I want a 6" lift? Any suggestions??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07COMA801, Feb 18, 2013.
  1. Feb 18, 2013 at 4:56 PM
    07COMA801
    07COMA801 [OP] TOYOTA.. Because barbie drives a jeep..
    Kris
    salt lake city
    07 Indigo Ink DCSB TRD OR
    ARB/OME 3" lift kit- (886 coil/springs-Dakar leaf pack)- 265/75r16 Toyo open Country M/T's - Stock 16" Toyota Wheels painted black - Full Size Spare W/a steele rim- B.A.M.F Slider W/Kickout (Bolt on)- Tint all round including windshield - Tint headlights and taillights - Bed lined grill surround and rear bumper - Color matched Toyota emblem - OEM Mud Flaps cut in half- Ultragauge - Cobra Radar Detector - Cheap Front seat covers/steering wheel cover - Remote Engine Start - Diff Breather Mod - Tailgate lock mod
    I have a 2007 double cab TRD 4X4
    I feel like most of you guys on here have done alot of reasearch and could help out im looking for durablility for off roading as well..
    Thanks
  2. Feb 18, 2013 at 4:59 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Elko, NV
    '09 Offroad
    Lift Armor Badassery with a shit ton of pin stripes 18% Tint
  3. Feb 18, 2013 at 4:59 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    My experience with a 6 inch lift is they are for show not off road durability. I am not saying that a 6 inch lift cant be taken off road there are just not built that strong.
    Why a 6 inch lift? why not a 3 inch? you dont gain any clearance with a 6 inch lift.
    Also the big company is fabtech i have installed many of the products aswell as procomp.
  4. Feb 18, 2013 at 5:01 PM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    Why do you want a 6inch lift? You wouldn't be happy with a 3in and a 1 inch body? theres a 4 inch lift thats tough and reliable
  5. Feb 18, 2013 at 5:03 PM
    jacko
    jacko Active Member
    Jack
    Destin
    '10 MGM TRD Sport
    6' BDS Lift 35' 1250 17 Toyo M/T 17' XD Revolvers 5% tint all around Yakima racks Debadged all around UWS low profile toolbox 4.88 Yukon gears
    BDS. Lifetime warranty, and it's held up good on the trails and in mud
  6. Feb 18, 2013 at 5:04 PM
    07COMA801
    Kris
    salt lake city
    ...Listed 6" so peeps would look and post but i really want a 3"-4" lift and some bigger tires so i have some clearence and durablility, i just was looking for some brands and some info on what too get from people with experience
  7. Feb 18, 2013 at 5:07 PM
    blake5995
    Blake
    Truckee, CA
    How hard are you on it? I helped my buddy install the first fabtech kit back in 04 when the 05 came out and that thing has broke so many times. Had to redesign it and sent them back how it should be made and they redesigned it again
  8. Feb 18, 2013 at 5:08 PM
    blake5995
    Blake
    Truckee, CA
    what size tires you thinking? 4 inch you are going to have to do a 3 inch suspension and 1 inch body which i dont suggest i dont like body lifts
  9. Feb 18, 2013 at 5:08 PM
    KJaikaran
    KJaikaran Well-Known Member
    Orlando FL
    2011 Tacoma DCSB TRD Sport
    URD intake/maf calibrator, Icon extended travel coilovers, Icon UCA, OME Dakar leaf packs, Bilstein extended rear shocks, 3 degree axle shims, Carrier bearing drop bracket, DS2 retro, 5k HID bulds top and bottom
    Front: Spindles will give you 4" lift then you can go with your choice of suspension to gain the other 2". I would go with coilovers, or you can do the adjustable bilsteins.
    Rear: I would do the all-pro leaf back that will give you 4" of lift in rear with unloaded bed then maybe a 1-1.5" block. I deff wouldn't go over 1.5" block, of you could just do a custom leaf pack.
  10. Feb 18, 2013 at 5:08 PM
    tacomataco2
    Eastham Mass
    02 Dbl cab Silver
  11. Feb 18, 2013 at 5:09 PM
    Blacktacoma23
    Blacktacoma23 CO
    Denver
    2011 TACO
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, Nitto Mud Grapplers, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5%/30% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    Go hard!
    kit is super solid with a great warranty
  12. Feb 18, 2013 at 5:09 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Can't do spindles on a 4x4
  13. Feb 18, 2013 at 5:09 PM
    blake5995
    Blake
    Truckee, CA
    He says he only want 3-4"...
  14. Feb 18, 2013 at 5:10 PM
    blake5995
    Blake
    Truckee, CA
    x2
  15. Feb 18, 2013 at 5:10 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    6" for offroading? Those two don't mix.
  16. Feb 18, 2013 at 5:10 PM
    Blacktacoma23
    Blacktacoma23 CO
    Denver
    2011 TACO
    Good point, OP 2wd or 4wd?
  17. Feb 18, 2013 at 5:11 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    According to OP's first post he's 4wd
  18. Feb 18, 2013 at 5:12 PM
    blake5995
    Blake
    Truckee, CA
    He only wants 3-4"...
  19. Feb 18, 2013 at 5:13 PM
    jacko
    jacko Active Member
    Jack
    Destin
    '10 MGM TRD Sport
    I haven't had any problems. It's the only lift I've had though so I've got nothing to compare it to. But I'm definitely a happy customer
  20. Feb 18, 2013 at 5:14 PM
    KJaikaran
    Orlando FL
    Didn't catch that at first.
