nov 2, 2017 at 12:24 PM
    taco2010trd
    Tampa, Florida
    Ha I know all about this...had to have the local shop do my front shocks after I failed with the hex nut.
    98tacoma27[QUOTED] and Nimble9 like this.
  14. Nov 2, 2017 at 12:27 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    I would definitely call that a "break" job..
    Haha just kidding man, glad you got it sorted out. I pray every time I work on my truck that I don't break something, but I usually do.
    Pigpen and EatSleepTacos like this.
  15. Nov 2, 2017 at 12:28 PM
    Beerline123
    No impact wrench just socket wrench. Used kroil penetrant. Driver side caliper bolts were a bitch so I had to use breaker bar but they did eventually loosen. I don't now I enjoy doing these little jobs they make me feel more confident when I accomplish them even if there just basic maintenance. The other day I had done my plugs and it felt good when done. I'll keep trying but I'll be more nervous on next job whatever that might be. My mechanic told me I did nothing wrong and that it happens all the time with them. Thanks guys for all the encouragement.
  16. Nov 2, 2017 at 12:31 PM
    taco2010trd
    Tampa, Florida
    Some easy ones are: power steering flush, rear shocks (if hex nut doesn't f u), tranmission drain and refill, radiator drain and fill if you are looking for some more maintenance tasks.
  17. Nov 2, 2017 at 12:33 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    What's the old saying? "If you haven't broke a few things you don't work on much stuff"......or something like that.
    A couple of weeks ago I replaced the LCAs on my FIL's Sienna. Accidently disocated the driver's side inner CV joint. FUBAR'd it. Thank you AutoZone for stocking complete axles.
  18. Nov 2, 2017 at 12:35 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Holly shit.... you used aerokroil and still had issues loosening a bolt! That bolt wanted to break! Kroil makes pb blaster look like childs play.
    OP we have all been there where a simple project turns into an adventure.
    I had a similar thing with an ex's car. Here rear calipers were all sorts of fucked and sized on the pins. Im like no problem, pull the rotors and calipers, resurface the rotors, throw new pads in and grease up the calipers. Too bad the lil honda had rotors that were screwed onto the hub with some smaller philips screws (for easier production). But after 12 years and 140k miles of use.... those screws were NOT moving even with an impact driver.... so the angle grinder came out and new rotors were purchased haha.
  19. Nov 2, 2017 at 1:11 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i also stopped on that job. it was raining, i was on my driveway. i laid into that first bolt and it didnt budge. i was about to get medieval..but my spidey senses went off..i took it in to a friends shop. something about having the truck up on a rack makes every one of those fasteners easier to break loose.
  20. Nov 2, 2017 at 1:21 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Using a little heat in safe areas is always a good option. A propane torch can help free a stubborn bolt.
    A slight expansion from heat on a bolt can get you going again. Just use it in safe areas.
    2010tacoma2tr likes this.
