I want a 1st gen taco, which model is best?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ztader, Dec 16, 2010.
  1. Dec 16, 2010 at 1:03 AM
    ztader
    ztader [OP] Member
    I am looking to buy a 1st gen taco but i'm not sure which year model is best. I need a v6. Any help would be greatly appreciated.
  2. Dec 16, 2010 at 4:17 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Get the latest year you can get in the 1st gens ...which would be a 2004. At BEST - between 2001-2004. First Gen's have fallen prey to the frame rust issue/warrantee. Finding one in those years and it fails the frame rust inspection (via Toyota), they will replace the frame and you can keep the truck.
    Any earlier than that and it fails - Toyota keeps the truck and will give you $$ for it.
    The 3.4L V6 is a great motor. You can get the truck in Extended cab 6ft bed or double cab/shortie bed.
  3. Dec 16, 2010 at 7:03 AM
    Barnone
    Barnone Guest
    One with low mileage and excellent original condition.
  4. Dec 16, 2010 at 8:26 AM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    The newer the better. 2003 or 2004 would be my bet.
  5. Dec 16, 2010 at 8:48 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    My opinion a non super charged as it most likely had the shit run out of it!
  6. Dec 16, 2010 at 8:59 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    what region are you in?
    what kind of terrain are you planning to take it into?
    is this truck going to wheel or cruise the mall?
  7. Dec 16, 2010 at 9:27 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I would go with a 2001-2004 TRD 4x4 but that's what I wanted. are you looking for a 4x4 or a 2wd. if you don't plan on going in the snow or off road i would get a 2wd. Make sure you jump under the truck and check for rust some dealers will spry the truck with under coating to make it look good so get under there and inspect it. Other then that low miles is a +
