I want a 3in lift and 33in tires, is this possible
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mhalog, Apr 18, 2017.
  1. Apr 18, 2017 at 5:42 PM
    mhalog
    mhalog [OP] Well-Known Member
    2016 Toyota Tacoma double cab 4x4 TRD
    Hi everyone. I was wondering what brand/company I should be looking at for a 3in lift? I have read a few fomments from people in the group, but would like to get more input on the subject. Furthermore, I was wondering if it was possible to run 33in tires once I get the truck lifted 3inches without any rubbing in the wheel wells.
    ChadsPride likes this.
  2. Apr 18, 2017 at 5:43 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    255 - no rub, no cutting.
    285 - rubbing and cutting..
    Bullnettles, ChadsPride and jeff b like this.
  3. Apr 18, 2017 at 5:55 PM
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    4.5" backspacing on rims is major
    boogie3478 and ChadsPride like this.
  4. Apr 19, 2017 at 7:57 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Will 33's rub after lifted?
    Short answer = YES
    Bring these to your lifting party:
    :sawzall::welder::muscleflexing::headbang:
    JayMac, Nfarrall and ChadsPride like this.
  5. Apr 19, 2017 at 7:59 AM
    la0d0g
    running for the hills
    For crawling not hauling
    But 4" is perfect.
    bski22 and ChadsPride like this.
  6. Apr 19, 2017 at 8:00 AM
    AtxLakeTaco
    AtxLakeTaco Texas Toyota Coalition
    Tres
    ATX
    Black DCSB Prerunner
    5100's,887's,etc.
    rough country is the way to go
  7. Apr 19, 2017 at 8:02 AM
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    Spacer lift on 285 and no rubbing :anonymous:
    :stirthepot:
    ecotecin, JayMac, ChadsPride and 4 others like this.
  8. Apr 19, 2017 at 8:13 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Brand: King
    Rubbing: You probably won't rub on the street but you will rub offroad. And it's not just the plastic from the fender well, it's the cab mount.
  9. Apr 19, 2017 at 8:30 AM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    Bilstein 5100s + OME 888
    Pro Comp Rockwells 17x8.5 +0mm
    zero rubbing w/ 285s
  10. Apr 19, 2017 at 8:46 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Be honest, have you gone wheeling yet?
    bski22, ChadsPride and la0d0g like this.
  11. Apr 19, 2017 at 8:50 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    no :notsure:
    I reshaped my plastic fender liner to give it some extra room just in case....
    why?
  12. Apr 19, 2017 at 9:15 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    No
    bski22, JayMac and ChadsPride like this.
  13. Apr 24, 2017 at 10:51 PM
    mhalog
    I thought Rough Country had a lot of problems with their kit? Correct me if Im wrong. Trying to educate myself on lifts, I have read that the Rough Country kit was better suited for street use and not really a great off-roading lift kit.
    :stirthepot:[/QUOTE]
  14. Apr 24, 2017 at 10:54 PM
    mhalog
    I currently ride on 16in rims. Should I switch to 15in rims? What is the ideal 33in tire dimensions?
  15. Apr 25, 2017 at 5:25 AM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Nobody is gonna give you a straight answer, do your own research and draw your own conclusions. Read a couple build threads, use the search bar
    virvak2, bski22 and JayMac like this.
  16. Apr 25, 2017 at 6:00 AM
    rdlmac
    rdlmac Well-Known Member
    Colorado
    2016 Tacoma DCSB TRD OR
    3" Toytec Boss 2.0 Kit w/ SPC UCAs 285/70r17 Maxxis Razr ATs 17"x7" TRD Pro wheels Softopper Prinsu Cabrac RCI Sliders Mountain Hatch tailgate insert Diode Dynamics SS3 Sport Fogs
    25k miles on 285s and a Toytec Boss kit here. I do moderate offroading(not rock crawling/bashing) and haven't had any issues w/ rubbing. Could it happen? Sure. Has it? No.
    Justanotherhemi likes this.
  17. Apr 25, 2017 at 6:21 AM
    AtxLakeTaco
    Tres
    ATX
    5100's,887's,etc.
    I really suggest you private message marie over at @HeadStrong Off-Road she can answer pretty much any and all of your questions. My set up is as follows: Front: Bilstein 5100's set at 0, with old man emu 887 springs (the taller of the springs they make for tacomas, will provide a true three inches of lift), stock upper control arms (yes this is possible, currently rebuilding a set of camburg ucas). Rear: Purchased a basically brand new oem leaf pack from a fellow TW and installed a 1.5 inch AAL, with bilstein 5100's (standard length).
    Like I said marie is super helpful and is basically the only reason I haven't regretted spending my hard earned money on my truck.
    And to answer your tire question, your more than likely going to have to do what they call a cab mount chop (cmc) for labor and parts it shouldn't run you over 200 bucks, any major off road shop that offer fabrication work should be able to do this. With this cmc you should be able to run up to 285 or 295 size tires which is a bit bigger than 33's.
  18. Apr 25, 2017 at 6:22 AM
    AtxLakeTaco
    Tres
    ATX
    5100's,887's,etc.
    I really suggest you go read the thread "halftime speech" go search it under tittles only.
  19. Apr 25, 2017 at 6:50 AM
    la0d0g
    Why? He answered the guy's question.
    Sub-Zero likes this.
  20. Apr 25, 2017 at 6:54 AM
    AtxLakeTaco
    Tres
    ATX
    5100's,887's,etc.
