I want a little more lift, opinions?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YotaOwner, Feb 21, 2014.
  1. Feb 21, 2014 at 8:47 AM
    YotaOwner
    YotaOwner [OP] Well-Known Member
    Zack
    Western North Carolina
    2000 Tacoma Reg Cab
    Ok so I've added my toytec 3" lift with front coils and 5100s at 0 and AAL with 5100s in the rear. I'd like another inch or so, not much more. I know I'll get hit with a big stick for saying this but I'm gonna say it, would a body lift be the best way to get that inch? I know it's not good to put a spacer lift and blocks on top of the suspension I've already added and I don't want to give up function for form. I've been looking all over the place for an alternative to the body lift(can't even find a body lift for that matter) but I know I can at least make a body lift if I go that route. Let's hear it.
  2. Feb 21, 2014 at 9:42 AM
    jimmybee1108
    jimmybee1108 Well-Known Member
    JM
    San Antono
    2012 blk DC sr5 v6 prerunner
    bilstein 5100s, wheelers AALs, amazon dual 10 sub box, with two jlw1s cheap HIDs
    One word: spindles.
    Maxtrac will be 4" I believe
    Camburg and tc are 3.5" I think.
    But you could get those, and also crank up the shocks then get bigger leafs in the back.
    Wish I could go that route. I just don't trust BLs
  3. Feb 21, 2014 at 12:52 PM
    YotaOwner
    Zack
    2000 Tacoma Reg Cab
    I already have the AAL in the rear, and I've only seen spindles for the 2wd trucks. And I'm more comfortable with 1" BL than a spacer lift on top of my suspension lift. I'm not comfortable with 2"+ BL but I'd settle for a 1" if I can't find it to add to my suspension.
  4. Feb 21, 2014 at 12:57 PM
    jimmybee1108
    JM
    San Antono
    I thought I saw a certain brand that sold spindles for 4x4s. I'll need to find it
  5. Feb 21, 2014 at 1:00 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    nope, no 4x4 lift spindles exist.
  6. Feb 21, 2014 at 1:03 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    If you want more lift without going body or spacer you might want to get a 6 inch lift.
  7. Feb 21, 2014 at 2:34 PM
    jimmybee1108
    JM
    San Antono
    Damn. I must be blind or dyslexic. It happens. When I drink Valencia grove amber shiner. I think if says vagina good on her
  8. Feb 21, 2014 at 3:46 PM
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    There's nothing fundamentally wrong with a body lift if you just want to clear bigger rubber. They can squeak and cause problems lining up aftermarket bumpers, slider's, etc. But you're not going to bust your junk over a 1" BL. I wouldn't do it just for looks, but they have their place.
  9. Feb 21, 2014 at 3:57 PM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Yeah, I think you're kind of stuck with a body lift if you want more without a DB lift. If you put spacers on top of your current suspension you'll have just about no down travel which will make it ride very rough, that and the CVs will be at a wicked angle. As the pervious poster said, nothing wrong with a 1 in body lift, above that is where supposedly problems can arise. If you're just looking to get bigger tires on I'd just bust out the angle grinder, save yourself the headache.
    What size tires do you have now? They'll lift it too...
  10. Feb 21, 2014 at 4:12 PM
    YotaOwner
    Zack
    2000 Tacoma Reg Cab
    I have 285/75, I'm not doing it just to clear bigger tires, and it's not just for tires, those are just two positive outcomes. And I don't want to buy a whole other lift when I have a brand new one so the 6" is a no, my 87 p/u had a BL and did just fine so I know 1" is gonna be safe on what I have. The whole reason I want that extra lift is to stuff the tires further UP when I take it wheeling without tearing a fender off. I don't want to cut it, yet, but once I start cutting the first things to be cut are the cab mounts and as off now I'm not hitting those yet. El Lobo thanks for the link! And everyone else thanks for the input. I believe I'll do the 1" BL and when I take it out and get some serious rubbing going I'll trim from there. I'll update my other thread when I get the stuff together and put it on.
  11. Feb 22, 2014 at 5:46 AM
    SpecialED
    SpecialED Active Member
    Ed
    Southtern MD (Chuck County)
    06' Tacoma Double Cab
    N/A
    I am contemplating getting the same 3" lift Yotaowner, how is the ride on your current system?
  12. Feb 22, 2014 at 5:49 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    You can add a 1/2" top plate spacer to it that will yield about another inch of lift. Those are fine. Might need longer top plate bolts on your coilovers though.
  13. Feb 22, 2014 at 9:26 AM
    bpayne97
    bpayne97 Well-Known Member
    McAllen, TX
    06 TRD OR 4x4 Debadged
    URD SS Kit and TRD shift knob, rearview mirror bracket, Fox 2.0 coilovers and smooth bodies
    Lots of guys running 1-1 1/4" BL's in conjunction with the typical 3/2 lift on 4runners. If you get a quality BL it should be just fine but there is the gap. If it bothers you, you will have to modify. I had a 1/2" BL on my runner with the Toytec 3/2 lift and kind of likes it. It was cheap, added a little "ups" and never squeaked...I half way forgot it was on there!
  14. Feb 22, 2014 at 1:55 PM
    YotaOwner
    Zack
    2000 Tacoma Reg Cab
    Mine rides like stock for the most part, the rear is a little stiffer as expected so bumps are a little more noticeable. Overall I'm very pleased with it though. And I think I'll pull the trigger Monday on a 1" BL
