I want Free Stuff
Discussion in 'Buy / Sell / Trade' started by ryanjboutin, Feb 23, 2011.
  1. Dec 12, 2013 at 1:32 PM
    #2001
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5 LUXURY YEAR
    Added extra awesomeness to its original awesomeness.
    Just checking again, anyone have a driver side foot rest for a 2nd gen they aren't wanting?
  2. Dec 12, 2013 at 3:10 PM
    #2002
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 886's, Locker Mod. Bilstein 5100's on 4 corners
    Anyone have a good center support bearing? OEM is fucking pricey.
  3. Dec 13, 2013 at 3:12 PM
    #2003
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    Worse than Hell (SoCal)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    Need driver's seat belt retractor unit (with the airbag connector).
    Also need driver's side rear door privacy glass for a DC.
  4. Dec 16, 2013 at 9:14 AM
    #2004
    luke99
    luke99 Member
    Southern Utah
    99 Taco, SR5 TRD
    Need a grille emblem for a 99 tacoma
  5. Dec 16, 2013 at 11:46 AM
    #2005
    Smashing
    Smashing Well-Known Member
    Rochester NY
    2010 DCLB TRD 4x4
    2010 compatible grille. don't care what color but MGM would be perfect.
  6. Dec 16, 2013 at 12:16 PM
    #2006
    somethinboutayota
    somethinboutayota Dorthy left Kansas for a reason
    Parker
    Dodge City, Kansas
    Go to get alignment- replace whole front end
    Debadged and painted, plasti-dip bumper , Sock monkey decals, tool box, K&N cold air intake, flag holder/fishing pole holder, Satoshi, magnaflow 40 series, spidertrax wheel spacers, map lights, led reverse lights, led dash assembly lights, roof top LED bar
    I have one hanging out in my room, send me a PM
  7. Dec 16, 2013 at 1:34 PM
    #2007
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    Pasadena CA
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights - 3k) Bullz Audio 0g wire Exterior: Blacked out OEM headlight housing Front grille swap (to chrome, dipped red) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome) 99 Cents Store tailgate lock Suspension: 1" spindle spacer kit (Addional nuts and longer bolts added) 4x4 leaf pack swap (middle leaf removed) 1" Drop Blocks Air Lift rear helper springs Rims: 18x9.5 Asuka ST 15-2 rims et26 all around 5mm billet aluminum wheel spacers 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Pioneer DEH 5000ub Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (old Dickies pants shift boot)
    if anyone has some old shocks, don't care if they work or not. Just need the bushing in the bottom of the shock. Busted one when swapping out my old OEM rear shocks.
  8. Dec 17, 2013 at 8:45 AM
    #2008
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    05 Speedway Blue PreRunner TRD Off Road
    3 inch lift OME 885, 2in AAL, 5100's, Black Badges, Fog anytime, ABS on/off, window vents, Blacked grill and rear bumper, Afe pro s dry drop in filter.
    Rear floor mats for a 2nd gen access cab. Rubber mats would be preferable but carpet will do to. Thanks.
  9. Dec 17, 2013 at 2:20 PM
    #2009
    Mach375
    Need the driver's seat belt retractor in grey. The one with the airbag connector.
  10. Dec 17, 2013 at 2:23 PM
    #2010
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Want TRD Buckets and QA1 Coilovers if anyone has a set up for free.
  11. Dec 18, 2013 at 7:26 AM
    #2011
    mmadej87
    mmadej87 Mayday
    NMB, FL
    98 Xcab Prerunner
    Looking for shock set up for 1st Gen. Stock, aftermarket, anything as long as they work...mine are so worn out..haah, Thanks in advance
  12. Dec 21, 2013 at 8:20 PM
    #2012
    Brandon###
    Brandon### Well-Known Member
    I just bought one at the stealership...it was $5
  13. Dec 21, 2013 at 9:11 PM
    #2013
    Mach375
    Looking for the secondary (carbon/emissions) air filter in the engine airbox for the 1GRFE (4.0L V6). The one that sits behind the main air filter. Very popular item to remove by people who believe it restricts airflow.
    Or I can take the entire air filter housing, for those of you switching over to a CAI or a supercharger.
    Mine's been marinating in engine oil ever since my rollover.
  14. Dec 21, 2013 at 9:47 PM
    #2014
    aw10tacoma
    aw10tacoma backyard mechanic
    Andrew
    Bergen County, Nj
    2011 AC OME3inch lift
    -HomerTaco Grille -Aftermarket Headlights Halo Projectors -kobolt toolbox/toyota bed extender -rear doors now have pioneer speakers… installed myself -Kenwood DNX690HD -LED speedo gauge swap and faceplate along with painted needles -TRD spray painted on grille -Strobe lights in reverse lights -All bulbs are now led -XD rims -arb bumper -SLIDERS -OME 3inch suspension lift nitrocharger sport shocks dakar leafs -light racing ucas -toughtlight 22''dual led bar behind my homertaco grille -wet okale seat covers -2 led off roading lights mounted to the bullbar -trailer lights connection moved into bumper -tints -trd cold air intake -trd catback exhuast -total chaos lca skids -ATO IFS Skidplate -DT Shorties
    I ve got a mgm in northern nj off my 11
  15. Dec 25, 2013 at 7:28 PM
    #2015
    TypicalPete
    TypicalPete Well-Known Member
    California
    08 Access Cab
    Anyone got a pair of OEM headlights?
  16. Dec 26, 2013 at 6:00 AM
    #2016
    mmadej87
    mmadej87 Mayday
    NMB, FL
    98 Xcab Prerunner
    Also looking for a front grill for a 98
  17. Dec 26, 2013 at 6:48 AM
    #2017
    Phil Dammit
    Your Mom
    Tempe, Arizona
    bed pockets for a second gen, my passenger side doesn like to stay in anymore.
  18. Dec 26, 2013 at 9:27 AM
    #2018
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    2001 4x4 5Spd Xtra Cab V6
    265/75/16 BFG A/T's, OME 881's, Wheelers 5 leaf pack, 5100's, Home Made Sliders
    Anyone have a set of good second gen 6 lug rear shocks they don't want?
  19. Dec 27, 2013 at 7:05 PM
    #2019
    skidooman
    skidooman I'm your huckleberry
    TJ
    Idaho
    sold everything
    This guy has one.
    In this thread
  20. Dec 27, 2013 at 9:31 PM
    #2020
    Taylor
    Taylor Wants to learn all about his Taco.
    Taylor
    Lynchburg/Harrisonburg Virginia
    03 4x4 TRD SR5 College build
    Extra badges, painted skidplates, grey wire mod, Kenwood double-DIN headunit, pioneer amp, 12 inch MTX sub, playstation 2 under seat, Uniden CB with 5 foot Wilson 1000 antenna, deckplate mod, 4xinnovations sliders, diff breather mod, bilstein 5100s at all 4 corners, OME Dakar Leaves, BAMF BPV bracket, Wheelers greasable shackles,
    I have a grill emblem off my old 96 Taco.
