I want a bigger engine.
Discussion in '1st Gen. Tacomas (1995-2004)' started by UhOh nd his taco, Aug 29, 2012.
  1. Aug 29, 2012 at 6:30 PM
    thatoneguy
    thatoneguy Well-Known Member
    Salt Lake City
    87 4runner SR5
    31" Mud-terrains
    I agree. Dirty chev 350 swaps seem to be reasonably common on the 1st and 2nd gen 4runners, so i'd imagine they wouldn't be outrageous in a tacoma.
    Or, build a 2rz or 3rz. I watched a couple videos of some forced-induction RZ's today on youtube, it got me thinking. They were pullin hard!
  2. Aug 29, 2012 at 8:10 PM
    UhOh nd his taco
    UhOh nd his taco [OP] Member
    russ
    1995 Toyota Taco V6 4X4
    Cool air intake, series 2 racing clutch, subs, and hid kits.
    it had 340,000 and then i just got sick of fixing all the issues it kept going out here and there so i stored it till i get my new parts
  3. Aug 30, 2012 at 6:37 AM
    06yfz450ridr
    06yfz450ridr Well-Known Member
    Austin
    CT
    HID's
    is that a mopar 440 six pack?
  4. Aug 30, 2012 at 7:06 AM
    BamaToy1997
    Bill
    Navarre, FL
    I was actually considering a Chevy V8 swap into mine when the 2.7 let go. I decided against it only because of fab time and cost. I am still sitting on my Chevy LS1 Corvette motor and am waiting for a project car/truck to put it into. The conversion can be made with a reasonable amount of fabrication. Most of what I have seen done is the cutting out of the front crossmember, and welding a never pair, one in the front, and another bolt in one in the back, just under the transmission. This is needed for strength and rigidity due to the torque that this frame is not designed to take, and the removal of the original is to allow for the oil pan. There are a couple of companies out there that offer a "bolt-in" kit that consists of prefabbed engine mounts, bellhousing adapters, and transmission mounts. These kits are only for the install thought, and do not take into account the pre-mods you have to make to the frame and suspension. I am not sure if this is required, but so far I have not seen a Tacoma with a V8 swap that retained the IFS. They all had an SAS swap done as well.
  5. Aug 30, 2012 at 7:40 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Duramax LMM and allison trans.
  6. Aug 30, 2012 at 7:53 AM
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Western Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod
    do the toyota d-4d turbo diesel swap!
  7. Sep 17, 2012 at 9:59 PM
    Bino9905
    Bino9905 Well-Known Member
    TX
    99 ExtCab 4X4 V-6 TRD
    I agree with Rebel, when mine goes out im going diesel. I think you can get one of those sent in from japan for less than $2K if that doesnt work then the cummins 4bt engine would be good.
