i wanna lift my truck what do i need exactly???
Discussion in 'Suspension' started by biggecko, Mar 19, 2011.
  1. Mar 19, 2011 at 2:18 PM
    #41
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    It will be quite a while if I lift mine but have been watching these threads and I am kinda confused. So with the 5100's all you are doing is adding shocks that will adjust so you can select the height you want? I dont understand how shocks will give you lift. I thought you would need longer coils or spacers and the shocks were just upgraded to a longer travel to center the new travel range?
  2. Mar 19, 2011 at 3:10 PM
    #42
    mattsowell
    mattsowell Ridiculously lazy member
    kamloops, bc
    2010 Tacoma TRD DC SB sport debadged
    no seatbelt chime, stubby antenna, 5100's front and back with AAL, offset rims with Dura-Trac rubber, weathertec mats, Image Dynamic sub with 5 channel Amp and Kenwood Deck with steering wheel control, PIA bulbs, K&N air filter, ARB Delux front bumper
    yesssssssssss. i have wanting to know this exact thing. I am newish to this and was unclear as to the steps I need to take. All I want is a 2" lift and level all around. I have had the rear spring TSB which gives me additional rake at this point. This should give me room for some bigger tires :D
  3. Mar 19, 2011 at 7:17 PM
    #43
    biggecko
    biggecko [OP] Well-Known Member
    Tarek
    Apex,nc
    2000 TRD SR5 pre-runner v6 3.4
    nerf bars, deckplate mod, billys 5100 all the way round with an aal in back
    and say i take out the shocks and replace them with regular old shocks will the truck be lower than it is now, does the trd pakage add any height?
  4. Mar 20, 2011 at 3:17 PM
    #44
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Yes, the front 5100's are adjustable to whatever height you would like, according to what coil you go with whether it be stock or aftermarket.
    They have little snap rings on them around the coil spring base and you have 4 notches for 2nd gens and 3 for 1st gens, you just pick height and assembl.e
    What are you planning to use the truck for and what is your budget?
    Yes it will return to the stock height or whatever height shocks you choose. The rear shocks dont lift at all they are just longer to compensate for the extra lift and rear end travel. Im not to sure about TRD adding any lift stock over a basic stock prerunner but i think it may have a slight bit more.
  5. Mar 20, 2011 at 7:03 PM
    #45
    TacoDawgfan
    Georgia
    Thanks! If/when I lift mine, probably wont do more than 3 inches and dont do much or real hard core off roading so this sounds like just what I need. :thumbsup:
  6. Mar 21, 2011 at 3:27 PM
    #46
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Good deal man, i thnik 3" w/ 33's is plenty enough, to me the 6"DB is a little overkill for the same ground clearance.
    I do a good bit of offroading though and everything has been fine, i ve had my 5100's and eibachs for about 4,000 miles and havent had any problems.
  7. Mar 23, 2011 at 7:13 PM
    #47
    biggecko
    Tarek
    Apex,nc
    my budget is around if not less than 500 bucks i plan on dry offroading like hills and rocks n stuff nothing too bad and also needs to be good for everyday driving to school
